Question about Digi 002 Rack FireWire-based Pro Tools LE External Sound System
NO AUDIO CAN'T GET SIGNAL GOING TRHU THE DIGI 002....MIC WORKS O.K AND PHATOM POWER IS ON...CABLE..NEW ...ROUTING DONE AS DIGI GETTING STARED GUIDE SAYS... SO WHATS WRONG...RUNNING PRO TOOLS ON WINDOWS XP SERVICE PACK 2......
  • LPawnell Mar 19, 2009
    I ma having the same problem I think evrything plays through my monitors but in the audio and sounds tab it reads no audio device. I can see the digi 002 in the playback dropdown but not in the reocding device drop down. Is there a fix for this?
  • 4 Answers
Did you solve this problem yet. If not let me kno im looking for a 002 to do some testing plus i need some spare parts.
Posted on Apr 25, 2009
Configuration settings PIN code
Try Hard Reset your Phone
or
Here's a hints on how to repair or fix Nokia 5800 XpressMusic Digi Mic Knopfler problem issues.
A guide picture below which I included an schematic diagram shows each every components and line paths for quick test and check up procedures.
Digi Mic Knopfler Pin configuration:
1. L/R - microphone's left and right audio signals groundings
2. CLK - Audio Clock data
3. Data - Digital Microphone data
4. VDD - Power supply voltage
http://2.bp.blogspot.com/_8JZhVVmpICU/TBnMEY2FYyI/AAAAAAAAAiI/KWb0ERKLIPE/s400/digi+mic+knopfler+schematic.jpg
Locate and trace each and every components, line paths and corresponding connection as shown on a picture. The red highlighted components and line paths is for the power supply voltage which came from Power management IC (AVILMAS) Vsim2- approximately 2-3 volts.
Test and check this components and track the supply voltage from C220 to C2170 then through the digi mic knopfler pin 4.
http://4.bp.blogspot.com/_8JZhVVmpICU/TBnNuXjiK5I/AAAAAAAAAiM/zRyjq5oSGEA/s400/nokia+5800+xpressmusic+digi+mic+knopfler.jpg
The pink highlighted components and line paths is for Audio Clock data signal, which is came from the Audio Codec IC (Avilmas) then flow across R2201 and R2170 (valued 100ohms each) then to the Digi mic knopfler pin number 2. Check also the C2173 valued 22p Clock filter capacitor for possible damaged.
I included step by step procedures on the images like as follows:
* Check each components and line paths.
* Replace if found open or shorted
* Jumper the line paths if found open or cut
* Check or replace the digi mic knopfler for a quickest step might as possible.
http://4.bp.blogspot.com/_8JZhVVmpICU/TBnUknz7xAI/AAAAAAAAAiQ/McXux--YsDc/s320/nokia+5800+xpressmusic+digi+mic+knopfler+repair+gu ides.jpg
The microphone's digital data signals has also a line paths connected to the front side of the Printed circuit board, check and trace also this line paths which is connected to digi mic knopfler's pin 4
Feb 17, 2011 | Nokia 5800 XpressMusic Smartphone
Can i use the 002 rack as a standalone mixer without pro tools running
Unlike some RME products, the 002 rack has no ability to run as a standalone mixer. All routing/mixing is controlled via the pro tools software.
Jan 13, 2011 | Digi 002 Rack FireWire-based Pro Tools LE...
Hi i have digi design rack 002 with pro tools le
Try the other port on the 002. If that doesnt work, I recommend trying the 002 on a computer that does have 400 to see if it will connect then.
If it doesnt, then you may have a couple blown firewire chips inside your 002. It happens, and can be fixed.
Jun 29, 2010 | Digi 002 Rack FireWire-based Pro Tools LE...
How do i clean the dc power? what is that?
I think you're referring to a problem that's known with Digi 002 Rack where the power harness oxidizes and loses power connection over time.
Digi used to send you a new power harness & contact cleaner to make sure that doesn't happen again. You should contact their customer service if you're having an issue with it.
May 27, 2010 | Digi 002 Rack FireWire-based Pro Tools LE...
I want to hook up a an interface to a mackie mixer. What is the common denoinator to hook up, let's say a digi 002 and a mackie mixer so i can have a mac computer with pro tools operational with also the...
you can just piggyback the mixers - take the outputs from the mackie mixer (assuming it is NOT a powered mixer) ... those should be line level outputs - send them into a line level input on the digi 002 and then set that channel on the digi 002 and once set, just leave it, and control the mackie channels individually ... should work fine ...
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.rexark.com
Oct 14, 2009 | Digi 002 Rack FireWire-based Pro Tools LE...
My ProTools LE Digi 002 rack stopped connecting to my IMac.
clean the ribbon cable connection on the dc power harness with contact cleaner. i had the same problem. this fixed it.
Feb 14, 2009 | Digi 002 Rack FireWire-based Pro Tools LE...
Digidesign 002
yes you should be hearing sound but i dont realy know how to help you because i dont have enoughdetail on the cofigeration of the cables. my email is garrett7@mts.net
Sep 12, 2008 | Digidesign MBox 2 External Sound System
Digi 002 Red Light Only fix?
Hey Chadfish,
I had to call Digidesign. They are aware of this very common problem with 002s and will send you a new power harness free of charge. They were really cool about and did not give me the runaround. I got the new harness in about 5 days. Make sure you have your 002 registered before you call.
Aug 05, 2008 | Digi 002 Rack FireWire-based Pro Tools LE...
Digi 002 rack
easy. Your clock got screwed by one of your audio programs in you system. It Happens when sample rates are mixes up. Leave your digi 002 on it does not set itself other than the factory sample rate setting when primarily switched on, which will remember its last setting if mixed up in an attempt to recover. Leave it on turn your system on. Then turn your system off. Not the digi. just your pc, mac. The software utilizing the previously screwed up sample rate will or should be reset. thus resetting your digi 2 to its factory 44. If it does not work check your software settings for any audio software set as default to run when pc is started ans make sure they are set to play back 44. Never turn your pc off when a program using your digi faulters.
Sep 08, 2007 | Digi 002 Rack FireWire-based Pro Tools LE...
Digi002 Rack
Reinstall the driver with the unit dissconnected. Check to make sure your version of OSX is stable with your current version of Protools, especially if youve done any software updates.
Keep me posted.
Aug 30, 2007 | Digi 002 Rack FireWire-based Pro Tools LE...
Digi 002 Rack FireWire-based Pro Tools LE External Sound System Logo
184 people viewed this question
Top Digi Computers & Internet Experts
doggzzz
Level 1 Expert
Alun Cox
Don Hart
Are you a Digi Computer and Internet Expert? Answer questions, earn points and help others
