Question about Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor
Motor operates in horizontal position only
Endura 30 when motor is positioned vertically in water, it won't run. when it is tilted toward horizontal position it starts running. returned to vertical, it stops again.
    Problem Solver:
  • 10 Answers
Turn off the motor, and grab the prop and see if you can pull if away from the housing, if it moves more that about 1/16, you have a problem in the motor housing, maybe bad bushings or contacts.
Posted on May 31, 2009
    Problem Solver:
  • 11 Answers
Take the top cover off and check for a wiring problem. You may have one that is loose and isn't
making connection when motor is in the water. I'd guess it is your red (hot) wire).
Posted on Mar 12, 2009
Memory seats adjust on there own as well as mirrors
BCM has nothing to do with this function , MMM - memory mirror module !
Memory Mirror System Operation
The MMM is capable of storing mirror position for 2 different drivers. Mirror position is determined by both horizontal and vertical position sensors in each of the power mirrors. The MMM supplies a reference voltage and a low reference to these sensors and determines mirror position through the horizontal and vertical position signal circuits.
The MMM receives power through the battery supply voltage circuit and the MIR/LOCK fuse and a constant ground source. Any time that battery voltage is disconnected and then connected from the MMM, the MMM will enter the mirror relearn mode. The mirror relearn mode can also be commanded using a scan tool. Refer to Memory Mirror Module Learn for further information.The memory switch receives power through the battery supply voltage circuit and the MIR/LOCK fuse. The MMM upon receipt of a memory switch signal input, a class 2 message from the SIC or a class 2 message from the PCM indicating that the transmission is in park, will then supply battery voltage and ground to the appropriate power mirror motors through the mirror motor control circuits to move the mirrors to the predetermined positions.
DTC B1586, B1596, B1616, or B1626
The mirror horizontal and vertical position sensors are potentiometers. The Memory Mirror Module (MMM) provides these sensors with a 5 volt reference circuit and a low reference circuit. The MMM monitors the horizontal and vertical position sensor signal circuits which change values based on mirror position. These voltage values are used to determine mirror position and can be set into memory. When the MMM receives a memory recall request, the MMM will control the power mirror to the memory position based on the horizontal and vertical position sensor signal values.
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With the scan tool, observe the mirror horizontal and vertical position parameters in the Memory Mirror Module (MMM) data list.
Operate both the left and right mirrors through the full range of movements.
Does the scan tool indicate that the left and right mirror horizontal and vertical position parameters are within the specified range?
Memory Seat System Components
The memory seat system consists of the following components:
• Power seat switch assembly
• Memory recall switch assembly
• Horizontal adjuster motor
• Front vertical adjuster motor
• Rear vertical adjuster motor
• Recline adjuster motor
• Memory seat module
• Memory mirror module
• SEAT 25A circuit breaker
• MIR/LOCK 3A fuse
Your best bet , take it to a qualified repair shop !
May 23, 2017 | 2002 Cadillac Escalade
GMC Yukon Seat Switch
You don't mention what year your Yukon is ? This could very well be a control Module problem .
I'll post how the power memory seat's work or are suppose to work !
Memory Seats Description and Operation
Battery voltage is supplied to the memory seat module through a 25 A circuit breaker. The memory seat module supplies the seat adjuster switch assembly with a battery positive reference voltage. While the seat adjuster switches are in an inactive state the switch contacts are closed to the adjuster switch common circuit. When a seat adjuster switch is pressed to an active state the switch contact is closed to the reference voltage circuit. Battery voltage on a switch signal circuit indicates to the memory seat module the switch status is active. Each seat adjuster motor is controlled by the memory seat module through 2 motor control circuits. While the seat adjuster motors are in an inactive state the motor control circuits are closed to ground circuit contacts within the memory seat module. The memory seat module operates the seat adjuster motors by switching one of a motors control circuits to battery voltage. The seat adjuster motors are bidirectional and the direction of adjuster motor rotation is determined by which of the adjuster motor control circuits is switched to battery voltage while the other remains grounded.
