Question about Whirlpool GU2400XTP Built-in Dishwasher
Clean light flashes
The problem is that the clean light flashes even when the door is open. When trying to start the washer the start light flashes and it does not start. I tried draining it and that does not work. I have a whirlpool dishwasher Model #DU1055XTPQ0 clean light flashes 7 times and pauses and repeats 7 times, pauses. This is happened before when my children play with dishwasher. I know you can reset the computer by pressing a series of buttons. Which buttons do I press?
  • william dworsky Sep 20, 2013
    worked perfectly,saved me a fortune
  • 188 Answers
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Posted on Feb 20, 2009
  • Aprille Ottmann Nov 02, 2011
    Thank you so much, Ive had this issue or over a year, someone said go online, thanks so much
  • tyndaris2000 Apr 01, 2012
    WOW!!!!!!!! I am now my wife's hero :))))))
    Thank you, thaaaaaaaank youuuuuuuuu :)
GFWH1200DWW GE front load washer won't unlock red lock showing
From an article I found online:
See if manually opening the door will reset everything. Unplug the washer and remove the lower front panel like you're going to clean out the drain catch. Once you remove this panel you can reach up behind the upper front panel and pull down on the small plastic pull tab attached to the bottom of the door lock assembly. This will manually unlock the door so you can open the door.
Now once you have the door open, plug the washer back in and see if you can start another cycle.
Mar 06, 2016 | GE Washing Machines
Bosch Nexxt 100 series washer wfmc1001uc
According to the manual, you have to:
1. Turn program selector to "off"
2. Turn selector to Drain or Spin
3. Press the start / pause
Wait until program ends.
Open door.
or
Press "start / pause" until the start / pause light flashes.
Jan 10, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
I have a front loader washer...it was in the middle of the cycle and starting beeping. The dr (door) signal is flashing. Cloths are wet and i can't get any cycle to go now. Any suggestions?
Unplug your machine.
Open the top of the machine.
Open door
Remove the door lock assembly
Check contacts of the door switch.
Replace if faulty or try to clean with electronics cleaning solvent.
Jun 23, 2010 | Frigidaire Affinity ATF6000F Front Load...
Zj1217 door not opening
you need to clean your pump there is a safety feature in the washer that will not allow it to open if there is water in the machine if you open the pump be sure to have plenty of towels
Dec 26, 2008 | Zanussi ZJ1217 Front Load Washer
Indesit wil 103 door won't open...
Welcome to Fixya.
Try holding the Start/cancel button in for at least 2 seconds.
If there is another lamp flashing at the same time as the door lamp, then you will have to call an engineer.
Dec 18, 2008 | Indesit W 123 Front Load Washer
Whirlpool front loader duet sport washer door will not open
without complete f code hard to pin cause but suspect pump not pumping out remove bottom cover reach up to lock area pull small tab down to unlock door remove as much water as possible remove pump clean out by turning counterclockwise clean pump and connecting hoses reassemble and ck
Nov 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWM8121 ?door open? light flashing and washing machine won't start. I had solved this same problem over a year ago. It seemed to be the door locking solenoid not working. I solved the problem by...
I had the same problem about a year ago, I replaced the door switch but didn't fix it, I found the brushes in the motor has worn out - Replaced the brushes and fixed the problem.
Jul 20, 2008 | Whirlpool AWM6120 Front Load Washer
Whirlpool AWM 8103/S Problem
This happens to me every time i put a load in, try giving the door an extra nudge to close it, just give it a firm push where the handle to open it is. hope that helps!
Oct 07, 2007 | Whirlpool AWM6120 Front Load Washer
FLASHING LIGHT(WHIRLPOOL AWM6120 FRONT LOAD WASHER)
Sep 19, 2007 | Whirlpool AWM6120 Front Load Washer
Whirlpool GU2400XTP Built-in Dishwasher Logo
846 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
