Question about Maytag MER6772 Gemini Electric Kitchen Range
Maytag Gemini top oven element no longer heats.
Replaced element to no avail.
  • Anonymous Feb 12, 2009
    The top element in the top oven does not come on, though the display looks normal (on broil, for instance). The bottom element and all of the bottom oven work fine.
    President:
  • 1,314 Answers
Replace the switch
Posted on Feb 11, 2009
After a power failure, the clock face went out and there is no power to the duel ovens on a Maytag gemini electric oven. All four burners on the glass flat top work though.
try turning power off at electrical main switchboard for a minute, then back on. reset clock and see how it goes.
otherwise > call the repair man.
Oct 20, 2013 | Maytag Gemini Electric Double Oven Range...
The top oven only heats up to like 150. Is it the heating element for the top oven? If so is it hard to exchange?
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 27, 2011 | Maytag MER6772 Gemini Electric Kitchen...
I have a Maytag Gemini, top oven burns everything on the bottom
RAISE OVEN RACK SHELF, BOTTOM ELEMENT MAY NOT BE TURNING OFF, NEEDS REPLACEMENT
Nov 03, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Problems with Maytag MER6772 Gemini Electric Kitchen Range
may tag gives 5yer worenty if not still under worant get rid of it
Apr 05, 2009 | Maytag MER6772 Gemini Electric Kitchen...
To part of Gemini Double oven/coils do not light up/work
check elements to see if there good if they are u need a erc
Mar 20, 2009 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Maytag Gemini Double Oven-bottom temp problem
after power outage clock on oven will not set unless the oven itaelf is on unable to set clock
Jan 16, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini top oven, the bottom element does not get hot. I replaced the element with a new one from maytag. what is the problem?
Hello jrlibs
Welcome,
You said, Your Maytag Gemini top oven, the bottom element does not get hot. You replaced the element with a new one from Maytag. Asking what is the problem?
1.What is the model number and the year of your Gemini Range?
2.Was there an error code that came up before you changed the heat element?
3.If yes what was the code?
4.Did you check for current in the connection leading to the element before you installed the new one? Or just plug it in hoping for the best?
Waiting for your reply!
Huuum
Oct 16, 2008 | Kitchen Ranges
Maytag Gemni Stove
The problem is either in the oven control or the element (in some cases could be both). You will need a meter to check the resistance on the elements as well as power to the element. Remember this is 240 volts and very dangerous. If your not comfortable with it call a professional.
Oct 08, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
182 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