Memory Set/Recall Operation
The seat adjuster motors are equipped with internal position sensors. The adjuster motor position sensors are monitored by the memory seat module and are used to determine the seat position when storing or recalling memory settings. The driver seat adjuster motors use potentiometer type position sensors. The position sensors are supplied with a 5 V reference and ground circuits from the memory seat module. The position sensor signal circuits return to an analog input within the memory seat module. During adjuster motor operation the position sensor provides a voltage change proportional to the change in revolution of the adjuster motor shaft. The memory seat module monitors the voltage from the position sensor signal circuits to determine the adjuster motor positions when storing or recalling memory seat position settings.
The memory recall switch assembly on the driver door provides inputs to the driver door lock/window switch. Battery voltage is supplied to the memory recall switch assembly from the driver door lock/window switch. When a RCL 1, RCL 2, or EXIT switch is pressed, the switch contacts close the appropriate switch signal circuit to the battery voltage supply circuit within the memory recall switch assembly. When the driver door lock/window switch receives active switch signals from the memory recall switch assembly, the appropriate commands are sent to the memory seat module using the GMLAN Serial Data circuit. The Body Control Module software version determines the personalization features available.
Memory seat recall operation is allowed only with the transmission selector lever in the PARK position while the ignition is on. The transmission selector lever position data is provided to the memory seat module by a message through the GMLAN Serial Data circuit.
There are somethings listed you are not familiar with , like GMLAN Serial Data circuit ,maybe Body Control Module software etc... GMLAN is a communincation network that the computers on the vehicle uses to share information , transmit commons etc... you can google it to read about it .
There are DTC'S - diagnostic trouble codes that can set in the module in control . Do you know what DTC'S are .
DTC Descriptors
DTC B1825 01: Driver Seat Recline Position Sensor Circuit Short to Battery
DTC B1825 06: Driver Seat Recline Position Sensor Circuit Short to Ground or Open
DTC B1825 5A: Driver Seat Recline Position Sensor Circuit Plausibility Failure
DTC B1850 01: Driver Seat Lumbar Horizontal Position Sensor Circuit Short to Battery
DTC B1850 06: Driver Seat Lumbar Horizontal Position Sensor Circuit Short to Ground or Open
DTC B1850 5A: Driver Seat Lumbar Horizontal Position Sensor Circuit Plausibility Failure
DTC B1860 01: Driver Seat Lumbar Vertical Position Sensor Circuit Short to Battery
DTC B1860 06: Driver Seat Lumbar Vertical Position Sensor Circuit Short to Ground or Open
DTC B1860 5A: Driver Seat Lumbar Vertical Position Sensor Circuit Plausibility Failure
DTC B2355 01: Driver Seat Front Vertical Position Sensor Circuit Short to Battery
DTC B2355 06: Driver Seat Front Vertical Position Sensor Circuit Short to Ground or Open
DTC B2355 5A: Driver Seat Front Vertical Position Sensor Circuit Plausibility Failure
DTC B2365 01: Driver Seat Rear Vertical Position Sensor Circuit Short to Battery
DTC B2365 06: Driver Seat Rear Vertical Position Sensor Circuit Short to Ground or Open
DTC B2365 5A: Driver Seat Rear Vertical Position Sensor Circuit Plausibility Failure
DTC B2375 01: Driver Seat Assembly Horizontal Position Sensor Circuit Short to Battery
DTC B2375 06: Driver Seat Assembly Horizontal Position Sensor Circuit Short to Ground or Open
DTC B2375 5A: Driver Seat Assembly Horizontal Position Sensor Circuit Plausibility Failure
5) Memory Seat Module is under the front of the driver seat , you could look under an see if all the connectors are fully seated.
