Question about Garmin nuvi 265 Car GPS Receiver
Garmin bluetooth won't disconnect call
I connected my phone via bluetooth, and it works, but sometimes it refuses to end the call. My phone registers the call as ended, but the Garmin continues to tick off the time. When I press the red end call button nothing happens. I have to shut down the Garmin in order to make another call. I've tried pairing them again, but it still happens.
  • therealdort Feb 21, 2009
    i have same issue with nuvi 660 after webupdater
Solution below works for NUVI660 as well; ignore everything after step 6 but DO reboot and delete previously existing connections.
good luck
All,
I was having the same problem with my Curve and Nuvi 680. What has fixed this for me is downgrading the Bluetooth firmware version on the Nuvi itself. I was running version 3.0 (you can check your version by going to Settings -> System -> About on the Nuvi) -- I had success after downgrading to version 2.4.
It's a bit of a convoluted process, but here is the procedure I followed:
1. Download the old Nuvi BT firmware from the Garmin Italy website:
http://www.garmin.it/files/FileBluetooth.zip
2. Connect your Nuvi to your PC.
3. Go into the X:GarminRemoteSW and look for a file called 006B055301.GCD (where X: is your Nuvi drive)
4. Back up that file to your
computer, and delete it from the Nuvi.
5. Extract the file in the zip downloaded in step 1 to the X:GarminRemoteSW directory
6. Disconnect your Nuvi from your computer, and let it
reboot
7. Click on "View Map," then touch the "Speed" in the lower left corner.
8. You should have the "Dashboard" view up. Touch and hold the "Moving Average" box for ~15 seconds until the diagnostic screen appears.
9. Press the "next" button until you arrive at the "Bluetooth Status" screen (5-6 screens in)
10. Click "Updt PR" and then click "Yes"
11. Reboot the Nuvi, delete the existing bluetooth pairing, and attempt to re-pair with your BlackBerry.
Seems to work perfectly now -- please let me know if you have any questions. Good luck!
Posted on Feb 21, 2009
How can I my 2004 Honda Goldwing mic to work with my Garmin Zumo 665 to answer my cellphone? The phone bluetooth connection works fine with the Garmin in my car, but my Honda mic does not work through the...
The microphone input from the Zumo 665 motorcycle mounting cradle is the smaller 2.5mm jack.
Be sure to use this one as some microphone jacks will require a 3.5mm to 2.5mm adapter.
The audio output is the 3.5mm jack.
Be sure not to confuse the two.
It may be necessary to have a custom 5 or 7 pin DIN adapter made to connect between the GW audio system and the Zumo.
It would be best to consult with your local Honda GoldWing dealer for more information on interfacing the GW audio system.
Oct 07, 2011 | Garmin zumo 665 GPS Receiver
I need to use this phone as a modem for internet. How?
  • Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the AT&T Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
  • Launch Internet Sharing, found in the Start menu on your AT&T Samsung cell phone. Open the application.
  • Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than AT&T is showing on the display.
  • Start the Internet Sharing connection. On your AT&T Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
  • Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your AT&T Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
Feb 04, 2011 | Samsung SGHE250i Cell Phone
How do I update my garmin
Hi Wilma,
Go to http://my.garmin.com
Register for a free account.
If you have not registered your unit it will ask for the serial number and ask you to choose the model.
If you are eligible for free updates it will tell you, otherwise you can purchase the updated maps per the cost at the website.
Of course you must have a pc cable to connect to your device - unless possibly you can update via bluetooth.
Safiri
Nov 11, 2009 | Garmin nuvi 205W GPS Receiver
Can't end Bluetooth phone call with Zumo 550
I have a motorola phone, and it's fine.
I have paired the phone to the zumo, and the phone is set to connect to the zumo automatically.
Check the phone is set up this way, and all should be well.
Hope this helps.
Dec 24, 2008 | Garmin zumo 550 GPS Receiver
Bluetooth intermittant connection problem
Have you rechecked with garmin webupdater there is a new update since july 1 2008.
Jun 21, 2008 | Garmin nuvi 350 GPS Receiver
Zumo 550 - Failure of call functionality on Bluetooth
Try the garmin webupdater with the unit connected to the computer to see if your bluetooth firmware is the latest. Beware however, I lost phonebook functionality!
Mar 04, 2008 | Garmin zumo 550 GPS Receiver
Speaker phone
While the unit is plugged into the computer, it cannot be used as a speaker phone. If you have a cellphone connected via Bluetooth, it will transfer the call to the C550, but you will not hear the other party and vice versa. The unit cannot be manipulated until it is disconnected from the computer.
Dec 21, 2007 | Garmin StreetPilot c550 GPS Receiver
Garmin nuvi 265 Car GPS Receiver Logo
464 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
