Question about Sony Playstation 3 (PS3) Console
Error msg cannot start correct harddrive not found
When i turn the console on i get an error msg cannot start correct harddrive not found
  • michael tran Feb 12, 2009
    need to upgrade your PS3 on line
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Was the harddrive swapped out with another one?
  • 42 Answers
Your hard drive has died. You must replace it. Get any size SATA 2.5" notebook hard drive replacement and install it. I have seen this issue plenty of times. Usually on the old 40GB systems.
Posted on Feb 12, 2009
I am having trouble with my computer crashing and before this happens it will clik continuously untile it freezes up. Norton utilities live assistance checked the computer and have not found anything...
Hi Your harddrive has bad indexing unit so this problem arise. For that you need to fix error on harddrive. First open cpu cabinet reconnect RAM memory and both connection to harddrive and power cable and ide or sata cable. Then for fix error on harddrive boot computer with cd/dvd rom then enter in recovery console and type in prompt "chkdsk /r" without "" then press enter then it fix error on harddrive. Then again boot computer with windows disk then choose repair option then if still problem arise then you need to repartitioning the harddrive then format harddrive and install windows then it will work fine. Let me know if you need further assistance. Thanks for using FixYa.
Sep 02, 2010 | HP Pavilion a6110n PC Desktop
Hi, In my dell optiplex 380 desktop showing blue dump error which describes that ecode : 051 msg : 2000-0151 msg: Hard drive-1-incorret stats:3E no addition
Most cases the harddrive is faulty if with code the PSA+ 2000-0151 code means Hard Drive (d): - Incorrect status: (x) (s) etc...Caution:Remove any and all power sources Including but not limited to: AC Adapter, Battery, or Desktop Power Cord, before you remove or reinstall an item in your computer." So Run the Drive Self Test (DST) from the Utility Partition also known as the 32 bit diagnostics to determine if the previous error has been corrected. If the DST from the Utility Partition does not indicate a failure of the drive, we consider the error to have been corrected and the drive does not need to be replaced.
Aug 11, 2010 | Dell OptiPlex 380 MT Desktop Computer...
Iturn on it says cannot start the correct Hard disk was not found
Open up your ps3 on the right site with a small flat screw driver.
Turn out the blue screw with a small cross screw driver, slide the hard drive to the left and pull it to warts of you, note it is a 2'5 inch sata notebook harddrive.
Hook it up to a pc or mac to run a diagnostic check on it to see if it is crashed, by the way you're able to tell by the sound it makes if it crashed.
Aug 28, 2009 | Sony Playstation 3 (PS3) Console
Tv screen is black and says cannot start correct hard disk was not found
your harddrive is bad and you to replace it with a locked ten gb harrdrive
Jul 02, 2009 | Video Game Consoles & Games
XBOX 360 PROBLEM!!!! HELP!!!
Have you tried replacing the hard drive?
Jun 21, 2009 | Microsoft Xbox 360 Console
Red light blinking on front of xbox 360
How many red lights flashed? One, or three?
One means that your harddrive isn't seated correctly.
Three means that your console is more or less screwed, and needs to be repaired by Microsoft.
Apr 10, 2009 | Microsoft Xbox 360 Arcade
When turned on msg says can't start correct hard drive not found
ok I have the best solution for you you need to do the follow in order to solve this problem ok My name is Juan and I am a ps3' proff so don't worry this is fixable in a portable usb card reader install the newer ps3 update go to sony and in your usb created a folder with the name PS3 in capital letters and inside this folder created another folder with the name UPDATE and download the update on this folder once you have the update ready connect the usb storage device to your ps3 turn the ps3 on and press the PS logo on your ps3 control then on the next screen press STAR and SELECT at the same time and the ps3 is going to start looking for the update follow the instactions and then some model on the next screen you have to press again SELECT and START at the same time but this time hold them for 5 seconds and the update will start after the update finish it will start normally if you have problems doing this call me at 706 529-0579 and ask for juan thanks
Mar 11, 2009 | Sony Playstation 3 40GB System Console
No bootable device
Error Code 0141 means no drive detected.
If that's your problem then you should take out the harddrive out and try it on another laptop or buy an external enclosure.
You can get them for $10
If it won't run on another computer that means the harddrive is bad but if it does run then it means you have a serious issue within the laptop componants.
Dec 24, 2008 | Dell Inspiron 6400 Notebook
Error messages
Try removing the jumper from the harddrive, then restart
or
Take the jumper off restart shut down and then put it back on again
or
remove the CMOS battery from system board and boot once after booting shutdown your system and insert the battery back, again start your system and press F1 next time it won't ask you for pressing F1. reset your BIOS after that (time,date,etc.)
Try these one should work.
Please let me know.
Dec 01, 2007 | Computers & Internet
Sony Playstation 3 (PS3) Console Logo
128 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