The best diagnostic step would be to hook up the factory scan tool an see what the computer is seeing as far as inputs from the switch an outputs it's sending . I wouldn't suggest you take the seat apart an try testing electrical inputs etc.... unless you very familiar with automotive electrical systems an circuits .
Mar 06, 2017 | GMC Cars & Trucks
CAN YOU STAND THE Husky WL651004AJ UPRIGHT?
Your compressor will work in the vertical position however you will not be able to properly drain the water from the tank in this position.
Feb 18, 2012 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Got a sc141 and 142 on a ricoh mp5000. Have cleaned the lamp and associated mirrors and have reseated the connectors at the lamp and sbu. i have run the scanner free run with the lamp on. there is no...
SC 141 -Lens vertical home position sensor abnormal stays on
When the lens returns to the home position the lens vertical home position sensor does not detect the off condition.The possible cause :home position sensor open,lens vertical drive motor defective or optics control board defective.
SC 142 -Lens horizontal home position sensor abnormal stays off
When the lens returns to the home position,the lens horizontal home position sensor mot detect the on condition.Possible cause :home position sensor in shortcircuit,horizontal drive motor defective or optics board defective.
The SC can be reset by turning main switch OFF and ON if the SC caused by misdetection.
Scanner free run
Remove the rear cover and the air inlet duct.Remove CN502,CN503,CN504 from the optic control board.Create short circuit TP 514 and GND on the optics board.Turn ON the main switch.Short circuit TP 512 and GND then the machine automatically starts the scanner free run.Turn off the main switch.Perform the scanner control adjustment.Enter in the service mode:press the clear modes key - 107 -press the clear/stop key more 3 second until the service mode appears.Perform the free run test mode 30 times.
Sep 19, 2009 | Ricoh Office Equipment & Supplies
2003 gmc mirrors do not fold in
The power mirrors are controlled by a module (computer) DDM - drivers door module an the PDM - passenger door module .
Folding Mirror System
Folding Mirror System Controls
The folding mirror system requires signals from 2 separate switches. The mirror select switch must be in the neutral/fold position and the mirror direction switch must be activated to the left/extend or right/retract positions. Both switches are integrated into the DDM and provide direct signals.
Folding Mirror System Operation
Upon receipt of the required switch inputs the DDM will supply battery voltage and ground to the mirror fold motor control circuits to perform the requested extend or retract function. The DDM will also send a class 2 message to the PDM indicating the requested function. The PDM will supply battery voltage and ground to the mirror fold motor control circuits to perform the requested extend or retract function.
Power Mirror System
Power Mirror System Components
The power mirror system consists of the following components:
• The driver door module--Class 2 module with integrated switches and requires programming when replaced
• The passenger door module--Class 2 module with integrated switches, requires programming when replaced and also contains the RFA receiver
• The power mirror direction switch--Integrated into DDM and is a 4-position momentary switch that provides a signal input to the DDM for up, down, left/extend and right/retract with a mirror switch activation
• The mirror select switch--Integrated into DDM and is a 3-position switch that allows the operator to select the left or right mirror and also a neutral/fold position
• The left outside power mirror--Contains both the vertical and horizontal mirror motors and is serviced as a complete mirror assembly
• The right outside power mirror--Contains both the vertical and horizontal mirror motors and is serviced as a complete mirror assembly
• The body control module--Class 2 module that requires programming when replaced, serves as the power mode master and is the main message handler
• The DDM 10A fuse--Located in the I/P fuse block and is hot at all times
• The PDM 10A fuse--Located in the I/P fuse block and is hot at all times
• The memory switch, if equipped with memory mirrors--Supplied power by the DDM and provides a voltage signal to the DDM upon a switch activation
• The horizontal and vertical position sensors, if equipped with memory mirrors--Supplied a 5-volt and low reference by the DDM/PDM and provide a variable voltage signal to the DDM/PDM that is proportional to mirror position
• The park neutral position switch, if equipped with memory mirrors--Provides transmission gear selection information to the PCM and is used for memory recall and mirror tilt in reverse functions
• The powertrain control module, if equipped with memory mirrors--Class 2 module that requires programming when replaced and provides Class 2 message indicating transmission gear selection
• The driver information center (DIC), if equipped with memory mirrors--Part of the instrument cluster which is a Class 2 module that requires programming when replaced and is used to personalize the memory recall and mirror tilt in reverse functions
• Fold motor in each of the outside mirrors, if equipped with power fold mirrors--Provides extend and retract movements of the mirror and is serviced as a complete mirror assembly
Each of the outside power mirrors contains 2 reversible motors to provide horizontal and vertical movement of the mirror glass. The vertical motor operates the up and down directions and the horizontal motor operates the left and right directions. If equipped with power folding mirrors, each outside power mirror will contain a reversible fold motor to operate the extend and retract functions. Each of the mirror motors are circuit breaker protected.
