Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
PDW7880J10SS: No water
No water in the dishwasher. How do I find the problem?
  • 10,865 Answers
First check to be sure that the valve that controls water coming from the hot water supply is turned on. This may be right under the kitchen sink. If it is turned off, just turn it back on and u should be set.
However, if you have water coming to the dishwasher but no water in the dishwasher it has to be one of two items:
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Posted on Feb 11, 2009
Wan't take on water after first rinse
see this steps and fix it. God bless you
Water Inlet Valve
The dishwasher has an electrical water valve called a water inlet valve. If the dishwasher won't fill with water, the water inlet valve might be defective. These valves are not repairable and will have to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Float
The float assembly is normally inside the dishwasher near the door on the floor of the dishwasher. If something gets stuck underneath it and holds the float assembly up, the dishwasher won't fill with water. If the float assembly moves freely up and down, the float switch might be defective.
Float Switch
The float switch is actuated by the float assembly. It is a protection device designed to prevent the dishwasher from overfilling. If the dishwasher won't fill with water, it may be because this float switch is defective or stuck.
Water Supply Problem
The dishwasher is connected to the hot water supply from the house. Check to be sure the household water supply valve is turned on. Over time, calcium deposits can build up in the water supply valve or in the small filter screen inside the water inlet valve. The water supply line may need to be removed from the water inlet valve of the dishwasher, then run some water into a bucket to see if there is enough pressure. Be certain to turn off the water before working on the water line.
Jul 30, 2013 | Whirlpool 24 in. DU1055XTPS Stainless...
I NEED MY INSTRUCTIONS MANUAL
Hello, I do offer a manual/instructions locating service such as this one that I provide and locate your manual for you click here for an example http://www.fixya.com/marketplace/prothreadpage.aspx?objtype=1&objid=10893554
if you have any questions message me back
Thanks
Rick
Dec 02, 2011 | Dishwashers
GE Profile mod. # PDW7880J10SS not cleaning, leaves film
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Nov 04, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
I have a GE dishwasher, nodel #pdw7880j10ss; water sits in the base of the unit & will not pump any every cycle. Can you also advise where I can get a dissabling manual?
Log on to www.appliancedigest.com. Sign in for free registration. Go to the Dishwasher section to find the service manual for your dishwasher.
Aug 27, 2011 | Dishwashers
My dishwasher is not heating the water up just running cold
Try turning on the faucet by the dishwasher and let the water run until it gets hot. Once this is done turn on the dishwasher and see if the water is warm or hot. Most dishwashers do not heat the water (residential dishwasher) they take the hot water from the hot water side of the sink. If the water heater is located a distance from the dishwasher then the cold water fills the dishwasher before the hot water can make it to the unit. This should cure your problem.
Hope this helped
Dave
Jan 15, 2010 | Dishwashers
Dishwasher wont fill with water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Sep 11, 2009 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Asko dishwasher d3530. The water in the dishwasher is not hot.
Generally speaking, dishwashers don't heat cold water on their own. Be sure the dishwasher is connected to a hot water supply and that hot water is available to the dishwasher at the START of the cycle.
Often it takes hot water several seconds for house plumbing to deliver hot water to an outlet. If the dishwasher is connected to the kitchen hot water supply, run the water in the sink until the water runs hot before you start the dishwasher.
Dishwashers often have heaters to heat the water even hotter than most home water heaters, but they are not intended to heat cool or cold water. You MUST furnish hot water to the dishwasher from the time the cycle is started.
I've seen houses that take so long for hot water to reach a faucet, the dishwasher is already full (of cold water) before the first drop of hot water reaches it.
Good luck. Hope this helps.
Sep 11, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
Dishwasher wont take water
Jun 12, 2009 | Kenmore 24 in. 15252 / 15254 / 15259...
Rotating arms getting clogged very frequently
I do not have a huge amount of information about the GE Profile PWD7880 handy, so I don't know if it has a chopper blade/food disposer at the bottom of your Dishwasher, but when a dishwasher gets the holes of the spray arm, the most common cause is the chopper blade is jammed/blocked. Then the food debris never gets sliced and diced at the end of the of each wash cycle.
Opening up the filter under the spray arm, removing as much of the lower assembly and inspecting every where in the sump area, especially the drain pump area would be a great beginning.
Good Luck! Just ask if you have more questions.
Apr 04, 2009 | GE 24 in. Profile PDW7800 Built-in...
Ge pdw7880j10ss dishwasher lower roller fell off and melted on lower heating element. need to know part number of lower roller and plastic clip that affixes the lower roller to lower rack?
(http://www.geappliances.com/service_and_support/parts/)
the correct # for your unit is pdw7880n10ss
just enter your model #(under repair or replacment parts)the site will walk you thru the rest.when you get to the parts list make sure you use the diagram to match your part exactly(click the red box at top of page)hope this helps.thanx for using fix-ya!!!
Nov 29, 2008 | GE 24 in. Profile PDW7800 Built-in...
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
249 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
