Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Lubricate agitator? Unit seems to get hot during a cycle. 1.Does the agitator ever need lubricated? 2. Does constant water pressure from the supply line hurt the washer in any way when the washer is not running?
    President:
  • 1,314 Answers
No on both counts
Posted on Feb 11, 2009
Door will back up when closeing
unit is encountering too much resistance during closing cycle and reverses itself as if it is hitting something. You need to increase the closing pressure control to overpower the resistance. OR, clean and lubricate the rails to reduce friction and see what happens.
Nov 03, 2013 | Chamberlain 1/2-HP Whisper Drive Belt...
Ice machince is going max freeze cycle shut down
1. Possible cause. Water leak. Check purge valve, water curtain, sump, sump hose.
2. Air filters clogged. Clean air filters.
3. Dirty condenser. Clean condenser.
4. Restricted location, intake air to hot. Have machine moved.
5. Ice thickness sensor dirty or disconnected. Check ice thickness sensor probe.
6. Water distributor dirty. Remove and clean water distributor.
7. Inlet water valve leaks through during freeze cycle. Check water inlet valve.
8. Connected to hot water. Check for bleed through from missing check valve in building water supply.
9. Incomplete harvest. Check harvest system.
10.High pressure cut out opened. Check fan motor pressure control, check fan motor, check controller using test mode.
11. Fan motor pressure control open. Check fan pressure control.
12. Fan motor not turning. Check fan motor, check fan blade,check controller using test mode.
13.Water pump not pumping. Check pump motor,check controller using test mode.
14. Pump hose disconnected. Check hose.
15. Compressor not operating. check compressor contactor, check controller using test mode.
Check compressor start components, check PTCR resistance and temperature, check compressor voltage, check compressor windings.
16. Low refrigerant charge. Add some refrigerant and restart unit. If cycle time imporves, look for a leak.
17. Hot gas valve leaks through during freeze. Check hot gas valve for hot outlet during freeze.
18. Thermostatic expansion valve bulb loose. Check bulb.
19. Thermostatic expansion valve producing very low or high superheat. Check evaporator superheat, Change TXV if incorrect.
20. Compressor inefficent. Check compressor amp draw, if low and all else is correcy, change compressor.
Sep 28, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
90cc 2 stroke polaris atv backfires, the plug is new, and it sometimes seems to starve for fuel. filter seems o.k., and the air filter cleaned out. Seems to get worst when hot
2 cycle engines have tendencies to plug exhaust systems which will cause pressure buildups within the combustion chamber due to the oil being used to lubricate the internal bearings and components it is then spent on combustion and exits out the exhaust hence to cloud of smoke left behind over long periods of time if too much oil is being supplied (oil rich) then these heavy oil deposits collect within the exhaust system eventually leading to a plugged exhaust stream. Another issue is that a 2 cycle engine requires the crankshaft seals to be perfect, if a crankshaft seal is not completely sealing during the intake cycle instead of using the fuel system to provide 100 percent of intake air/fuel there will be a reduced or limited amount reaching the combustion chamber as the crankcase will **** in air through the seals on the crankshaft and reduce the amount of required fuel/air mixture to provide a complete combustion cycle, another possibility is piston ring/cylinder wall damage. Some steps are the compression gauge test, cylinder leakdown test and a simple tear down and visual examination.
Jan 01, 2012 | Polaris ATV
When i switch on the power of my karcher K2.38 power washer, the motor runs but there does not appear to be any increase in pressure, which means that it is ineffective when it comes to cleaning the patio/...
Hi and welcome to FixYa, I am Kelly/
First off, remove the water supply hose from the power washer and locate the in line filter. Most of them are a plastic screen stuffed into the plumbing just behind the hose washer. Others have a short stand off and the filter / screen may be where the stand off attaches to the pressure washer. Others units have in in line sump that usually has a blue or red cap that you remove to clean the sump. Find the filtering mechanism(s) and clean it.
After doing this... attach the water hose loose to the power washer and turn on the water supply hose. Wait for all of the air to purge from the water supply hose. Then tighten the water supply hose. After that... Squeeze the wand trigger until all the air purges out of the high pressure hose and you get a solid stream of water with the unit off. Once you get a solid stream of water with the unit off... power the unit up and see if the high pressure hose becomes rigid / charges with high pressure. Next.... cycle the wand trigger 1 second on... and then wait for the hose to charge again. Do this multiple times. What your doing is forcing the un-loader / relief valve to stroke in the pump. Until the un-loader valve stokes un-restricted; you will have pressure problems. Next after the hose is fully charged... cycle the wand trigger very rapidly until you get high pressure each time you cycle the wand trigger. At this point your done and can proceed with patio cleaning.
