Question about Westinghouse Microwave Ovens
No display on LCD panel on my whirlpool microwave
There is no digital display on my LCD panel on my whirlpool microwave. The model is mh1160xsb. All of the other functions work on the microwave works. The display and the buttons under the dispay panel is the only thing not working. Is there a fuse just for the dispaly only.
Any help would be appreciated.
Thanks
  • 1 more comment
  • mlwhitton Feb 11, 2009
    I just put a new door on the microwave thinking it would solve the problem. It cooks fine. I can hear the beeps when I press the buttons put the clock and digital numbers that should appear on screen dont light up. Thanks for your help.
    You might need to know its a whirlpool MH1160XS
  • roberto serbin May 11, 2010
    Is your microwave cooking normally?
    Novelist:
  • 140 Answers
I do not know what procedure you used to replace the door, but if the buttons and display were working fine before you replaced the door then it seems that there is a plug not plugged into the control display panel. Other than that the low voltage power supply may not be providing the needed voltage for the display and only for the logic circuits which are a different voltage. With the microwave unplugged, take the cover off and look at all the connectors and make sure that they are plugged into something and none that are not plugged in. They should all go somewhere. To answer your original question, there is only one main fuse to the microwave. The circuitry in the control panel operates on low voltages +/- 5 volts or +/-12v so that part is not fused. What I recommend also is to go back mentally through the procedure you used to replace the door and that may give you a clue as to what you unplugged, although you should not have to unplug anything.
Posted on Feb 11, 2009
The control display on my microwave is very dim. Is there any way to make it brighter?
If you had mentioned your full model number, we could have looked whether the VFD is available as a separate part in case your model has a VFD display, or whether the whole control board would have to be replaced.
If your model has an LCD type display, it may be weak LEDs or other failing components in the display backlight circuit.
We regularly repair microwave displays for $39.95 nationwide.
It's pretty rare for a microwave to have a display brightness feature.
Let us know if we can help you further.
Nov 16, 2012 | Whirlpool MH2155XP Microwave Oven
Microwave model number mh1160xsb. It will only turn on for 15 seconds at a time what could be wrong with it
There is a thermal fuse that sometimes becomes defective or the magnetron is getting to hot causing a shut down, exhaust fan may not be running which cools the magnetron, should be checked.
Mar 05, 2012 | Whirlpool Microwave Ovens
We had a power surge and now the microwave does not work, model number MH1160XSB-0 whirlpool, what could be the problem? We put a fuse in and it kept blowing.
Model MX6110XB. Nothing worked. LCD panel was dead. Unplugged and replugged; and everything works.
This fix described for the GE Spacemaker. They say problem result of a power surge. Apparently applies to different manufacturers; or does GE make Whirlpools?
Dec 09, 2010 | Whirlpool Microwave Ovens
F7 code on Whirlpool Microwave model GH9185XLT - 1
Power to magnetron
interrupted
12. Replace inverter.
13. Replace all parts and panels before operating.
14. Plug in microwave oven or reconnect power.
15. If problem persists, unplug microwave oven or disconnect power.
16. Replace electronic control.
17. Replace all parts and panels before operating.
18. Plug in microwave oven or reconnect power.
19. If problem persists, unplug microwave oven or disconnect power.
20. Check for reversed plug connection on controls or loose wiring.
21. Replace all parts and panels before operating.
22. Plug in microwave oven or reconnect power.
May 23, 2017 | Whirlpool GH9185XL Microwave Oven
Whirlpool mh1160xsb over range that buzzes when cooking
It depends on if it is just a loose component that needs tightened up or if it has started failing. it will require some investigation and trial and error to resolve. I have had some success in resolving vibrations and some were real challenges. It is a matter of isolating the noise maker and seeing what can be done.
Eric
Oct 04, 2009 | Microwave Ovens
Whirlpool GH7155XHS microwave shows partial display
The display is defective and requires replacement. Unfortunately, the display is probably incorporated as a unit with the control panel and must be purchased as an entire service part. This will cost $80-$120 depending on the oven make & model. It will cost more if you have a repairer install the part.
It may be more cost effective to replace the oven. Microwave ovens are rather inexpensive these days.
Mar 06, 2009 | Whirlpool GH7155XHS Microwave Oven
The microwave does not work.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
You may have a failed keypad or control board.
We repair these for customers nationwide with our guaranteed $39.95 service.
Aug 07, 2008 | Whirlpool GH7155XHS Microwave Oven
Microwave Ovens Logo
261 people viewed this question
Top Westinghouse Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Westinghouse Microwave Oven Expert? Answer questions, earn points and help others
