Question about Scotsman DCE33PA1BC 15in Built-in Automatic Ice Machine/Maker w/ Drain Pump, Black
Scotsman icemachine m# DCE33A-1WB ice cubes are hollow
The timer seems to be moving too fast for ice to freeze whole the cubes look like shot glasses
  • Shirley Holcombe Jun 06, 2013
    Need instructions on cleaning this icemaker, dce33a 1wb....husband used to do it and I can't find manual. I have the bottle of solution.
    Problem Solver:
  • 7 Answers
Have several of these machines here. The cube size control and the hot gas valve are common problems. I've had several that had one or the other. Generally if the cubes are forming and not harvesting the cube size control is likely the culprit. If no ice is forming then the hot gas valve may be leaking by or several of my machines have had leaks around this valve. The replacement part is not the same as the OEM part.
The charge is tricky and no access valves on this machine. Weighing in the charge is preferred.
Posted on Aug 23, 2010
It stopped making ice cubes...........water is flowing but the cubes wont form
Posted on Jul 20, 2010
  • Scotsman Master
  • 8,220 Answers
    Guru:
  • 462 Answers
There is a cube size thermostat that energizes the timer. If it has been energizing early try a thicker setting on the cube size. If still gives problems ... your trouble was back in Feb I assume in cold weather.. If the machine is not in a room where the temp stays above 65'f this can also cause premature harvesting as you discribe also. Also if you are loosing water from the water curtian not sealing off it will cause the problem you discribe because the water is dripping off and out before it can freeze. Any futher questions please post. If this helps you understand your trouble please rate me as high as yuou can, thank you for using fixya
Posted on Jun 02, 2009
Scotsman icemachine constantly freezing up no matter how small you put the setting?
Max harvest cycle just keeps it in a harvest longer. if you set the freeze setting to its lowest point and ice is still to thick then replace the freeze stat.
Feb 22, 2015 | Scotsman Ice Machine, Cuber, 1930 lb....
Ice getting to thick and not dumping
go to the freeze timer which has off and on dip switches. take some freeze time out by moving the first switch to off this will shorten freeze time. Also check the harvest assist solenoid and plunger when it go's into harvest. make sure the machine is cleaned and check the cube plate to make sure that none of the plates are not loose this will cause ice to freeze between the loose spots and will not let ice come off the plate.
Jul 21, 2014 | Ice-O-Matic ICEU220HA Undercounter Ice...
Scotsman DCE33A-1WB not draining
Check that Ice cubes are freeezing completely before dumping into tray.
Check that spray nozzle isn't inadverdantly clogged and spraying water everywhere.
Check that water inlet solenoid is actually closing and not leaking water into bin.
Check thermostat for the bin not working properly, frozen over or something.
Oct 31, 2012 | Scotsman Refrigerators
Scotsman DCE33A-1WB Residential Ice Machine Problem
Making good ice. Could be cube size control. Could be a weak compressor. Also these machines are household and meant to run in air conditioned space.
Aug 02, 2010 | Scotsman DCE33PA1BC 15in Built-in...
A continuous grinding sound on my Scotsman DCE33A
I would suspect the water pump is making this noise. If it is, there is no repair, you must replace it.
Jul 01, 2009 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman ice machine problems.
Well it is making ice cubes alright just too thick right? I would give it a good cleaning with nickleguard and retry. If it is still doing the same thing I would replace the ice thickness switch.
Aug 05, 2008 | Scotsman CSW45 15" Ice Maker with 26 lb....
Ice maker making hollow cubes
check your incoming water pressure, change the water filter recently? hollow ice cubes is a sign of low water pressure
Mar 05, 2008 | Refrigerators
Scotsman DCE33PA1BC 15in Built-in Automatic Ice Machine/Maker w/ Drain Pump, Black Logo
1,215 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
