Question about Jabra BT150 Wireless Headset
BT150 not going into discoverable mode
I've tried everything: 1- holding down just the power button.  No solid blue light. 2 - holding down the + and power key. No solid blue light. 3 - holding down all keys.  no solid blue light.
I did all of this after already turning the headset off.  So how do I get it to work now?  Is there some sort of magic dance I'm supposed to do?
  • 1 more comment
  • ribaf Mar 02, 2009
    I'm trying to make it discoverable for my cell phone
    i have the same problem
  • Anonymous Mar 31, 2014
    my device is stuck on a solid blue light. it will not do anything
First turn on the Jabra BT 150 by holding the power button for about 4 seconds. Then hold the + key and the the power button together for about 4 seconds and the power light will go steady. Then have your bluetooth capable cell phone search. It'll find it and when asked for a PIN just enter 0000. Tjis will change the jabra power light to blinking when paired successful.
ribaf@cox.net
Posted on Mar 02, 2009
Which botton do i hold
If i remember correctly, turn it off, hold the up volume button, then hold the power button as well. Hold them until about 8 secs after the light comes on, when you should see the light go solid blue, and possible blink from red to blue, either of these means your in pairing mode.
GOOD LUCK AND PLS RATE THIS POST!!!!
Jun 05, 2010 | Jabra BT150 Wireless Headset
How do i set my my motorola h350 into discoverable mode
Plug the Motorola charger into the end of
the headset.
The blue indicator light turns on when the
battery is charging. It may take up to 1
minute for the light to turn on. When the
headset's battery is fully charged (about 2
hours), the blue indicator light turns off.
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit.
Note: The blue light will flash as you press and hold the Call
button. Continue holding down the Call button until the blue
light is steadily lit.
Note: If you let go of the Call button before the blue light is
on and steady, ensure that your headset is off before trying
again.
Oct 05, 2009 | Motorola Mobility H300 Wireless Headset
Hoe do i put the lg hbm-760 in pairing mode????
Turn it on by holding the power button for four seconds, Then go to your phones bluetooth setup screen, search for new devices, and pair it. The blue led on the HBM-760 will turn solid blue during pairing. It is always discoverable. The default passkey is 0000. Hope this helps.
Jun 22, 2009 | LG Car Charger For HBM-710, HBM-760...
Jabra BT3030 Device in Discoverable Mode?
Read the users manual(google is your friend)
But in case they drop support soon, turn the beastie on, press and hold the Vol+ and Answer Call buttons till the "on" light goes solid. You're now in discover mode.
May 15, 2009 | Jabra BT150 Wireless Headset
Motorola HS850 N136 bluetooth won't go into discoverable mode. I press and hold the call button. The light turns blue for a second but then turns off. I am trying to get my cell phone to discover it.
open the boom (mic) right when it turns to solid blue!
http://www.motorola.com/consumer/v/index.jsp?vgnextoid=4507f7c0c1a0b010VgnVCM1000008206b00aRCRD&ps=y&pg=PG_TYP_00003&show=globalSupport&productID=e4e6e7af976c9010VgnVCM1000008206b00aRCRD
May 06, 2009 | Motorola Mobility HS850 Consumer Headset
Get jabra in discoverable mode
ok i finally found out.. Turn on the jabra unit once on hold the answer button AND the volume up button at same time till u get solid blue light... It will flash like 8 times then go solid... At that point it can b found by all ur devices... the passcode is 0000... Enjoy
Apr 14, 2009 | Jabra BT350 Bluetooth Headset Headset
I have a wireless headphones the only number i can see is model f0461b on the trasmitter. The transmitter and headphone are not comunicating the lights are red not blue.How do i recalibrate them so they...
In rare cases, the FreePulse Headphones may loose synchronization with the receiver. If this occurs the following steps will re-establish the connection by putting both the headphones and the receiver in discoverable mode (actively searching for another bluetooth device it can connect to).
Putting the headphones in discoverable mode:
Press and hold the power button (located next to the charging port on the right earpiece) on the headphones. The LED on the button will go through three states in this order:
  • Blinking Red
  • Off (continue to hold. the LED will be off for several seconds)
  • Alternately blinking red and blue. (The headphones are now in discoverable mode and you can release the button at this point. The headphones will remain in this state for 30 seconds).
Putting the receiver in discoverable mode:
Press and hold the power button (located on the side of the receiver opposite the headphone jack).The LED on the button will go through three states in this order:
  • Blinking Red
  • Alternately blinking red and blue. (The reciever is now in discoverable mode and you can release the button at this point. The reciever will remain in this state for 30 seconds).
Re-establishing the connection:
To re-establish the connection between the headphones and the reciever, put the headphones and the receiver in discoverable mode at the same time. It will take a few seconds for the two devices to establish the connection. Once the connection has been established the LEDs on both the headphones and receiver will glow solid blue.
Nov 19, 2008 | Audio Players & Recorders
Trying to pair BT150 but it won't go into pairing mode
I had the same problem. The many instructions available don't have quite the right details. This worked for me:
1. Turn off the BT150 by holding down the answer button about 5 sec. until the blue light goes off and is not flashing.
2. Turn on the BT150 by holding down the answer button about 5 sec. until the blue light flashes.
3. Keep holding the answer button, and press and hold the volume + button for another 5 sec. until the blue light comes on solid.
Nov 12, 2008 | Jabra BT150 Wireless Headset
Lost instructions BT150 how to connect to phone?
1. Turn the BT150 on. To do this press and hold the answer/end button until the light flashes blue, then release.
2. Press and hold the answer/end button and the volume up (+) button until you receive solid blue light. This may take up to 10 seconds.
3. Go into the Bluetooth menu on your cell phone and follow the cell phone’s instruction guide for pairing a Bluetooth headset. This generally involves going into a “devices” or “hands free” menu and adding a new device. Your phone may ask if you want to pair with the headset, accept by pressing “yes” or “OK” and confirm with the passkey or PIN 0000 (4 zeros).
Goodluck
Apr 27, 2008 | Jabra BT150 Wireless Headset
Jabra BT150
DO AS THAY SAID HERE.......Press power button and the - and + volume buttons at the same time AND THEN WHEN THE BLUE LIGHT STOPS ON !!!!! GO TO YR PHONE AND SEARCH FOR THE HEADSET WHEN U HAVE FOUND IT ON YR MOBILE TIPE .........0000...... then you will be sorted
hope this helps c ya
Nov 04, 2007 | Jabra BT150 Wireless Headset
Jabra BT150 Wireless Headset Logo
411 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Jazz Boyce
Jazz Boyce
Level 1 Expert
vimal
vimal
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
