Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
Older electrolux canister brush will not turn used reset button
I have a older electrolux canister the brush will not turn used the reset button without success.
  • Anonymous Mar 30, 2014
    vacuum turned off but brush not
    can not be turned off
  • 547 Answers
Change the belt
Posted on Feb 12, 2009
Where is the reset button on my electrolux guardian canister
There is a reset button on the power nozzle...not sure I heard of the vacuum canister has a reset button....hum.
Feb 15, 2013 | Electrolux Guardian Bagged Canister Vacuum
I vacuumed a shirt. It came out immediately and there is now visible damage. The suction is working but the rotary piece with the brushes is not
Have you pressed the reset button on the power nozzle? If the power nozzle motor isn't running, this is the problem. If the PN motor is running, the problem is more likely to be a broken belt, and it needs replaced.
If the belt, I strongly recommend taking it to an authorized Aerus Electrolux dealer to have it replaced. It can be tricky disassembling and reassembling the PN without damaging something.
Nov 21, 2010 | Electrolux Guardian Bagged Canister Vacuum
Hello! I have an Electrolux Ultralux 2000,
Sounds like the belt on the beater brush has broke.replace the belt on the beater brush.
Dec 06, 2009 | Electrolux UltraLux 2000 Bagged Canister...
The brush on the power nozzle N137P does not rotate on my Guardian and I can't get it apart to see if the belt is broken.
First of all, have you tried pushing the reset button?Do you hear the brush motor come on when you push the switch on the hose? If the belt is broken the brush will spin freely without any resistence.
The elbow of the power nozzel has a history of breaking and one or both wires in it will loose connection and the motor will not run.
There are five screws on the bottom of the power nozzel. Four long screws and one shorter screw. Be sure to mark where the short screw goes for re-assembly. Then the top will lift off. You might want to take it to your Aerus/Electrolux shop for repair. Your Guardian should be under waranty.
Joe
Sep 23, 2009 | Electrolux Guardian Bagged Canister Vacuum
Electrolux vacuum power bar not turning
First thing is to push the circuit breaker button(reset button). If that dosen't work, check the belt. It could be broken.
Jul 10, 2009 | Electrolux Guardian Bagged Canister Vacuum
Power nozzle motor will not turn on
Try hitting the reset button,It is a small button on the top of the brush and make sure the switch is turned on on the handle.
Jun 22, 2009 | Electrolux Epic 6500 Vacuum
I have a Electrolux , EL6988 Canister Vacum, howeveer the brushes and motor will not run when turned on. I have take the plates and cleaned around the brushes, but it will not come one. The vacum comes on...
Turn the brush unit upside down, so you can see the brush roller. Then, with the brush roller positioned nearest to you, you will find the reset button close to the rear edge, near the wheel that's on the right hand side as you look at it.
Good luck! I hope this works for you. I value your feedback. Please remember to rate this response.
Feb 19, 2009 | Electrolux UltraLux 2000 Bagged Canister...
EL5 (large) powerhead
There is a no filter safety device part #1130912-01, maybe the new filter isn't in quite like it should be or this device has gone bad. Also check the brush roll and make sure it turns easily, if not then that could be the cause.
Nov 27, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
283 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
