Question about Kenmore 62602 Electric Dryer
My Kenmore Dryer turns on and then goes off on it's own
I turn it on and it runs for about 90 seconds, then turns off.  It will not come back on without a significant break, but when it does, it only runs for a short time.
The heating element is working.
Dryer is 12 years old.   Do I buy a new one or try to fix this one?
Brian
  • 11,896 Answers
By the time you purchase a part it would be almost half of what a new one would cost. Check for any clogs that may be in a drain and try playing with the dryer door latch. These things could also cause this problem. But a 12 year old washer could just be a motor wearing out from age.
Posted on Feb 11, 2009
Kenmore Elite HE3 not heating up when vent connected
check outside of house for any obstructions to the outlet. make sure the vent is clean
Jan 02, 2013 | Dryers
Filter light is on. I pull filter - its clean. I put filter back in - filter light goes out. I start dryer. It runs for about 5 seconds and stops
Did anyone come up with a solution to the problem, we are having the same problem, except our dryer keeps running, the filter light goes out, and when the dryer is turn back on the filter light is back on, the filter is clean.
Oct 22, 2010 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore 90 series gas dryer Model# 7691269076912 When I push the start button it whines then nothin. I used wait a few minutes and just start running. now you push the start button, it whines then...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 20, 2010 | Kenmore 77632 Gas Dryer
Kenmore 800 dryer shuts down after running down to 40 minutes on the timer. When I restart it at that point it runs for about 30 seconds and shuts down. If I turn the timer back to 90 minutes it runs down...
Sounds like you may have a bad motor. If the motor is overheating it will shut down on its overload.
If its a shorted contact in the timer you could mark the spot where it stops and restart it again. It should stop exactly at that point.
Jan 22, 2010 | Kenmore Dryers
Hi - My Kenmore top load stacked washer/dryer has a broken timer. The dryer just goes and goes until it's turned off. Can this be fixed?
you can order a replacement timer from either sears or they do sell a universal timer that can be installed by a service tech timer's run from $35-$90 depending on where you buy it
Jan 12, 2010 | Kenmore 80754 Top Load Stacked Washer /...
Dryer doesnt go on
I opened up the lower panel of my kenmore 90 and then removed the blower cover. I found two hair pins lodged in the blower and removed them. I tested the dryer with it open and the blower and drum began to turn again. I buttoned everything back up, and it is running fine now.
Jul 21, 2009 | Kenmore 73952 Gas Dryer
Kenmore dryer buzzes but does not run
You could have any one of several problems with that gas dryer -
Turn dryer on.
Go out to where dryer duct exits house.
Feel the amount and strength of air blast coming from vent.
Air blast should be strong and cover the full face of the vent.
If not, check that dryer hose is not crushed/collapsed behind dryer as it is pushed back into position.
Clear any restrictions in the vent pipe.
Clean lint screen.
Check that there is no restriction where air is pumped into or discharges from the dryer drum on the inside.
If you are able to, check to see if you can see the pilot ignitor lighting.
Reply back your findings for further instruction or information.
Feb 04, 2009 | Kenmore 73932 Gas Dryer
90 series dryer wont start
first check and see did any clohes fall down in the blower wheel,,from fillter no...check the belt that its not jammed,,check your idler wheel ...always unp[lug unit first.....now we will check motor ,turn unit on if you get a humming for about 10 to 15 seconds than a click,,replace motor
Dec 25, 2008 | Kenmore 63942 Dryer
Kenmore 90 series won't start timer ticks
heatman101
Dec 03, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer 90 series model 66901692
heating element is located at the back of the dryer. if you can see a big coil of wires like a long spring laid back and fort to a duct , that is the heating element.
Feb 19, 2008 | Kenmore 62602 Electric Dryer
Kenmore 62602 Electric Dryer Logo
114 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
