Question about Haier Refrigerators
Refrigerator too cold stays at 30 degrees
Haier bc 110 mini fridge stays too cold freezes everything 30 degrees Is there any way to adjust the temperature
  • 358 Answers
SOURCE: my mini fridge freezes everything
Need to replace the termostat.
Posted on Apr 03, 2009
  • 146 Answers
SOURCE: Koolatron Mini Fridge Overheating
Check the condensor fan behind the fridge which is designed to cool the compressor/gas line by blowing air over the condensor. When this fan motor seizes or stops running, the gas gets very hot and because it is skin cooled too, the outside of the fridge also gets very hot. You can overcome the problem temporarily by putting a standing fan behind the fridge, blowing onto the compressor and under the fridge untill you can have the problem rectified.
Posted on Nov 04, 2007
  • 236 Answers
SOURCE: brand new refrigerator...freezer works great, fridge does not
Try to defrost the unit, if it wont work check the air vents if air is present. Check also if some of your stuff may be obstructing the air vent.
sample of air vent location :
Posted on Apr 07, 2008
  • 145 Answers
SOURCE: My Kenmore Elite refrigerator keeps freezing the food!
Replace your thermostat and will work like new again
Posted on Jun 07, 2009
  • 358 Answers
SOURCE: Haier mini fridge thermostat confusion (which is cold)
Max means colder.
Posted on Sep 02, 2009
What can I do to fridge to stop it from freezing everything. its a haier mini fridge
There should be a thermostat, perhaps it needs adjusting or perhaps it is faulty and should be replaced.
Dec 28, 2017 | Haier Refrigerators
My Mini fridge Doesn't Get Cold, it's running, I've tried unplugging it for a day and then plugging it back in , still not getting cold..Looked at back and everything looks fine..Except..T
Replace the fridge compressor with another one, try a Google search and maybe you'll find result's for your specific fridge. If all else fails, then ring up your fridge manufacturer and talk to them about your fridge, and if you still have warranty and you complain hard enough, they might just send in a new compressor.
Dec 10, 2012 | Haier HSB03 Compact Refrigerator
I have a mini red bull fridge...
Open up the compressor area and trace the wiring. The thermostat should be indicated on the wiring diagram, which should be pasted on the cabinet.
It just may not be obvious without a conventional knob, but it will have a thermal sensor tube- usually copper. It might be bonded on a sheetmetal panel inside the fridge. at least one wire to the compressor's mag starter will be attached to that thermostat to interupt power. It would be adjustable with a small flat bladed screwdriver. Clockwise should lower the temperature, and counter clockwise should raise it. To further complicate it that adjustment screw may be under a dab of red paint that used to anchor it.
Put a thermometer in the fridge to monitor the temp. While water will freeze at temps below zero, Sodas will not normally develop ice until below 30 degrees F and and beer will be fine to about 15 degrees F before it freezes.
Apr 02, 2012 | Refrigerators
My Sub Zero 550 model seems like it is running all the time. It is too cold in the refrigerator compartment,and the condenser fan runs constantly. Adjusting down the temp control has no effect. Freezer...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
Dec 15, 2010 | Sub-Zero 650 / O Bottom Freezer...
Produce freezing in fridge
check your door seals and replace the thermostat controll and adjust the vent door cables
Jan 14, 2010 | Maytag MTB2456G Top Freezer Refrigerator
The lower part of my refrigerator is freezing everything (temp. approx. 30 degrees). The upper part of the refrigerator is almost 45 degrees.
it is possible that the circulating fan is knacked. cold air drops so the bottom of your fridge so will be alot colder than the top, especially since the air will no longer be circulating.
Dec 04, 2009 | Amana ATF2136ARB 33" Top Freezer...
Fridge won't stay cold
How to check everything
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 08, 2009 | Refrigerators
Haier hrt02wnc compact refridgerator 1.7 cubic
I have a Haier mini fridge model hrt02wncbb it will not cool, The fan runs all the time. I keep it in my class at school but there is five other mini fridge they work find what should i do?
Apr 13, 2008 | Haier HRT02WNC Compact Refrigerator
After my mini fridge was left open over night, it doesnt get cold anymore....
Being left open can let lots of moisture in that can freeze up the air circulation paths. First thing is to leave it off and unplugged for a couple days to melt any hidden ice build up from being open all night. Then start it up like normal and see if it works properly. If not then repost and we'll go from there.
Jan 09, 2007 | Haier HSB03 Compact Refrigerator
Refrigerators Logo
668 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
