Heat Pump operation
Have a Mitsubishi Model SRK25ZDXA unit in my office and was wondering where I can get an instruction sheet from
  • 56 Answers
You should be able to google the information you have. Most companies have a tech support line or a place to download a PDF file. Hope this helps good luck.
Posted on Feb 12, 2009
Should the heat pump stop when it reaches temp?
Check to see if you have fan on automatic or continuous run ,it should have a setting so you can get air flow at all times or just when unit runs
May 18, 2015 | Mitsubishi Heating & Cooling
Kennmore combo window unit will not blow hot air what could be the problem
That all depends on the model number of the unit you own. Some window units have electric resistance heat (like a toaster), where others are a heat pump. Even other models have heat pump ability, with added backup resistance heat.
Then again it could be a settings problem. Ifd the unit is not set in the right mode, and the thermostat is not set correctly, the unit may operate and not produce heat.
Jan 08, 2015 | Heating & Cooling
Mitsubishi Heavy Industries Cassette Out Door Model: FDC506HES. What is the BTU size?
1 ton of ac is 12000 btu. you should probably call mitsubishi they have a tech support that will help you with this. the number is usually in the paperwork that came with the unit. you may find it on the tag where you got the model number
Oct 15, 2013 | Mitsubishi MSZ-FE12NA MUZFE12NA Mr Slim...
How to use mitsubishi heat pump remote
i have a mitsibishi heat pump which i purchased 2years ago but have missed place the instruction manual are you able to help me with this. the problem i am having is setting the right temperature and function that i need.the model is msz-ge5ova, thank you
Jun 02, 2012 | Mitsubishi MSZ09UN Air Conditioner
I have a Mitsubishi mini split system heat pump model MSZ-A12NA. The problem is the wireless remote has been lost. How do I get another one? Or, can a regular hard wired heat pump thermostat be used? I...
just lift the filter panel on front of indoor unit and turn it on manually,remember this just sets the a/c to 24 deg,the unit decides whether to heat or cool it to 24 deg....at least it gets it goin so u can order a replacement
Feb 21, 2011 | Mitsubishi MSZ-A12NA Air Conditioner
I have an older Mitsubishi split system heat pump. The outside condensing unit needs to be replaced. It is model # MUH09DW11 with 115 volts @ R22 coolant. Where can I buy just the outside system?
Due to the fact that R-22 has been phased out on all new equipment the chances of finding an outdoor R-22 unit is highly unlikely....The best chance may be to contact Mitsubishi directly and see if there is any old stock still around.
Here is a tip about how to contact Mitsubishi...
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the Mitsubishi line. The manual include both troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Oct 06, 2010 | Mitsubishi Heating & Cooling
I HAVE A GOODMAN CPL E30-1 , HOW DO YOU CHECK THE HEAT STRIPS ARE WORKING ? WERE WOULD CHECK THE TEMP AT ?HOW CAN YOU TELL IF THE HEAT PUMP IS WORKING RIGHT .WHAT IS THE COMMON THINGS A TECH SOULD CHECK...
First, you need to get the spec sheet for that unit from www.goodmanmfg.com, go to bottom, click on Partner link, then put in goodman for id, dealer for pass, go to InfoFinder in the Toolkit. under model, put CPLE, under lit type dropdown put spec sheet. Click on the RED SS number in the fourth column. In the spec sheet, print out the Expanded Heating Data sheet for your CPLE30. It shows the outdoor ambient temp, follow that column to the bottom and it shows the pressures you should have. They are very very close it unit is working correctly. It also has a DeltaT for airflow. So, now you can put stat at 1 degree differential so only heat pump comes on and check temp rise and pressures. If both pressures are low, you have lost some charge. As for heat strips, turn stat up 2 or more degrees or put it in Emergency heat. Then the strips should come on....sequencer may delay stages. Then you need to use amp clamp to see if individual heat elements are pulling amps. In E heat, you need to go online and get a CFM/Kw temp rise chart. It will show you what your temp rise from return to supply should be at your cfm with the amount of heat you have..i.e. 10kw, 15kw, etc. If it is cold out and your heat pump is running with no aux heat, the temp rise will get lower as the outdoor temp falls, so alone it will not be able to keep up.
Jan 11, 2010 | Goodman PHKJ048-1 Air Conditioner
Mitsubishi heatpump not blowing out heat.
One reason could be a shortage of refrigerant. Another could be incorrect mode selection? Or the reverse valve which changes the unit from cooling to heating is either not being energised or may be blocked and would have to be replaced.
Mar 09, 2009 | Heating & Cooling
HEATER ISNT HEATING UP THE ROOM ENOUGH
It sounds like the space is too large for the BTU capacity output of the unit.
Did the unit ever heat the space?
Have you measured the temperature of the incoming air, vs the discharged air?
And finally, based on the Model number in the heading of this thread, this unit is cooling only, no heating (it's not a heat pump).
Jan 11, 2009 | GE AJCQ08ACB Air Conditioner
Heating & Cooling Logo
140 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
