Question about Dell W4201C 42 in. Plasma HDTV
Dell w4201chd 42" Plasma Tv.
I am having the typical problem with this model as most people. I understand that there are 2 power supplies on this which are the main power supply and the sub power supply. I am curious as to where the sub power supply is located on these? My power LED lights up but I have no picture or sound. If you have a solution on how to fix this Please let me know. I am electronically inclined.
  • 3 more comments
  • wags7879 Feb 28, 2009
    I am having the same problem but with my Dell w5001c TV. It looks like these almost use the same parts.
    Kenz, I have mine open and a digital voltmeter. Could you walk me through to find the problem.
    Thanks
  • adam3k Mar 15, 2009
    I have the same problem with my Dell plasma 4201C. I opened it. and I hear a sound in the upper midle board. Then the TV goes completely black as if it were off. Do you think you can help me more? I got a volimeter ready
  • ValiPA Mar 17, 2009
    my dell plasma w4201chd 42 tv wont come on its on but no sound or picture
    this TV really " sucks" Still paying 4 it too
  • covermyer Apr 05, 2009
    I have a 42" dell plasma. When i turn it on the blue light turns on but no picture or sound. I have tried to find a power supply to purchase with no luck . Any advice? The tv is 2.3 years old
I have a 42" dell with the samsung power board pspf651b01a and i did a voltage check at all points and the VA should have 55-75 volts and there is 9 volts also the VE check point should have 105-135 volts and it has 83 volts can you tell me what part to replace please.
Posted on Apr 12, 2011
  • tinners02 Apr 12, 2011
    There is no picture or sound but the blue light comes on and the board clicks.
OK, you need to replace the Power Supply Board.It is made by Samsung the number on the board will be LJ44-00110A. The Replacement number is LJ44-00019A,the cost is $349.00,however this part also crosses to a Phillips number 99500042146 which sells for $289.00 these are all the same board.I use the Phillips Board.Most repair shops will not do any research to locate these boards due to time and volume of repairs the have to deal with.Most call Dell and they won't give out repair info.They require it to be sent in.The Phillips board can be purchased from any NAP distributor.
Posted on Apr 24, 2009
  • cbenjamin1 May 06, 2009
    The philips part number was incorrect.It should have been 99650004216.Can be purchased from mcmelectronics.com.
  • To io Apr 19, 2011
    Will it b worth fixin
    New Friend:
  • 90 Answers
There is only 1 power supply located in the top middle connected to the panel. the unit needs to be opened up. A digital voltmeter is also needed. when u get it apart, contact me for further instruction. I can help u pinpoint the problem to the exact malfunctioning board(s). keep in touch
Posted on Feb 28, 2009
Dale 42 inch plasma TV model number w4201chd
Take it back to the place you bought it from they will most likely fix it if you have a warranty. Thats your only choice if you want it fixed unless if you wanna pay a hundred bucks to get a 3rd party lcd put in it haha.
Jun 19, 2013 | Televison & Video
About 2 weeks ago my dell 42" plasma started
this problem is from power supply section, check your power supply, change it with new one
Jan 16, 2011 | Dell W4201C 42 in. Plasma HDTV
If I turn on my DELL W4201CHD, the button lights up, but no picture or sound.......can you help?
check the cable power??i think the problem is from power supply section, the symple way to fix it is contack service center
Dec 02, 2010 | Dell W4201C 42 in. Plasma HDTV
I have an option to get the Dell W4201CHD Plasma tv for $100. However, They say that it will not power up. Does any one know how to go about fixing it or the price range it would cost to get it fixed at...
If the tv doesn't power up then the fault is big. Even if it's only in the power source if you don't have a  god experience in electronics it will cost you over $250 to call a repairman to fix it for you.
This was sold for parts, it's not for you.
Sep 07, 2010 | Dell W4201C 42 in. Plasma HDTV
My 42" plasma tv screen went black but there is still audo
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 27, 2009 | Dell W4201C 42 in. Plasma HDTV
Dead, no power
It sounds like ze power supply blew when it was being turned off. This seems to be typical of plasmas. Bad power supplys wont let the tv come on and will result in no lights coming on. Since there R no lights coming on, I would suspect the power supply first, followed by the power control board,. and circuit board. It may cost anywhere from $250 to $500 to fix.
May 14, 2009 | NEC PXT-42SX1B 42 in. Plasma TV
204451972 Vizio 42" Widescreen Plasma no picture
Check for swollen Capacitors on the power supply. This is normal on older units. You know the caps are bad if they are even slightly raised. These are easy to solder on and off. Match up the Cap with either form a electric supply store or EBAy
Dec 02, 2017 | Televison & Video
Is Dell W4200HD Y-Main board and Dell W4201C HD Y-Main board compatible
The port locations do not seem to line up the same so I'm pretty sure they are not interchangeable
http://support.dell.com/support/edocs/systems/w4201c/om/OM.pdf
http://support.dell.com/support/edocs/systems/W4200/W4200UG.pdf
It can be worked on by a local TV repair, then TV was made for Dell by Philips
Jun 12, 2008 | Dell W4201C 42 in. Plasma HDTV
Help
The Power Supply Board is listed below. Please note, there are 2 models with the same beginning number (PDP4294). Verify your model number before selecting the Power Supply Board as each board is different depending on the model number.
For PDP4294LV use:
Akai PDP4294LV Power Supply Board Replacement
For PDP4294LV1 use:
Akai PDP4294LV1 Power Supply Board Replacement
Apr 01, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Dell W4201C 42 in. Plasma HDTV Logo
2,612 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
