Question about GE Energy Star WCVH6260F Front Load Washer
Kenmore Front Loading Washer started vibrating wildly.
The washer started vibrating wildly after 4-5 years of good service. I removed the back panel and rotated the drum and motor thinking bearings might be a problem, but they seem ok. The shock absorbers seem ok too, although I never saw inspected them before the problem and have no reference. I downloaded the Electrolux manual from online but saw no troubleshooting for my problem. Any help? Thanks!
  • odpoe Feb 12, 2009
    Thanks for the help! Broke it down and that was the problem, am waiting on a new inner tub.
  • Anonymous Feb 18, 2009
    This machine is the biggest piece of **** I have ever owned!
    It's 2 years old and broke already? I will never buy a GE product again!
Here is a website that outlines what your problem might be. I had the same problem yesterday after owning my Kenmore tumble washer since July, 2003.
http://www.jimwilliamson.net/misc/2006-08-28-front-load-washer/index.html
Posted on Feb 11, 2009
Water will not drain out of front Load Kenmore 44072
Kenmore front loading washing machines will give you years of service. Sometimes things do go wrong, especially after the warranty runs out. Troubleshooting a Kenmore front loading washing machine could save you a lot of money on a repair bill. Before you call a service technician to fix your machine, attempt to resolve the issue through simple fixes first.
Washer Code Messages Your Kenmore front loading washing machine has an LED display that will give you error codes.
Will Not Spin If your washing machine does not spin, check to make sure the door has latched completely. Also remember that if your machine is in the SUD cycle it will not spin until it has eliminated the suds.
Washer Is Noisy
  • If the washer is making noise or vibrating, check to make sure it is still level. If it is out of level you can change this by adjusting the feet. Metal belt buckles and buttons in your laundry could be causing the noise as well.
  • Door Stays Locked After Cycle
  • At the end of the wash cycle, the lock will disengage after about 30 seconds. If it does not, it may be because the machine still detects that the water has not completely drained. Just select "Drain" and "Spin" and let the washer go through the cycle. Your door should unlock.
Nov 03, 2011 | Washing Machines
I recently moved and the movers removed two bolts from the back of the machine...should I replace those bolts
No do not replace the shipping bolts. I assume you have a front loading washer. The tub is secured by bolts during transport. Then they have to be removed so that the washer will operate properly without damaging the machine.
Many machine manuals are available online. For example, LG washers manuals are available at their site and under more information for models sold by Home Depot (http://www.homedepot.com/Appliances-Laundry-Clothing-Care-Washers-Front-Load-Washers/h_d1/N-5yc1vZ1xr5Zbv6h/h_d2/Navigation?langId=-1&storeId=10051&catalogId=10053&omni=c_Front%20Load%20Washers). The LG front loading washers use 4 bolts with retainers. If they are not removed, the machine will have severe vibration and noise. The vibration can damage the unit.
I hope this helps.
(if you have an top loading washer, shipping bolts are less common. If you provide the model of the washer, I'll see if it is one for which I know the shipping instructions.)
Dec 12, 2010 | Washing Machines
The machine is not spinning or tumbling, i went through the diagnostic test and that was the only thing it did not do. my understanding is that it is a belt that should be the problem how do i get at it?
I have the same washer and problem. I've had mine for just over five years with no problems, but I've had other top loading washers for as many as 12 years. I solved the problem with the Kenmore 44042 as follows:
1. Remove the washer from the laundry room and move it to the garage.
2. Go to Lowe's and purchase a Roper top loading washer for $300.
3. Install the new Roper in place of the Kenmore 44042.
4. Create and sign an agreement with yourself to never purchase another Kenmore product.
Sep 26, 2009 | Kenmore 44042 Front Load Washer
Can't remove front bottom panel to get to pump
Hello, lean the washer back, place something underneath it to hold it back( place 2 2x4 blocks either side), remove 3 screws with star driver...remove panel. You will see the drain filter right beside the pump. Good Luck! Mike
Sep 22, 2009 | Kenmore 44042 Front Load Washer
I have a Kenmore he5 front loading washer. It
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 09, 2009 | Kenmore Washing Machines
Removing front panel from kenmore elite HE-3 front load washer?
If you've removed the screws and the panel sticks, tapping on each side will knock it loose. The panel should drop down, then off. You can also try propping the two front feet of the washer up slightly for better access. A 2x4 works real well. This will allow more room for the panel to drop and gives better access to the screws. The washer is very heavy, so you may need some assistance to lift the front. Either lift from the bottom, or place your hands on the front facing of the cabinet to push the washer back. DO NOT push on the door or control panel.
If you still need assistance, please let me know. I hope this helps you.
Jul 05, 2009 | Kenmore Elite 45986 Front Load Washer
Washing machine has a seizure during the spin cycle.
Try leveling the washer so that it is about half a bubble biased towards the rear. This usually helps front loading washers balance properly even if the installation instructions say that it should be perfectly level. This can also aid draining problems.
Also, some newer front loading washing machines are simply prone to dramatic vibration even when they is "anti-vibration" or "vibration reduction" systems. You can never go wrong installing an anti-vibration pad under the washer. Good Vibrations Inc, Kellett Enterprises and The Vibration Solution all have good products. The Vibration Solution seems to have figured out the best solution and offers excellent support and return policies.
Washer anti-vibration pads
If all else fails call the retailer and ask for an exchange.
Jun 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore front loading washer won't drain or aggitate, just buzzes
take the front bottom panel off. inside there is a drain pump. you need to remove filter from drain pump its look like a knob. be careful because their is water inside your drain pump so use some big thing for water. clean your filter. put filter back tight. i hope will solve your problem.
May 23, 2009 | Kenmore 43142 Front Load Washer
Kenmore HE2 Front Load Washer
is it level ? i had to level mine then i had a nut that come off had to put that back on on i am all set
May 22, 2008 | Kenmore 43142 Front Load Washer
Kenmore Elite problem
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^@#
Apr 28, 2007 | Kenmore Elite 45986 Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
328 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
