Question about HP OfficeJet 6110xi All-In-One Thermal Printer
It won't print
I replaced the black ink cartridge, as I usually do, but now the printer will not print. I know the power is on, the screen reads "printing" but there is nothing happening, no sounds of even trying.
I called a friend who did not charge me.
Works perfectly now.
Posted on Feb 11, 2009
Large ink spill. Printer no longer recognized new black cartridge.
You can perform the Tap 41 Cartridge Health Diagnostics Test: [applies to HP Deskjet 6800/6900/9800]
http://inkjet411.com/?page_id=1741 (refer to 2nd video to understand how to read the printed pattern)
1. With printer power on, press and hold the POWER button.
2. Press the Cancel (X) button four (4) times.
3. Press the RESUME button (Down Arrow) once.
4. Release the POWER button.
5. The Diagnostic Test Report should print.
--- A good HP 93/95/97/99 color cartridge should display 600 good nozzles, while a good HP 92/94/96/98 black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout: http://inkjet411.com/?page_id=1741
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink (special "ink back-up mode").
For information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Aug 27, 2013 | HP Deskjet 6988 Inkjet Printer - Color -...
Quicken 2008 won't print anything in reports in black
You need to replace the Black cartridge, as it appears the colour one is fine. Look in the printer options on your PC for a display of ink levels, and you'll probably find the black down to zero. If you've used generic cartridges, not genuine HP, you may find the printer can't actually read the ink levels.
Feb 06, 2013 | HP Photosmart D7260 Printer
I have a Lexmark Pinnacle Pro 901 printer and its set up to print using black ink only, but it keeps telling to replace color cartridges and it won't let me print at all, how do I print using blac
The printer would need all cartridges to have sufficient ink levels to continue printing - that's to prevent damaging the printhead. Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
To save on your ink investment, try printing in draft mode and by making sure that your printing preferences is set to print using black ink only.
Oct 25, 2012 | Lexmark Pinnacle Pro901 All-in-one Inkjet...
My Pinnacle Pro 901 is set to print using black ink only but it keeps telling me I need to replace color cartridges and won't print.
You won't be able to print if one of the cartridges is out of ink. The printer needs all cartridges with sufficient ink levels to prevent damaging the printhead.
Oct 25, 2012 | Lexmark Pinnacle Pro 901 All-In-One Inkjet...
The printer won't print. It says replace the color ink cartridge. All I want to do is print black and white.
You can only use the black ink cartridge without the color ink. But no need to replace them in your printer.
When you print just choose black and white for the printed text must be black not colored. But if you still received such notification...just try to replace the color ink cartridge to continue printing
Note: As per my experience. printer with exclusive black ink alone will damage the printer easily due to unbalance printing of ink
Sep 20, 2011 | HP OfficeJet 6210 All-In-One InkJet...
The black print won't print, but colour does, although very lightly. I have refilled the ink cartridges at Island Inkjet, so there is ink,..but black won't print at all.
your black ink cartridge got bad sprayer nozzles now you gotta replace it
and why the other color one is not bad yet cus printer as will known will depend on black ink far more so the black cartridge is heated up more times
May 27, 2011 | Canon PIXMA MP610 InkJet Printer
Just need to know how to put in black ink in the z1300
Follow these steps on how to install the cartridge: 1. Make sure the printer is on. 2. Lift the access cover. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. 3. Press down on the left cartridge carrier lever to raise the cartridge carrier lid. 4. Remove the used print cartridge(if you are replacing). Insert the new black cartridge in the left carrier. 5. Snap the lid closed.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridge.
4. Load the new black cartridge. Close the cover.
5. Plug the printer back to the power source.
Apr 29, 2011 | Lexmark Z1300 InkJet Photo Printer
I only want to print black color but was asked to replace color inks.
Unfortunatly, because its a color ink jet machine you will need to replace the ink to print anything. The way its designed is that it has one printer head for all four cartridges.
When you replace the color ink you will deffinetly be able to print.
Apr 02, 2010 | Brother DCP 115C All-In-One InkJet Printer
Ink replaced, but sows nothing
A yellow exclamation mark in any application means the attatched item to it is usually in error state, but you say the printer works fine. Most people would tell you to not touch what is working!!! But leaving anything showing error risks further confusion and problems. I think that you problem is probably very simple. Do you know hao to reset your ink levels. Read your manual that came with disk or go to the onscreen help. You may find this will remove the issue. If it does not, then you may have a corrupted driver etc, and may need to uninstall the printer, and reinstall it again. Good luck.
Aug 30, 2007 | HP Photosmart C3180 All-In-One InkJet...
HP OfficeJet 6110xi All-In-One Thermal Printer Logo
44 people viewed this question
Ben Johnson
