Question about Kenmore 19110 Computerized Sewing Machine
Need online manual
The thread bunches up under the fabric on the bobbin side , makes a huge tangled mess and bogs the machine.
Several layers of fabric and heavy duty needle.
Misplaced my manual
Tension?
The shuttle or bobbin not installed correctly?
I have the same problem! I'm about to bring it in for service, so if anyone has the answer... let me know!
Kenmore 19110
  • 10,865 Answers
Fashion Mate 248. The top stitch is fine but will gather too much under the material. Wraps around the bobbin holder and tangle up into the bobbin thread. Does anybody know whats going on?
That is what is referred to as bird nesting or thread nesting. It usually results from mis-threading, the thread not being fully seated in the tension disk, or the tension set too loose. (I have a machine that does this frequently because the thread "jumps" out of the take up lever when sewing fast--instant thread mess.)
Remove the thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. Make sure the thread path is correct. Set the upper tension to the midway point between high & low number. (You will probably need to tweak the upper tension because every machine differs over time, but the midway point is the factory standard setting.)
While you are at it, check to make sure the bobbin is loaded and threaded correctly in the bobbin case.
If you continue to have issues, you may need to take it for service.
Sewing Machine Thread Bunching Up Here Why
What causes Bird Nests Superior Threads
Birds nest under the fabric big loops of thread top side looks good...
Dec 10, 2016 | Sewing Machines
How can I prevent bobbin thread from bunching up and tangling?
First thing to do: install a brand new needle and clean the lint/dust from the feed dogs and bobbin area. Make sure you are using the right needle and thread for the fabric being sewn.
All About Needles
Second thing: remove all the thread from the machine. RAISE the presser foot and rethread from the beginning making sure that it is threaded correctly through every thread guide (consult the owner's manual). And verify that the bobbin is loaded and threaded in the bobbincase properly.
AVOID using old, fuzzy, and bargain bin threads.
Set the upper tension to the midway point between the high & low number (this is the factory standard although every machine may slightly differ). Now perform a new stitch test.
If the upper thread is creating a thread mess under the fabric, the upper tension is too loose. Tighten it.
If the bobbin thread is coming up to the top of the fabric, loosen the upper thread and retest. Sometimes the upper thread tension is not enough to prevent the bobbin thread from coming up. In that case, the bobbin tension may need to be tightened. (Search the internet for instructions for adjusting the bobbin tension. NOTE: bobbin tension adjustments should be done in micro-increments as a small adjustment will make a big difference in the result. Be sure to test after each adjustment.)
The tension is correct when the upper thread and bobbin thread meet and cross in the middle of the fabric. This will change whenever fabric, needle & thread are changed, so a sewist needs to be comfortable with regularly making upper thread adjustments.
One other thing to try is pull the bobbin thread up through the fabric before stitching and gently holding the thread tails when taking the first couple of stitches.
https://www.youtube.com/watch?v=caPzulMMlMU
Jan 25, 2016 | Sewing Machines
Have a Singer 11910000A and the bobber thread bunches up and makes a mess in the feet when sewing
Is it really the bobbin thread that is globbing? Check closely. Usually it is the upper thread accumulating under the fabric.
If it is in fact the bobbin thread, then the bobbin case is not threaded correctly, the bobbin case tension needs adjustment, or it is broken and needs replacement. There are web sites and YouTube videos that show how to adjust the bobbin case tension.
QUICK FIXES: Remove all the thread from the machine. Clean the area around the feed dogs and bobbin area. Oil as instructed in the owner's manual using ONLY fresh, good quality sewing machine oil (only 1-2 drops each spot). Install a brand new needle insuring it is installed correctly. Avoid using fuzzy, old, or bargain bin thread. Rethread: Be sure you raise the presser foot BEFORE threading the upper thread so it will seat properly in the tension disk--and check to make sure you are threading the machine correctly. Check that the upper tension is set properly (the factory standard is usually the halfway point between the high & low number on the selection). Test on a scrap of the fabric you wish to sew. Adjust the upper tension--either tighten to pull the upper thread toward the top of the fabric, or loosen to pull more upper thread down.
Here are some web sites that may help.
sewing machine birdnesting
https://answers.yahoo.com/question/index?qid=20100303212248AAnRUQA
8 Tips to Fix Birdnesting in Embroidery
http://www.marthastewart.com/1085057/common-sewing-machine-repair-tips
and here's another Hint that may be helpful:
https://www.youtube.com/watch?v=KDERq4I7l-Q
Dec 29, 2015 | Singer Sewing Machines
I am having trouble getting the bobbin to function properly during sewing.
It could be the top thread is the problem. Might try removing all the thread. Consult the owner's manual for threading instructions. RAISE the presser foot BEFORE threading the upper thread so the thread will seat properly in the tension disk. Re-thread from the beginning carefully following the instructions--do not miss any spots or thread guides.
If top thread is still creating a mess of loops under the fabric, try tightening the upper tension. The tension is ideal when both upper and bobbin threads meet in the middle of the fabric.
Dec 10, 2015 | Singer 5160 Mechanical Sewing Machine
Why does the top thread sometimes picks up the hook and then picks up bobbin but bobbin then crosses over and makes a mess? Wont work
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever? n
May 21, 2015 | Sewing Machines
I place the fabric on the machine, lower the foot and apply pressure to the foot peddle, when the machine begins to sew fabric is pulled down and the lower thread tangles, the machine make a crunching...
This is easily solved. Before you start sewing make sure your upper and lower threads are long enough for you to hold before lowering the presser foot. If these threads are too short they both get carried down into the bobbin along with the fabric and cause a big tangled mess. Always hold your threads at the back of your work with your left hand then lower your pressure foot and don't release the threads untill you have taken several stitches. Keep holding these threads during backstitching at the beggining of a seam too. Works like magic.
Dec 21, 2010 | Brother XL-3500
Brother embroidery machine broken
make sure the bobbin thread is wound and installed correctly
remove tangled thread and clean lint out from under feed plate
clean and remove shuttle to clean out area with lint brush
inspect bobbin for burs and scratches...make sure when reinstalling shuttle and bobbin that it rotates freely
hope this helps
Feb 04, 2010 | Brother SE-270D Computerized Sewing...
Need online manual
If you are having problems with the thread on the underside of the fabric, that is usually the upper tension. Check to make sure that it is threaded correctly. If so, make sure that the thread is inside the tension disc and that there are no pieces of thread caught in the tension. If it is threaded and there are no thread caught up in the tension assembly, adjust your tension dial to a slightly higher number. Do this until you get a good stitch.
Feb 09, 2009 | Kenmore Sewing Machines
Bobbin thread bunches up creating a tangled mess under the plate
This could either be due to the bobbin being wound too loosely, or the tension on the top thread is too loose. This just happened to me the other day, and I thought it was the bobbin thread, but then I put another bobbin in with a different color than the top thread (this is a huge help in diagnosing thread issues), and I was surprised to find that it was actually the top thread that was a big loopy mess on the underside of the fabric. I fixed it by tightening the tension on the top thread (quite a bit), and everything was fine.
Jan 23, 2009 | Husqvarna Viking 1
Bobbin tangle
can not thread bobbin...bobbin on top
Jan 16, 2008 | Kenmore 19233 Computerized Sewing Machine
Kenmore 19110 Computerized Sewing Machine Logo
373 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
