Question about Philips 42PFL3603D 42 in. LCD TV
Lines on tv
Our tv has multiple outlines of each figure on the tv and we cant find the adjustment or settings to fix the problems to get the lines to match up.
  • 124 Answers
Try these:
Contrast: 53 Brightness: 56 Color: 44 Tint: 2 Sharpness: 2
Color temperature: Off
Dynamic contrast: Off
Digital Natural Motion: Off
DNR: Off
Color enhancement: Off
Active control: Off
Posted on Mar 03, 2009
Hi there my tv casually has pink and green lines outlining every object on the screen. I also tried adjusting some setting with a cross section, adjusting red ad blue hues. It looked worse, not only the 3D...
There is a kit available to repair the convergence circuit...this is a convergence problem...I've seen a number of these sets where the convergence IC's go bad over time...this set is about 8 years old and about time for these components to wear out...you can go to tvrepairkits.com where you can get the parts for 65.00
here is the sku# TV-KIT-2013_50UX57B
all you will then need to do is either replace the parts yourself or have someone who knows about electronics and soldering to install the parts. Once the parts are installed you may need to go to the setup menu and reset the convergence(the crosshatch thing you adjusted)...here you are looking to get as perfect of a white line and as straight and uniform as possible
SKU TV-KIT-2013_50UX57B
Jan 20, 2011 | Hitachi 50UX57B 50" Rear Projection...
I have an RCA model #HD61W66 flat screen. This morning when I turned it on it went all 3d like and there was red/green/blue lines at the top of the screen, there was also outlines of the people on the...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 14, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Red and Green and Yellow lines inthe Picture
Is this an LCD TV or and LCD Projection TV.
This sound like a convergence problem that sometimes can be adjusted in the user menu. Definintely can be adjusted in the Service Menu.
May 18, 2009 | Philips Televison & Video
Red bowed horizontal lines
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
May 17, 2009 | Hitachi 43GX01B 43" Rear Projection...
There are green wavy lines that follow the outlines of most
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 30, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Blue outline around images on tv
Sounds like a convergence problem. I can tell you that the site that Jean posted will not fix this problem and could even make things worse. That site pertains to a specific problem that is common in some Sony sets and should not be used to try to fix any other issue.
Please keep in mind many things can go wrong with TV sets and you should really do a lot of research before attempting any adjustment and or repair. There are high voltages present and they can reside even when the set is unplugged.
Jan 29, 2009 | Televison & Video
Red outlines in the picture
somewhere in the tv menu there is a place to make video adjustments. one should be for aligning the color guns. one is for red and the other two are green and blue. it will give you a cross in the center of the screen. it should also give you prompts to adjust the lines for centering and to save changes. this happens eventually on all rear projection tv sets.
May 02, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Sony kp-43ht20 geometry issue.
You may be setting your self up for a major headache. Trying to set convergence requires a professional pattern generator. There are also multiple phase adjustments to prevent linear drift of settings. Please spare yourself, take unit to a professional service!
Nov 21, 2007 | Sony KP-57WS520 57" Rear Projection...
Samsung HCM5525W TV red blue outlines on images
The Samsung has bad convergence IC's most likly. This should be repair ONLY by a trained technician as a TV set is not a place to experiment or tinker with because of the extremly high voltage inside. This repair should cost you in the range of 250 to 400 bucks . Good Luck
Jul 31, 2006 | Samsung HCM5525W 55" Rear Projection...
Philips 42PFL3603D 42 in. LCD TV Logo
179 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
