Question about Encore ENLTV-FM-HA (CTETVC)
88 ford tempo car will cut out when put in gear
Had this 88 ford tempo for years , had tune ups , filter changes , etc
still no changes , will stay running when not in gear but will cut out when put in gear
  • 86 Answers
You need to check the distributer cap and make sure that it isn't cracked. If it is this will cause your car to cut out the minute that you start moving.
Posted on Feb 11, 2009
I have a 1994 ford tempo that has issues shifting. It starts fine goes into all gears . it shifts from first to second gear at 35mph then shifts again at 45mph. What could be the issue? I changed the...
You may need a transmission shop for this.
Some older cars used a vac modulator to control shift time, but I don't see one listed for a 94 Tempo. Whatever Ford uses to control shift time may be faulty, or the kickdown cable to the throttle body may be sticking. It could have a solenoid inside that does what the modulator once did.
Dec 12, 2012 | 1994 Ford Tempo
1994 ford tempo runs rough at ldel
try giving it a tune up, new spark plugs, wires, cap, rotor, and a new air filter, also the fuel filter if it hasnt been replaced in a while
Mar 26, 2012 | 1994 Ford Tempo
Could a electrical problem cause my 1987 ford ranger v6 automatic transmission w/overdrive not engage in any gear? If so what do I check?
possibly electrical, my opinion to you will be what my 88 did to me. i couldnt engage r or d so i decided to pull my ****** pan and gasket, and replace my filter, gasket, then fresh trans fluid to cure my issue. i drove the truck for a couple of weeks then decided to replace the filter and fluid again just to be sure. the truck served me many years after that tune up. i hope this helps you bud.
Sep 27, 2011 | 1987 Ford Ranger
Yeah my 93 tempo stalled out on me and wont start up.A mechanic says its the fuel pump so i changed it and it still wont stay on it does but then shuts off.I then put in a new fuel filter and it seems i...
test the fuel pressure ,it could be the valve on the end of the fuel rail ,the one with teh vacumn pipe running to it ,also check the rubber pipe as it could be deteriorated
Dec 12, 2010 | 1993 Ford Tempo
My 88 tempo is always stalkling when i am at a light i have fixed distributor fuel filter my catylic convertor was cleaned out my spark plugs were changed. not sure what it could be. Could it be the fuel...
you gotta run a fuel injecter cleaner through the tank next time you fill up. then i filled up with premium the next time and it really worked. then back to regular unleaded of couse.thats the cheap fix i did
Oct 06, 2010 | 1988 Ford Tempo
Are the brakes rotars or drums on an 88 ford tempo
disk in the front and drums in the back unless u have the upgreated to the disk disk.
Nov 21, 2009 | 1988 Ford Tempo
My 92 tempo runs and drives great,but when you put it in gear it seams like wants to stall.almost like the idel is to low. if you turn the idel up the car jumps when you put into gear. the idels to high....
GIVE IT A FILTER CHANGE-AIR, FUEL. MAYBE PLUGS AND WIRES DEPENDING WHEN WAS THE LAST TIME. FUEL INJECTOR CLEANER, DON'T MESS WITH THE IDLE SCREW-THAT'S WHAT THE COMPUTER IS FOR.
Oct 16, 2009 | 1992 Ford Tempo
1991 Ford Tempo GL shuts off and check engine light
check to see if there is exaust coming out of the exaust pipe. It sounds like you might have a stopped up catalitic converter.
Aug 04, 2009 | Ford Tempo Cars & Trucks
Televison & Video Logo
73 people viewed this question
Top Encore Televison & Video Experts
Electro Med Services...
Are you an Encore Televison and Video Expert? Answer questions, earn points and help others
