Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Dull Why does this TV seem so DULL? I've tried adjusting everything in the settings and it still appears really dull...Is there anything I can do to fix this, or is this model just doomed to being this dull?
  • melanatedone Feb 11, 2009
    DVI option? I have a cable box and the only wire coming out is a coaxial... what do I do, and how do I get it do DVI? RGB Stream? I hooked my game up to it using the HD cables and it is still dull like the coaxial... how to I tune it correctly? I've tried messing with all of the sliders from brightness to sharpness - alast, Nothing.
  • Anonymous Feb 11, 2009
    New tuner? Replaced the lamps? New screen insert? Computers I know... televisions, Zippo! Nadda! What are these things and where can I get them... I have some HALO 3 ODST and HALO Wars to play soon - I need my set spanking clear!
  • 6,784 Answers
This is a common situation with the rear projection build. its a combination of the burn in effect and also, bad tuning. you can get a better picture by using the DVI option. rgb stream can give you a better picture as well. adjusting the sharpness can help sometimes.
Posted on Feb 11, 2009
  • Michael Masters
    Michael Masters Feb 11, 2009
    I have this same set. the dvi option is only available if your cable box can allow it. the rgb/HD stream can be used with the appropriate box as well. most cable companies should ahve these hd recevers upon request. i put a new tuner in my set , which is similar to yours, and it cleared up most of the fog. i also replaced the lamps as well. and finally, i orderd a new screen insert from rca. its like new again.
My Vizio GV42L is fading to a dull whitish color after 2-3 minutes. I can still see the TV program I am on but the screen just goes to a dull whitish color. No boxes or anything popping up. Basical
Either its back light inverter board, or, the LVDS cable has the fault. First try by re-seat the LVDS cable, and check. Thus you can make sure about the fault. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic /Timeslide, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Nov 06, 2013 | Vizio GV42L 42 in. LCD Television
Screen not bright
obvious solution... check the settings.... you've probably done so already though. http://www.tvrepairkits.com/xcart/product.php?productid=24696&cat=3844&page=1 dull repair kit link. love the old rear projection tv's when they work right but they're finicky and monstrous, best of luck with your fix.
Apr 22, 2012 | Philips 51PP9910 51" Rear Projection HDTV
Blues' appear more green
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 05, 2010 | Philips Televison & Video
Dull picture in all situations
in the setting section click on picture and go to color warmth there you can change from cool to mediam and hot
Jun 23, 2009 | Philips 60PW9363 60" Rear Projection...
Dull/blurry picture
Sorry but You Don't.
Imagine taking a small Jpeg photo and blowing it up to Billboard size. It will be pixelized and dull.
Same with HDTV's. You can upconvert and adjust til your eyes turn blue, but you cannot take a Standard Def signal and make it look better by showing it on an HDTV. Some Standard Def material is better than others but ultimately what you see is what you get
Mar 23, 2009 | JVC LT-42X579 42 in. LCD TV
Plasma TV screen dull
yep, do u have a digital multimeter? if so, measure all the voltages from the power board located top middle. if u look at the top right of the panel, there is a sticker with va, ve, vset, vsc settings. ground the black lead, and use the red lead to read each of the settings on the pow bd. if there are more than 2 mismatches, its your power board and needs replaced.
Jan 03, 2009 | Samsung PPM42S3 42 in. Plasma Television
Screen goes dull at times
The dulling picture really sounds like a lamp failing. You would need the sony lamp xl-2100u
The ghost image may be easier to fix, sometimes as lcds age you will get a slight shift in a color. deep in the sony menu there is a parameter (menu-setup-imageshift) that will give you 3 levels of correction, this may solve this issue.
Dec 04, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Dull screen on monitor model no.337n rev 8
restore u r system and new operatin system and click on u r display settings and change u r display settings lolz no pro if still pro occur mail me then
Oct 24, 2008 | Compaq Presario 700 470024-192 Notebook
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
169 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
