Question about Fossil ES9944 Wrist Watch
My watch will stop winding..
I chnaged the batttery yesterday but when i got home it stopped again..
  • 2,071 Answers
Your watch needs to be clean thats why its stop ,the battery is new but not working it is a symptom of the oil in the machine of your watch is sticky already needs to replaced and cleaning.
Hopes it may helps you;
Regards;
VOTIT
Posted on Feb 11, 2009
I received watch for x mas and Sat 4/2 it stopped wound it and it stopped again 4/4 is it not getting enough light or do I have a bigger issue. Thanks
Eco-drive watches do not need winding or batteries, so if you are winding it to make it work, then it is not a true Eco-drive watch.
Apr 04, 2016 | Citizen Eco-Drive watch
Watch has stopped working
I would guess that the battery is dead. If you take it to a jewelery counter in a department store they can check it for you. Best of luck.
Nov 23, 2013 | Swiss Army Victorinox Chrono Classic Mens...
Stops after i take it off, I have to shake it to get it going again, problem is intermittent, I have no clue...
Your watch is self winding and will run down (if fully wound) for about 2 days.
This type of watch thrives on use and if not used will stop. To avoid having to re-wind by shaking, it should be worn every day.
(Some makers say that to full wind up their self winding watches, they need to be shaken (gently) aboiut 200 times).
Apr 15, 2011 | Rolex Daytona 116520 Wrist Watch
Fossil blue bq9307 Watch stopped, how do I get it running again? I'm told it winds automatically with wrist movement, no battery? Thanks for any help you can give
If it an automatic watch, it usually marked as such on the front or back.
To wind a self winding watch, shake it gently from side to side for a few minutes.
This type of watch thrives on use and if left off for more than 2-3 days it will stop.
Feb 07, 2011 | Watches
Omega constellation self winding watch stops
Omega claim that your watch will run for 40 or more hours, so stopping overnight should not happen. I doubt if you need to be particularly active to wind up the watch, otherwise this would make the problem quite common. My one experience of owning an automatic did not raise this sort of problem.
Discuss your problem with your supplier and describe your use. As you correctly say, having to hand wind i defeats the point of buying an autoamtic. (It could be that you have been sold two duff watches, however unlikely this may seem, it could happen).
Jun 06, 2010 | Omega Constellation 95 1262.15 Watch for...
Tag Heuer Tiger Wood Golf WAE1111.FT6004 Watch stops when not worn. Is there a problem
An automatic watch needs to be worn, wound daily or placed on a watch winder to keep it going. It is not like a quartz watch that has a battery and can keep going when not worn. A modern automatic watch will run for about 36 - 48 hours on a full wind.
A quartz watch that stops like you describe is in need of a cleaning by a professional watchmaker. When this stopping occurs it is an indication the oils have dried out and the warmth from your body heats them so they are semi liquid again and the watch runs. but when the watch cools again the oils harden and the watch stops.
Hope this helps,
Ken
Yellowstone Watch, Inc.
www.yellowstonewatch.com
May 21, 2010 | Tag Heuer Tiger Wood Golf WAE1111 Watch
Bulova Millenia 100 m,stops running,move it to wind,starts up
When you say "wave wind" do you mean you're waving it around to wind it with the self-winding mechanism? If so, that will only keep it running briefly as you're experiencing. Manually wind the crown about 40 turns clockwise to "fill the tank" and wearing it daily will keep it topped off. Anytime you don't wear it for a day, manually wind it again. As for the cleaning, the inside of the watch doesn't get real dirty but over time the lubricants wear out and thicken which makes the watch run slowly or not as long as it has to work harder to move the gears through the thickened lubricant. A watchmaker can disassemble and clean the old lube out with solvents and then reassemble the watch with fresh lubricants.
Apr 27, 2010 | Watches
Watch winding is not holding
Two words: Wind it! When any self-winding (automatic) watch runs down from not wearing it you have to manually wind it to get it going again. Once you've done that the movement of your wrist will cause the self-winding rotor mechanism to keep it running as long as you are reasonably active and wear it everyday. Just wind it about 40 turns and you'll be good to go. Oris is a great watch company and you should enjoy it for many years.
Apr 16, 2010 | ORIS Watch TT3 Day Date 63575887067MB
Is it good to change watch movement to a battery ?Watch was overwound.
There is no such things as over winding a watch. If it is not an automatic watch then the watch will wind until it stops. If the watch does not run then something else is wrong.
If the watch is an automatic then about 30 winds will fully wind the watch. But, you can continue to wind the watch forever. It will never stop winding. Again, if it does not run after being wound there is something else wrong.
To fix your watch you need to have a qualified watchmaker repair it for you.
Hope this helps,
Ken
Apr 08, 2010 | Kenneth Cole KC1104 Wrist Watch
Watch stops
sounds like the oil is contaminated and causing undo friction or the main spring is ether broken or slipping. Time to service your watch. call me 707-338-3207 www.finewatchmaking.com
Mar 01, 2007 | Ebel Tarawa Automatic 9127J40/5435136...
Fossil ES9944 Wrist Watch Logo
305 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