DTC B1722
The driver door module (DDM) and passenger door module (PDM) switch the mirror fold motor control circuits to battery voltage and ground in response to mirror extend or retract command.
Apr 06, 2017 | 2003 GMC Yukon XL
Horn and power seats quit working. maxi-fuse extremely hot. pulled it out and re-inserted after it cooled down. fixed the problem temporarily (a day or so). swapped that maxi-fuse with the one above it...
which maxi fuse gets hot ? # fuse , plus amps The power seats uses a 30 amp circuit breaker ,not a fuse . The horn gets power from the same circuit breaker . . Sounds like something is drawing to much current. Do you know how to use a amp meter to test current flow . Disconnect componets till draw goes away ? How to use a wiring diagram to pin point areas in a circuit to test ?
Is there corrosion on the pins where the seat circuit breaker plugs into ? Reach under your seats an see if one of the seat motors is hot .
DeVille
The left and the right power seat system consist of the following components:
• The seat switches
• The seat relay modules
• The 4 reversible motors:
- The front vertical motor
- The rear vertical motor
- The horizontal motor
- The recline motor
These 4 motors operate independently of each other.
When the entire seat switch is pushed to the FORWARD position, the forward input of the of the seat relay is grounded.
The seat relay module supplies battery positive voltage (B+) with a ground to the horizontal motor, in response to this input. In order to drive the seat forward, the motor runs until the switch is released.
The BACK position works similar to the FORWARD position with the exception that the voltage polarity supplied by the seat relay module is reversed causing the motor to run in the opposite direction. This action drives the seat backward.
These recline switches operate similar but independently:
The seat relay module could be bad , If you don't know how to do automotive electrical circuit testing it mite be a good idea for you to take your vehicle to a qualified repair shop.
Could have diagnostic trouble codes stored as well .
DTC B0846 +5 Volt Reference Out of Range
DTC B0856 Battery 2 Out of Range
DTC B1656 EEPROM Write Error
DTC B1658 EEPROM Checksum Error
DTC B1982 Source/Battery Voltage High
DTC B1983 Source/Battery Voltage Low
DTC B2101 Recline Aft Switch Failed (Eldorado)
DTC B2101 Recline Aft Switch Failed (DeVille)
DTC B2102 Recline Forward Switch Failed (Eldorado)
DTC B2102 Recline Forward Switch Failed (DeVille)
DTC B2103 Rear Vertical Down Switch Failed (Eldorado)
DTC B2103 Rear Vertical Down Switch Failed (DeVille)
DTC B2104 Rear Vertical Up Switch Failed (Eldorado)
DTC B2104 Rear Vertical Up Switch Failed (DeVille)
DTC B2105 Horizontal Aft Switch Failed (Eldorado)
DTC B2105 Horizontal Aft Switch Failed (DeVille)
DTC B2106 Horizontal Forward Switch Failed (Eldorado)
DTC B2106 Horizontal Forward Switch Failed (DeVille)
DTC B2107 Front Vertical Down Switch Failed (Eldorado)
DTC B2107 Front Vertical Down Switch Failed (DeVille)
DTC B2108 Front Vertical Up Switch Failed (Eldorado)
DTC B2108 Front Vertical Up Switch Failed (DeVille)
DTC B2109 Lumbar Aft Switch Failed
DTC B2110 Lumbar Forward Switch Failed
DTC B2111 Lumbar Down Switch Failed
DTC B2112 Lumbar Up Switch Failed
DTC B2115 Recline Sensor Failed
DTC B2116 Rear Vertical Sensor Failed
DTC B2117 Horizontal Sensor Failed
DTC B2118 Front Vertical Sensor Failed
DTC B2119 Lumbar Forward/Aft Sensor Failed
