Question about Logitech Driving Force GT Wheel for Playstation 2, PlayStation3
Brake pedal sticks!
The brake pedal on my driving force gt is sticking just on the surface so that the brakes are just barely on when I step off the pedal. I have to manually lift the pedal to stop braking...any solutions?
  • 3 more comments
  • Anonymous Mar 12, 2009
    Same problem here. If I flick the pedal with my foot the brakes come off.
    Any suggestions?
  • Anonymous Mar 20, 2009
    brake sticks just a little, very stupid
  • Anonymous Apr 07, 2009
    Same problem here right out of the box. I'll be returning it to Best Buy.
  • Anonymous Apr 15, 2009
    Same problem here. Very annoying
  • Anonymous May 07, 2009
    exactly same here, must be common fault, this sux logitech!
  • 15 Answers
3 Suggested Answers
  • 15 Answers
SOURCE: brake pedal sticks!
Here is the solution for the sticky brake pedal. This is a common problem on the Logitech Driving Force Series Wheels. http://merc460racing.com/GT/repairing_logitech_driving_force.htm
Posted on Sep 05, 2009
  • 15 Answers
Here is the solution for the sticky brake pedal. This is a common issue with the Driving Force series wheels http://merc460racing.com/GT/repairing_logitech_driving_force.htm
What is the proper way to hold and use the Racing wheel for Gran Turismo 5?
you dont. its not really designed for gran turismo at all. i would recommend just sticking to the dualshock controller or if your seriously into racing fork over some money for the logitech driving force pro. it features force feedback, pedals, gear shifter and pedals for acceleration and braking. its pretty much as close to driving as you can get from a video game other logitech wheels are available with clutches six shifters and interchangeable wheels but the driving force is the best for its price alone.
Apr 28, 2014 | Intec G6076 PLAYSTATIONRMOVE ULTIMATE...
Gas pedal sticks on isuzu trooper
On the next "above freezing" day, force lubricant through the throttle cable and lube all linkage at the engine end and interior.AND BEFORE STARTING for the next while try depressing the gas pedal and make sure it is releasing fully.
If it ever gets stuck again SHUT IT OFF before you damage the engine with high RPM on a cold engine.
May 21, 2017 | 1998 Isuzu Trooper
I have a 1979 suzuki 550 motorcycle.When you step down on the rear brake pedal, the brake works but the pedal will not come back up to release the rear brake, I have replaced the spring that goes around...
Presuming your bike is disc brake on the rear, disconect the pedal from the piston which opperates the brake mastercylinder, by removing the clip and clevis pin, now when you press the pedal you should have no resistance at all, if the pedal still sticks then you will have to remove the pedal and knock out the shaft from the frame and clean the shaft and the hole in the frame before greasing and refitting, it may also be the piston sticking inside the mastercylinder
Aug 28, 2011 | 1979 Suzuki Gs 550 L
My "Brake" light came on
Thanks for choosing FixYa and welcome to the site. Your brake switch is probably stick. It has a little button on it that is activated when you hit the brake. It may need changed. It controls your brake light. It is right above your brake pedal. The brake pedal hits it when the pedal is pushed in. It is usually chrome looking and a round cylinder. Go ahead and change it. It should solve your issue. Thanks for using FixYa.
Apr 20, 2011 | 1997 Toyota Camry
Could you help with this problem? when i put my car in drive or reverse my brake lights stick and stay on the whole time.
on the top back side of brake pedal there is a brake light switch. it maybe just sticking or its out of adjustment. the brake pedal arm hits this switch everytime brakes are applied to activate the stop lights. have a good day !! if it just sticks you may be able to free it up.
Apr 07, 2011 | 2001 Ford Focus
Front brakes sticking after a couple of miles
There are 2 causes, 1.caliper slides are in need of servicing/lube.2, caliper(s) piston(s) need to be serviced/cleaned. Recommend replacement of both calipers, if either doesn't work.
May 15, 2010 | Cars & Trucks
2001 silverado 1500, just put on new pads rotors and 1 new caliper, the brakes are spungy, the wheel with the new caliper is sticking and the front passanger brake too, i cant figure out why.
Replace both front brake hoses.....they collapse on the inside and will not allow fluid to retract...caliper was probobly fine.....this happens a lot....good luck...Lee
Jul 22, 2009 | 2001 Chevrolet Silverado 1500
Brake lights stick while driving but turn off when pressing brake
CHECK YOUR BRAKE LIGHT SWITCH THAT IS ON YOUR BRAKE PEDAL UNDER THE DASH
Jul 05, 2009 | 2007 Pontiac G6 GT Convertible
Brake pedal sticks!
Jun 02, 2009 | Logitech Driving Force GT Wheel for...
Brake pedal sticks!
May 28, 2009 | Logitech Driving Force GT Wheel for...
Logitech Driving Force GT Wheel  for Playstation 2, PlayStation3 Logo
766 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
