Question about Intel D945GNT Motherboard
Alienware Desktop will not boot
I have a Alienware desktop that will not boot, I have no video displayed. I have replaced the motherboard and I am having the same issue. My motherboard is a Intel D945gnt. When I boot the pc I dont have any error on the display or beeping errors. I have attempted to disconnect my hard drive and dvd rom and only left one stick of memory installed to troubleshoot this issue. But still have not figured this out ?
  • 6 more comments
  • anxioussky Feb 11, 2009
    Thanks for your help. Power supply set to 115v , P4 connector & main connector are both connected to motherboard.
  • Anonymous Feb 11, 2009
    When I remove the Ram I get (3) long beeps but still no display. Please provide me with some general troubleshooting steps, I am at a lost. What else could cause my system not to boot to post ? Intel has already replaced the motherboard for me.
    I have tested with (2) different monitors and have also attempted to use a pci video card , but still I have no display. Keep in mind this is a new motherboard from intel. I have no error beeps ! What could be causing this ? I have disconnected all other device from pc and now I just have one stick on ram connected to motheboard (dvd rom and hd are disconnected) Thanks for you help again.
  • anxioussky Feb 12, 2009
    Read above please .... I have tested with (2) vga cables and monitors
  • mdsavio Feb 26, 2009
    I have the same problem... i do everithing you said but don't boot... for me its death.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Try a different CPU and make sure the pins aren't bent on your CPU that your using now.
  • Ben Wabnick
    Does your power supply have the p4 connector on it plus the main connector that goes to the motherboard? If so maybe try connecting both the main connector and the P4 connector to the motherboard and make sure the power supply is set to 115v and NOT 230V
  • Mandeep  Singh
    Mandeep Singh May 11, 2010
    Have you checked , by connecting another display to the system .
    Proton
  • 50 Answers
Try removing the RAM as well and see if it beeps...
Posted on Feb 11, 2009
  • hornbillexp
    hornbillexp Feb 12, 2009
    When you power on the system without a RAM it should give long and continous beep, in that case your motherboard is most probably ok. Try using another RAM. It should work if everything else is fine with the motherboard.
My Alienware M9700 starts up but turns off before Windows can start
sounds like a thermal shut down maybe heat sink is full of dust under cpu fan or you need fresh thermal paste on processer
Jan 03, 2014 | Alienware PC Systems Alienware Aurora High...
Alienware Area-51 Desktop won't boot up long beep
The fan to the left of your RAM slots needs to spin, it may be the reason for your problem. If this is the CPU fan then you may have a dead CPU.
Contact a computer technician for repair or claim warranty support.
Take care!
damnor01
Sep 21, 2012 | Alienware PC Systems Alienware Area-51®...
Just finished installing an Asus motherboard, AM3 processor, and DDR3 memory in my Alienware tower, kept the hard-drives. Now it goes through post, everything reads ok, but it finishes on a black screen w/...
simple you windows installation cant find the hardware to finish booting up in other words its looking for the old system and cant find it yes you will have to reinstall windows you cannot take a hdd from one motherboard to another windows won't allow it
Apr 02, 2011 | Alienware PC Systems Alienware Area-51®...
I have an Alienware desktop. Up until recently it was running semi smoothly (every couple of days I started it up it would just stay at the windows start up screen and not load). Other than that it was...
By the sounds of it, you are having an issue with the motherboard. I had a similar issue once and this helped:
-Unplug computer from power source
-Hold the power button for 60 seconds
-Open the case and remove the video card and RAM. Then remove the battery from the motherboard (the small disc type battery)
-Put the battery back in, and reseat the RAM and video card.
-Plug it in and start it up
If this doesn't help, you can also try replacing the battery on the motherboard. Of course, if/when you get to desktop, be sure to update all the important drivers (display, video, bios, etc).
Dec 03, 2010 | Alienware PC Systems Alienware Area-51®...
Alienware Area-51 7500 R5 BIOS AHCI problem
I changed mine by hitting F12 at boot screen. that brings up a menu where you can change boot methods
Jul 09, 2010 | Alienware PC Systems Alienware Area-51®...
Alienware Aurora Desktop does not boot, has no HD activity
If the activity light on the front of the tower is not glowing than it can be an issue with the power supply of the PC. Try to open the tower and try to reseat the Power supply cables and check.
You can also try to Reseat the RAM (memory) sticks. If you have 2 Memory stick you can just try to boot the pc with the help of one stick and vice versa. If still the issue persist you can try to do a test on the Motherboard. Simply take out the Memory cards and power on the pc . if you hear a beeping noise than the Motherboard is fine and if you dont hear a beeping noise that it is a faulty Motherboard.
Jul 06, 2010 | Alienware PC Systems Alienware Aurora High...
Display driver stopped responding and successfully recovered
try checking for updated drivers for your hd 5730. i have seen this in desktops with both ati and nvidia gpus.
Jun 21, 2010 | Alienware PC Systems Alienware m15x Gaming...
No display
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
39
Apr 09, 2008 | Intel Motherboard
Foxconn Motherboards Led Boot display
Without more detailed information, I really can't help you decipher that code... Since you don't know which specific Foxconn motherboard you're working with, it might be best if you contact Alienware Customer Support for detailed information:
http://support.alienware.com/Support_Pages/Support_Area.aspx
Good luck; let us know what you learn...
Nov 21, 2007 | Foxconn (865G7MC-ES) Motherboard
Intel D945GNT Motherboard Logo
770 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