DTC B2120 Lumbar Up/Down Sensor Failed
DTC 2130 Seat Motor Failure
Aug 10, 2017 | 1997 Cadillac DeVille
MinnKota Endura 50 Runs only in high speed in forward and reverse
the coil pack is likely bad especially since you changed the switch. call minkota and get the bench tast info (very simple) and then order and replace the coil pack about 26 dollars. be very careful how you put the magnet assembly back together and mark the position of the case on the outside before disassembly. order a new seal kit and use locktite on the shaft again when reassemling to seal the shaft tube for water. dont run motor uout of the water much as it uses the water to cool the shaft and you can damage the seals. good luck.
Jun 18, 2009 | Minn Kota Endura 30 Freshwater Transom...
Electric Mirrors do not work (Drivers & Passengers)
There are two power wires to the DDM - drivers door module .Both are orange ,one is powered by a fuse DDM fuse 15amp . in the left I/P fuse block , plus LT DOORS 25amp circuit breaker .
Do you know what DTC'S are ? Diagnostic trouble codes
DTC B1544, B1600, or B1605
DTC B1580, B1590, B1610, or B1620
• If DTC B1580 is set by itself, the left horizontal position sensor signal circuit maybe open, shorted to ground or battery
• If DTC B1590 is set by itself, the left vertical position sensor signal circuit maybe open, shorted to ground or battery
• If DTC B1610 is set by itself, the right horizontal position sensor signal circuit maybe open, shorted to ground or battery
• If DTC B1620 is set by itself, the right vertical position sensor signal circuit maybe open, shorted to ground or battery.
• If DTCs B1580 and B1590 are both set, the left 5 volt reference or low reference circuit(s) maybe open, shorted to ground or battery.
• If DTCs B1610 and B1620 are both set, the right 5 volt reference or low reference circuit(s) maybe open, shorted to ground or battery.
Need a factory scan tool to test !
With the scan tool, observe the mirror horizontal and vertical position parameters in the Driver Door Module (DDM) and Passenger Door Module (PDM) data lists.
0.50-4.75 V.
Your best bet , take it to a GMC , Chevy , buick or cadillac dealer
Apr 16, 2017 | 2003 GMC Sierra 2500HD
How does the minn kota 65 all terrain run on 24
You should only run the motor with a 24v battery or two 12v batters 'jumped' out. To jump the two batteries, connect the positive on one batter to the negative on the other battery and hook the trolling motor battery cables up to positive and negative terminals that are NOT jumped out as you would normally. Don't run this with 12v as you will have serious problems if you do. They do not make a 65lb thrust in 12v - too much pound thrust to run off of 12v.
Feb 22, 2009 | Minn Kota Endura 30 Freshwater Transom...
Minn Kota Trolling Motor will not run
Hi!
For starters, here is a schematic:
Endura 30
Check to see if there is appropriate voltage getting to the switch (with an ohm meter).
You can (please do this carefully) disconnect the battery positive and negative as well as the motor red and motor black wires and connect the Batt positive to the motor red and the Batt negative to the motor black. If the motor runs, the switch is faulty. If it doesn't then I suspect the motor needs looking at.
Best of luck!
Mike
Feb 06, 2009 | Minn Kota Endura 30 Freshwater Transom...
Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor Logo
382 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
