Question about HP Compaq Presario v3000z Notebook
My lcd screen is not displaying anything as if the power is off even though it's on
  • 218 Answers
This is a known problem with your model. Read up at the following link and then call HP at the number listed in the article. You should be able to get it repaired free under the enhanced warranty. Good luck!
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01087277#c01087277_identify
Posted on Feb 11, 2009
Screen bis Blank
1) Try an external monitor to see if it displays anything. If it does, the backlight in your LCD screen died. You will need to replace the LCD screen.
2) If it doesn't display on the external monitor, then the motherboard is bad.
Jan 10, 2014 | Sahara AL-096 Laptop
Zg5 has blank screen even though power light is on. Computer was working fine and after turning it off if refuses to display anything but blank screen. Battery was removed for a short while then replaced...
Welcome to FixYa!
It seems that you are having problem with the LCD or the display on the laptop, you just said that its tyrning on but there is no display appearing on the screen. This may cause by an electrical charge in the motherboard itself,Im not really sure how it affects the display of the computer.There's also a possibility that the problem is with the LCD cable or the LCD itself. Please follow this method since it usually fix such problem like that,
1.Removed the battery then unplugged the AC adapter
2.Press and hold the power button or the ON/OFF button for at least 30 seconds
3.Connect the power supply back to your computer then turn it back on.
4. Check if you will see any difference.
5. If nothing happens, try to press and hold Fn and F2 on the keyboard.
If nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
Hope this information will help. Thank you for using FixYa!
May 17, 2011 | Acer Aspire One PC Notebook
I banged my cell phone against the wall
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-5 or 6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
May 13, 2010 | Nokia 6120 classic Cellular Phone
Spectre x7, at startup, screen blinks on and off. blue light at bottom also goes on and off
leos343872, Black screen type of failure. Is anything still displayed even though screen is black when you hold flashlight 1 inch from lower left corner near start button??? Possible "switch-mode-power-supply" in shutdown mode. Tech or you will need to evaluate further!! Read more of my advice to other owners with BLACK screen monitor problems in my profile. or louie12fix profile. 12fixlouie
Dec 14, 2009 | Sceptre X7G-Naga 17" LCD Monitor
DV8309 power up problem: blue lights on for few seconds then off
The inverter inside the lcd panel is most likely your problem. Try removing the whole lcd screen from the laptop if you are capable and run it with the external screen to confirm. leave the lcd switch off (this lcd switch above the power button turns the lcd inverter on and off)
Jun 19, 2009 | HP Computers & Internet
LCD screen does not display
you can easily find out if the lcd screen is bad by hooking up a vga monitor to the laptop. If it works then you need a new lcd screen you can get them from http://www.pricewatch.com
if other monitor hooked up is same then you need to replace video adapter.
Mark
Apr 28, 2009 | Toshiba Satellite L45-S7409 Notebook
SCREEN SUDDENLY WENT DIM
One of 2 things happened....
1) You Blew the Power Inverter... The Power inverter is a thin rectangular circuit board that plugs into the display panel cable and also powers the LCD Bulb.. If This Part Fails - You Lose Light to the Display even though the display will still be on and viewable against a bright light....
2) The LCD Bulb is Faulty... When the LCD Bulb Fails it will typically give pre-warning signs- though not always.... It will give signs like the whole screen has a light orange or pinkish tone to it, but eventually it will blow and no light at all to the Display Panel....
Both Of These Are Repairable....
The Power Inverter Can Be Purchased Off of Ebay, For Around $15 to $30
The LCD Bulb Itself is also Replaceable.. Though It is a Job Only to Be Performed By An Experienced Laptop Tech... Bulbs as well can be bought off of ebay for a few bucks..
Feb 13, 2009 | IBM ThinkPad T30 Notebook
Laptop doesnt display anything
if there is no display whn u press the start button then your motherboard is screwed. i had this problem with mine too. I got it replaced fro free as it had a warranty... anthing more contact babu_aero@yahoo.com
Jul 20, 2008 | Toshiba Satellite A135-S4527 Notebook
Laptop lcd display
sounds like your screen went out, if you need to access whats on your laptop real soon try hooking it up to a desktop monitor via rgb cavble.
Dec 13, 2007 | Computers & Internet
HP Compaq Presario v3000z Notebook Logo
101 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
