Question about Wells F-67 21167 Deep Fryer
The trouble light won't go off. How do i fix it?
I pushed the reset button, but the light won't turn off.
  • tom_denise Feb 20, 2009
    We tried unplugging it several different times. We have even left it unplugged for days. We will try to contact the manufacturer.
    Thanks for your help.
  • 979 Answers
You may have to unplug it for about 30 seconds to see if it resets. if not, I believe there is a code or sequence you can follow to turn it off. You can get this from the manufacturer.
Posted on Feb 15, 2009
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
Simply won't turn on. All the power at the plug has current but nothing when you push the on button.
Gary, Could be power supply failure. Links below for trouble shooting your problem.
How To Fix Laptop That Won Turn On
Laptop not powering up won turn on Fix Solutions
My laptop won turn on when push the power button
Here What to Do When Your Computer Doesn Turn On
Feb 26, 2016 | Computers & Internet
Harley trouble shooting
First, check for any error codes:
The speedometer is capable of displaying & clearing speedometer , tachometer TSM/TSSM , HFSM , ECM , ABS Diagnostic Trouble Codes also known as DTC's.
1 - Turn the ignition switch to off & run/stop switch is to run .
2 - Push odometer reset button in & HOLD .
3 - Turn the ignition switch on and then release odometer reset button . The background lighting should illuminate & the speedometer needle should sweep it's full range & indicator lamps ( battery , security , low fuel , check engine and cruise ) should illuminate . The word "DIAG" should then appear .
4 - Push the odometer reset button once and you will see the selection menu "PSSPtb" with the first P flashing .
5 - Each letter represents a area of the diagnostics module . The module that is flashing is the one you are going to check . To move from one letter to the next you must push the odometer reset button one time . ( from P to S to SP to t to b and back to P , ect ect )
P = ECM
S = TSM/TSSM/HFSM
SP = speedometer
t = tachometer
b = ABS codes
6 - To get the DTC code in a area of diagnostics you should PUSH & HOLD the odometer reset button in for 5 seconds and the release . If there are any DTC's the code will be displayed or the word " none " will appear if there are no DTC's . Push the odometer reset button again to view any additional codes if they exist .
7 - Record the codes .
8 - If DTC's are NOT to be cleared , press and release the odometer reset button . Part #of module will be displayed .
9 - If DTC's are to be cleared for that module , PRESS & HOLD the odometer reset button until " clear " is displayed .
10 - Press and release the odometer reset button to continue to the next module .
11 - Turn the ignition switch off to exit the diagnostic mode .
If you DO get any error codes, repost them for diagnosis.
Aug 05, 2014 | 2006 Harley Davidson FLHR Road king
Justanswer com
It's not a button, it's a process that has been the same since 2001. In addition to what is below, there is a list of diagnostic codes as well. Let me know if you don't have them. Too long for this post. Here it is. Thanks goes to Road Captain:
The IM (instrument module) is capable of displaying DTC's (diagnostic trouble codes).
Speedometer Self Diagnostics: The speedometer is capable of displaying and clearing speedometer, tachometer, TSM/TSSM and ICM/ECM Diagnostic Trouble Codes (DTC).
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting should illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word "diag" should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted)
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC's the code will be displayed or the word "none" will appear if there are no DTC's. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC's are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC's again by repeating steps 1 to 9. If the code is current it will reappear.
9 - Press and release the odometer reset button to continue to the next module.
10 - Turn Ignition switch to OFF.
On models not equipped with a tachometer "No Rsp" will appear when the tachometer identifier is selected.
"No Rsp" will also appear if the run/off switch is in the off position when doing this procedure.
Also if the code set is a historic code (not a constant light) after 50 start and run cycles of at least 30 seconds each in duration, the light will extinguish itself as long as the error hasn't occurred again.
If it were a current code, the light would remain lit while running.
Jul 16, 2014 | Harley Davidson FLSTC Heritage Softail...
JBL Flip won't turn on
this doesnt help. how can i get back on?
Jan 11, 2013 | Harman Kardon JBL Flip black
It won't power up. I have tried all of the "normal" fixes.
Does it start , lights come on and shutdown in a few seconds? Can you describe what happens when you push the on/off button. BOTH? Do you have them on a battery backup/surge protector? Need more info.
Dec 09, 2012 | Acer Power FH PC Desktop
Describe your WD-62725 62 in. Rear Projection HDTV-Ready Television Problem Green light is blinking the TV won't turn on. We've unplugged it and tried to push the reset button and the green light...
If the led light flashes green continuously, the fault came from the DM power supply. The faulty parts there are the electrolytic capacitors. Let me know if your handy with electronics and I will assist you to fix it yourself.
Jdvillanueva
Sep 16, 2011 | Mitsubishi WD-62725 62" Rear Projection...
My coby kyros won't turn on, won't charge, no lights are coming on
Mine does that to but all I ever do it just hit the reset button on the back and it turns back on.
May 18, 2011 | Coby Kyros 716829701508 Tablet PC
Check engine light is on
you have a trouble code,to get the code push in and hold speedo reset button and turn ignition on speedo will read diag. release button and push again to see the code,make sure you write them down then clear them out by pressing and holding the button.Then after you record them and erase them turn ignition off. then turn ignition on again and off then check the speedo again and if any of the same codes come back it is a current trouble code
Apr 11, 2010 | 2005 Harley Davidson FLSTN- FLSTNI Softail...
Wells F-67 21167 Deep Fryer Logo
134 people viewed this question
Top Wells Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Raymond Koonce
Level 1 Expert
Dennis Boxerman
Are you a Wells Kitchen Appliances - Other Expert? Answer questions, earn points and help others
