Canon Pixma iP90 suddenly will not print off the internet, does not show on Printer/Faxes in control panel, cannot add printer at this point, does show and print offline from Word????? I am doing research online of which I would like to print more. Thanks
  • 3 more comments
  • jldshasta Feb 11, 2009
    I disconnected the printer completely, reinstalled the printer software from its CD, connected and tried the printer again with the same results. It states in the dialogue box with the yellow exclamation point "An error occurred during this operationi." and there is a button to push labeled OK.
    Nope, looked carefully at the connections and redid them. Still does not print. Did you note that the printer does not show under printer/faxes in the control panel either, yet it does when printing a Word document?
    The "Add printer" in the control panel will not respond at all.
    I did this already with no response. I am using Windows XP
  • jldshasta Feb 12, 2009
    After following all the good suggestions, I have uninstalled the printer software and tried to reinstall. There is an error now in trying to install the driver and in recognizing the connection to the printer, soooo it may be that I need a new printer???
    President:
  • 2,559 Answers
You need to use an uninstaller to remove all related files,Then reinstall from disk,Then plug printer back in.Follow these steps.
Download and install Revo uninstaller
Once installer,run the program,When the window opens with all installed programs,double click the canon programs(you will only be able to remove them one at a time)Click yes on the "are you sure" box,select advanced,click next,on the next window,click next,when the window open with a list of files,click select all,click delete,click next,select all,delete again,click finish
Note:if the canon uninstaller pops up just select yes to uninstall and continue with revo
continue until all canon programs have been removed,restart computer then reinstall software.
Posted on Feb 11, 2009
    Master:
  • 416 Answers
I can not give explanation in words it takes long time
This is how to set printer from offline to online. I assume you have Vista. If you have XP everything is the same.
1. Click [Start] ( Canon Pixma iP90 suddenly will - g0010944.gif) > [Control Panel] > [Hardware and Sound], and then click [Printer].
2. The following screen appears to confiCanon Pixma iP90 suddenly will - g0013125.gif"http://i.fixya.net/uploads/images/g0013125.gif" alt="g0013125.gif" class="h_mi" /> the priCanon Pixma iP90 suddenly will - g0023084.gifof your printer.
* If the [Printer] is offline, it shows ( ) [Offline]. * If the [Printer] is online, it shows ( ) [Ready].
3. If the [Printer] is ofCanon Pixma iP90 suddenly will - g0013125.gifet it to online.
Right-click on . Click [Use Printer Online].
4. The following screen appears.
The display for g0013125.gif changes to [Ready] and the printer is set to online Good Luck
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, try:
  • verify that spoolsv.exe is running in Task Manager;
  • disable Power Management of USB hubs;
  • if and when the printer shows in Printers/Faxes, right click and click on "online";
  • when installing, make sure that the antivirus is temporarily disabled and that you are logged in with administrative rights/privileges.
Good luck and thank you for using FixYa.
    Sergeant:
  • 250 Answers
If u want to print from internrt with your canon printer.u will have to install easy web print driversfor that.u can download drivers from link below to print from internet:
http://canon.driversdown.com/Canon-drivers-download/Canon-iP90-Printer-Easy-WebPrint-Ver.2.6.4-for-Windows-XP-2000-Me-98_3654.shtml
rate the solution if it helps you solve your problem,thanks.
  • 2,404 Answers
I think you might have a problem with spyware or possibly a virus. Try running your virus program and see if it detects anything and if does then have it either quarantine it or remove it. Then after that, uninstall and reinstall the software.
  • 11,896 Answers
Did you by chance to to add hardware and try troubleshooting that way?
  • Nate Stansfield
    Nate Stansfield Feb 26, 2009
    A USB printer is initially installed with the printer off and disconnected from the computer - plugging in the cable and installing the driver will not work. Wait until the install program prompts you to connect the printer and turn on the computer.
  • 2,071 Answers
Just reveiw all the connection and unplug the usb connection and check it out the usb socket for misalignment or blockage and if its fine put it back tightly .Maybe there is something you miss.
Hope it may helps;
Regards;
VOTIT
  • 6,784 Answers
I would unplug this unit for 5 mins and, reinstall the software pack that come with it. this will fix this issue.
  • Michael Masters
    Michael Masters Feb 11, 2009
    if your using vista, you may have to update its driver base as well.
  • Michael Masters
    ok, this non responsive situation is unfortunately a virus attack. this explains the issues you are experiencing. i would run a virus scan quickly.
E 17, will not print
1st, are all the drivers installed? If not install drivers. 2nd If drivers are installed, look for updates. 3rd try removing all drivers installed and re-install. 4th is your printer showing in the control panel icon? If not click add printer. 5th is there ink in the printer. All the above can be done from the control panel. Click start, click control panel click printers and faxes. Some more info would be nice.
