Question about Logitech Cordless Desktop EX110
Cap Lock on or off
There does not seem to be a indicator of any sort
    Problem Solver:
  • 5 Answers
Your EX 110 receiver has 3 indicator lights (LEDs) that display the status of the Caps lock, Function key, and the Num lock during normal operating mode. These lights will also flash when the connect button on the receiver is pressed.
LED A: Indicates that the Caps Lock (Capital lock) key is on when lit.
LED F: Indicates that the F keys are in Standard F Keys Mode when lit and in Enhanced F Keys Mode when the LED is off.
  • Your EX 110 keyboard has an Enhanced F Keys Mode for F keys that provides additional functions you can program. See Knowledge Base article 9526.
LED 1: Indicates when the Num Lock (Number lock) key is on. This function allows the number pad to produce only numbers
Posted on Jun 30, 2009
    Scholar:
  • 140 Answers
There are many keyboard that don't have an indicator.
You can just push the caps lock button serveral times and see if there is any indication on the keyboard. If you don't see anything, then your keyboard may not have an indicator light.
Many times a wirless keyboard will have one. The light just causes the batteries to drain faster.
Posted on Feb 11, 2009
2 Suggested Answers
SOURCE:
  • 91 Answers
SOURCE: Cap Lock Indicator missing
You could turn on "Toggle Keys" (which is a feature in Windows XP) that plays a high-pitched tone when Num Lock is turned on and a low-pitched tone when it is turned off.
(Don't worry, the sound isn't annoying or anything)
To turn on Toggle Keys:
Open "Control Panel"
Open "Accessibility Options"
On the "Keyboard" Tab put a check mark in the box labeled "Use Toggle Keys"
Click "OK"
Give it a try & see if you like it.
Posted on Jan 10, 2009
Is there a user guide for this laptop?? If not is there a light or something that indicates the cap lock is on??
Just type something to see if cap lock is on, then press cap lock to turn it off if it is on
Feb 06, 2016 | Computers & Internet
Cap lock indicator for asus n55s
the caps locks led is located on the led-bar above the keyboard.
May 06, 2014 | ASUS N53SV-XV1 Versatile Entertainment...
Asus X75A has no cap lock indicator want software to correct this
Download the latest software from Asus. If it is available, that is where it will be.
Feb 25, 2014 | ASUS Computers & Internet
I have a 2002 Grand Caravan 3.3 with no heat after I replaced the radiator.I replaced the thermostat and still no heat.Heater core isn't blocked because I have coolant running through it...the question is...
Sounds like an air lock in the system, on the thermostat housing or right below the rad cap you will find a bleeder valve like on a brake cylinder.Crack it open while running and allow the air to escape from the sytem,hope this helps
Jan 22, 2011 | 2002 Dodge Caravan
Where is the light indicating that the caps are on?
It is usually a little A in a padlock. the easiest check is turn them on then off and see which light changes.
Dec 14, 2010 | Dell Wireless Keyboard Optical Mouse w0147
My dell d600 latitude laptop indicates a lock button in the top icons and cant procede from there
purple function key next to the ctrl key
press that down and hold
press the num lock (toggle)
press the scroll lk (toggle)
press white cap lock only
See if any of these change the lighted lock indicator.
I assume that was what you mentioned in a focus of the request
Aug 19, 2010 | Dell Latitude D600 Notebook
I need help removing the fuel pump from my 1998 chevy truck it seems to be fixed in place, i dropped the tank and see no visible way to remove from the tank
It has a lock ring that you have to hit counter clockwise in order to remove it, you must clean around it first so that you don't put stuff into the tank and be careful not to cause a spark, the lock ring looks like an upside down soda bottle cap sort of or if you know what a spanner wrench looks like [[[[ but sideways once the ring is turned the pump will come out.
Jul 02, 2009 | 1998 Chevrolet Blazer
Gas Cap
There is a lock inside there, but it should only be actuated when you've locked your doors. By pushing the lock button on your key fob it locks your doors, rear hatch and your gas cap cover. Once you push the unlock button the lock inside will retract back allowing you to push on the cover. If you do have your doors unlocked, then it could be either the lock is not retracting as it should or the metal clip that the lock contacts with when in the out position may be bent out of shape and still in contact with the lock when the lock is retracted.
Feb 04, 2009 | 2004 Nissan Murano
The best way is to open up a notepad document, and see if the letters you type in are in capital letters. You could also, however, download this free software that will indicate when your num lock, caps lock, and/or scroll lock are on. (this is, if you are running windows)
Jan 09, 2009 | Logitech EX100 967499-0403 Keyboard
Meaning of indicator lights on wireless receiver
I concur 2/3's with yooperbud.
1 = System is connected and working
A = Cap locks On= Cap lock is on. Off = Cap lock is off.
F = Function Key usage. On = I'm going to use the alternative fuctions of the F keys as programmed in the Keyboard settings. Off = Your using the standard features of the F keys.
Dec 31, 2008 | Microsoft Wireless Optical Mouse USB...
Logitech Cordless Desktop EX110 Logo
882 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
