Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
D52w20 RCA Projection wont turn on
My HD t.v. wont turn on. the green light lights up but nothing comes on the screen.  Can anyone help?  We noticed distorted coloring a day before the tv took a dump.
  • RCA Master
  • 5,138 Answers
On the Deflection board CK 3 fuses they will be in a roll on right side of Flyback Transfomer FL231 they look like small rectangler brown caps they are fuses Then Check 3 capacitors cp150 2200uf 16v if puffed up on top it is bad replace cp114 and cp120 220uf 35v.
Posted on Feb 11, 2009
RCA light comes on and then goes off. Tv doesn't turn on
replace CP150 and CP114 you can get them at the following link they also have the ITC222 service manual which is listed under Thomson as Thomson makes your TV for RCA. The Capacitors are listed under the RCA parts and they do send instructions with pictures of where the capacitors are located as well as how to remove the board.
http://servicemanuals.vstore.ca/
May 27, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch rca big screen tv will not come on
Hello All,
This set has the ITC222 chassis which has a problem with bad capacitors CP240, and CP250. In any event check these capacitors to see if they are puffy if they are replace them and this should solve your problem.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA TV Will Not Power On - Powered Off Suddenly
Theses sets had 2 problems pip mod or most of the time Flyback Transfomer bad.
Jul 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear projection hdtv problems
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
Jun 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Does not turn on
when the green light flashes.. this mean the processor in the set is shuting the set down. for some saftey issue. it doesnt want to cause a fire or damage the set further. it can be one of many issues. techninicans have speacial equipment to read the set to determine the errors. this is pretty standard with this set
Dec 17, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA d52w20?
ok ...first question ... what happens when u push menu?...do you get any osd...on screen display...menues volume.. channel number. HOw bout any sounds... the light comes on and the stays on..?
Dec 03, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv won't stay on!
Check C506 = high failure item # 483512247584 680pf / 2kv
Dec 01, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Wont turn on
I saw a reader on another site had same problem (and mine too). He replaced HO Transformer.
Nov 04, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear Projection
the main pwr board is defective and will need replacement...
Oct 18, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
143 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