Oct 28, 2013 | Canon PIXMA MG2120,INKJET PHOTO ALL IN ONE
Hi. there is an alignment problem with my canon pixma ip90 printer. I haven't used it for years and finally decided to take it out. changed the ink cartridges, and the alignment problem started. Please...
Go to Control panel. Click on Printer and Faxes. Right click on your printer icon. Click on Properties on the drop don menu. In the properties click on Maintenance Tab. Click on print-head alignment on the drop down menu/tab. Check the printed page after the alignment is completed. If not OK carry it on again till you get the right print.
Aug 20, 2011 | Canon PIXMA iP90 InkJet Printer
Is there a way I can print wireless from my laptop through the desktop attached to the Canon Pixma MX310 printer?
Yes.
The desktop and laptop both need to be attached to the same network.
On your desktop:
Go to Control Panel, Printers and Faxes
Right click on your printer, and click on "Sharing"
Share the printer on your network
On your laptop:
"Add Printer"
Choose a "Network attached Printer"
Browse for the printer, and add in.
Microsoft page:
http://www.microsoft.com/windowsxp/using/networking/expert/honeycutt_july2.mspx
Picture guide:
http://hubpages.com/hub/Share-Your-Printer-over-a-Home-Network-LAN-with-Windows-XP
Jan 12, 2011 | Canon PIXMA MX310 All-In-One Printer
Would not print, oraqnge light blinks 5 times then one green flash. Open the door to ink and the head does not move to center as it used to.
This is a waste ink code and needs to be reset. follow instructions below.
Canon pixma iP90 released almost at the same time with canon Pixma iP 1880. Canon iP90 is printer with single function. Cartidges which used in canon Pixma iP90 is BCI-15BK, BCI-115C dan BCI-16C. Resetting procedure canon iP90 almost the same as manual reset canon iP1880. You can use combination of button in the printer to reset the printer.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off .
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indocator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
Please rate my help++++Thanks for using FIXYA
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Nov 24, 2009 | Canon PIXMA iP90 Mobile Printer
CANNON IP 90 PRINTER PROB: ink try full. how do i clean it? i saw instructions on resetting codes. it will not print at all...HELP...Thank You!
How to Reset The Canon Pixma iP90 PrinterHere is the reset procedure for the Canon iP90 printer, which uses the BCI-15BK, BCI-115C and BCI-16C cartridges.
Just follow these step by step instructions, to reset the Canon Pixma iP90 printer
  1. Turn printer OFF.
  2. Press the RESUME button together with the POWER on button.
  3. While pressing POWER on button, RELEASE the RESUME button.
  4. Press RESUME button TWICE then release both buttons.
  5. The green LED indicator will start blinking, then stop.
  6. Wait until the Power LED lights are green, then press the RESUME button 4 times.
  7. Now press POWER button OFF.
  8. Turn printer ON again, your Canon iP90 printer should now respond normally.
  9. If you need to unclog your print head click on next line
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros Magic Inkjet Flush Kits (Ebay)
Sep 12, 2009 | Canon PIXMA iP90 Mobile Printer
IP90 Canon Printer shows error code 5100: How do I fix it?
This means there is something jamming the mechanism. You should take it to a repair specialist or do your best to check for blockages yourself. It can be the tinest little thing. Check everywhere!
Sep 01, 2009 | Canon PIXMA iP90 Mobile Printer
Canon Pixma MP190 all-in-one will copy offline and scan online however, when attempting to print online, status shows as 'error-printing'. have checked cables & power, cannot print from print command....
this sounds like a virus any ways, make sure u have a very good antivirus, remove and reinstall the printer with the driver but first go to the printer delete all the printers installed manually i.e after uninstalling the printer and its still showing the printer at printer and faxes, then reinstall it.
Jul 22, 2009 | Canon PIXMA MP190 All-In-One InkJet...
My Canon Pixma IP90 will not print. It pushes the paper
you going to take printer in for repair.or get a new one
Jul 18, 2009 | Canon PIXMA iP90 InkJet Printer
Canon iP90 only prints blank pages
Remove the printer from control panel, under installed printers, then unplug the usb cable and reinstall the printer drivers using printer cd, or download from canon support website.
Apr 27, 2009 | Canon PIXMA iP90 InkJet Printer
Error 5C00 on Canon iP90
i took out both printer cartriges then put them back in. there was a window that asks if you replaced the cartriges; click yes then click on the black and color boxes indicating you replaced (re-inserted) both cartriges. for me the light stopped blinking (previously, it was blinking orange 4 times). next i tried to print but only yellow and black appeared. i then cleaned the head 2 times.
to clean:
-go to control panel
-click on printers
-click on printers and faxes
-find your printer, right click on it
-click properties
-find the maintenance tab
-click cleaning
(clean a couple of times if needed)
hopefully it works...
Jan 28, 2008 | Canon PIXMA iP90 Mobile Printer
22 people viewed this question
jasbo
jasbo