Should this NOT resolve your problem.... get as much water out if it as you possibly can and pour a few ounces of engine oil into the water inlet. (Easier said than done... but you have to get oil into the pump and then let it sit over night. once you have oil in the pump pull the recoil 2 times with the ignition off just to force oil through the pump)
The next day you go through the same routine as stated above. This brings about 80% of the stubborn ones back to life again. Should it still be fussy after doing all of the above... you will have to replace the unload-er valve. If you removed the un-loader valve for any reason... you must clean out the pump housing and lubricate it and the un-loader valve with white grease (<-Available at any automotive parts source) BEFORE reinserting either the old one or a replacement un-loader valve. If you attempt to use the old one with lubrication.. make sure to remove any debris from the springs and wipe the seals clean with a PAPER towel before lubrication.
Thanks for choosing FixYa,
Kelly
Apr 16, 2011 | Karcher K2.26 Electric Power Washer
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
K5.140 makes a revving noise when releasing the
Before you do the below steps check the water supply inlet screen for obstructions where the water hose connects to the unit. If you notice debris remove and clean the screen under running water with a small NYLON brush.
The bypass unloader valve is triggering earlier than it should. You can lubricate this by adding oil to the water supply inlet (at least 3 oz.) and very briefly switching the unit on then off 0.5 seconds. Then let is sit overnight. The next day connect power briefly and again cycle the unit on then off for 0.5 seconds. Connect the water supply and then purge the water wand hose into a bucket to catch the oil before use. After this restart the unit and operate the wand trigger under full pressure at 0.5 second intervals to ;scycle the bypass / unloader valve inside the pump. This method has worked in about 95\0 % of the machines I have worked on. The oil lubricates and fattens the seals in the bypass / unloader valve. It eihter works the first time or the seals are torn in the unloader valve and must be replaced. With only 3 uses I think your pretty much in the clear and will not need new seals.
Thanks for using FixYa.
Kelly
May 16, 2010 | Alfred Karcher K 5.93 M Electric Pressure...
Need to know gas mixture
Yours is not a current model and I did not find a manual. The following is an excerpt from a 26cc MightyLite Blower/Vac UT08550/UT08951 "Operator's Manual":
This product is powered by a 2-cycle engine and requires pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded gasoline and 2-cycle engine lubricant in a clean 1 gallon container approved for gasoline.
Recommended fuel: This engine is certified to operate on unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mix lubricant with gasoline according to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US).
Do not use automotive lubricant or 2-cycle outboard lubricant.
NOTE: Premium Exact Mix fuel mix will stay fresh up to 30 days. DO NOT mix quantities larger than usable in a 30 day period.
PREMIUM EXACT MIX (50:1)
GasolineLubricant
1 gallon (US) 2.6 oz.
1 Liter 20 cc (20 ml)
If properly adjusted your blower will operate fine on 50:1 regardles of what the manual reads. HTH
Lou
Jan 29, 2010 | Homelite Consumer Products Backpack...
Spin cycle is off balance washing machine is
i dont believe it is the agitator per say. Assuming this problem has just started and doesnt have transportation bolts still attatched. Two conditions cause the imballance. 1)(if unit is a top loader) Check if all 4 shock absorber springs are well lubricated and not sticking. 2)A more involved problem which often happens, Underneath the washer, is the drive motor. on the motor, is a round pulley. this pulley needs to come off and strip further until you see a long spring. If it is not broken, clean it up using a solvent and a rag. reassemble and test. (if spring is defective, it will slip instead of grip on a spin cycle.
Sep 17, 2009 | KitchenAid KAWS700L Top Load Washer
Water level issues on the Whirlpool washer.
It's overfilling If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
It's underfilling The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected.
If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
May 08, 2009 | Washing Machines
No coffee, water going to the drip tray
OK, so this is a problem with your brew unit. The unit is not cycling correctly to tell the water to come through.
We had another problem like this just this week.
The wat we fixed it was 1) Give the Brew Unit a really good clean. 2)Make sure the Brew Unit can complete a cycle - manually rotate the brew unit components through a cycle 3) Lubricate the Brew Units moving parts if necessary using some Saeco or Other Food Grade Lubricant
Then try watch a complete coffee cycle by leaving the side door of your machine open, and tricking the micro switches into thinking the door is closed by engaging them with some card or something similar.
Let us know if this does not resolve your issue.
Paul from Coffee Shrine
Saeco Coffee Machines
Aug 20, 2008 | Saeco Royal Professional Espresso Machine
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
57 people viewed this question
Dan Webster
Dan Webster
Sal De
