Question about Sony FD Trinitron WEGA KV-32HS500 32" TV
DVI port on Sony Trinitron KV-32HS500 not standard.What fits it?
I'm trying to cable connect from laptop computer to Sony Trinitron for webstreaming. I was sold a "standard DVI male plug" from Tiger Direct that has one larger horizontal piece with has two pins above as well as two pins below this horizontal metal piece on their plug, with several pins on the other end. Meanwhile back at the ranch, on the back of the Trinitron there are two vertical slots and a smaller horizontal slot on the right with various pin slots on the left end. I bought the TV used from a friend's son who conveniently forget to give me the cable and owner's manual before he moved 5 states away (first state being Texas). Any and all rational ideas will be considered.
While typing this I am speaking to Sony and am being told this port labeled DVI is for DVI-HDTV and not for computer webstreaming......any way around that?? Anyone in south Texas want to trade a great TV for one that will receive webstreaming????
  • 1 more comment
  • pistache Mar 19, 2009
    did you find a solution for this?
  • Anonymous Mar 24, 2009
    Any updates on this issue? I am in exactly the same boat.
    Thanks in advance
  • jarblue938 Apr 29, 2009
    I have a similar problem, as I am trying to use the TV as a second monitor for my office set up.  I did get the TV working as a computer monitor via the DVI connection, but it will only display in 16:9.  The other problem is getting the resolution correct.  My UltraMon software will not recognize the TV as a second monitor, so I have to use my nVidia control manager.  I found a forum that said the Hi-Scan Trinitrons (which is what this TV has) have a display resolution of 853x1080, but it still looked stretched.  If I find a resolution that works, I'll be sure to post it.
    I have found the problem to be associated with the way this TV displays from any HD-capable source (read HD as 1080i or 1080p).  Whenever you connect a device to the DVI port the TV will only display a 16:9 ratio (I think this is a terrible design given the TV is 4:3, but there's nothing you can do).  The same thing happens when you hook up an HD device via the component inputs.  However, if you hook up a non-HD device to the component inputs, the TV will display 4:3 at full screen and will letterbox anything 16:9 (i.e. it will act normal, but not HD).  For example, my HD cable box connected to the TV via component cables displays all HD channels in 16:9, but crops non-HD channels to 4:3 from within that 16:9 screen (which makes all my regular cable channels super small in the TV screen).  But if I plug my Sony PS2 into the TV via component cables, it will display games full screen and movies at 16:9 ratio (because the PS2 is not HD-capable).
    BTW, I solved my cable problem before by connecting both component cables and composite cables for HD and non-HD channels, respectively.  The biggest pain was this makes me switch the TV's input everytime I switch from HD to non-HD channels or vice versa for it to look right.
I've just recently connected my old 32" Sony KV-32HS510 to my HP G60 Laptop via an HDMI (laptop) to DVI HDTV port(TV) with a cable.
I'm running Windows Vista on my laptop with the nVidia software. Once I've plugged in the TV to the HDMI port, the software initializes (recognizes the TV) and then I can select it as my second 'monitor' in the nVidia control panel.
I found I had to tinker with the resolution settings in the nVidia program to find an optimal resolution where the sides of the screen weren't 'cut off' by the TV.. I finally ended up with the resolution 1152x768 (I believe). It might be different for everybody, as I'm told Vista might do things differently than XP... But you should be able to tinker with the resolution settings and adjust the screen size...
(hope this helps with the second post - above)
Posted on Feb 05, 2010
  • TheRealSneak Feb 05, 2010
    ^^^ As for the first question, it sounds like you might have the bought the wrong DVI connector cable. I noticed there were a few different layouts of pins on the various types of DVI connectors available.
    You mentioned:
    "While typing this I am speaking to Sony and am being told this port labeled DVI is for DVI-HDTV and not for computer webstreaming......any way around that??"
    - I think Sony 'recommends' that you don't use the TV as a full-time monitor for your computer. This is to avoid having the desktop displayed on the screen too long and suffer from "Screen Burn". I think it's worse on Plasma tv's.
    I've started using the TV (my Sony 32" KV32HS510) as a 2nd monitor to view streaming webvideo recently, and it seems to have no ill effects.... Then again, maybe there will be long term side-effects, but I figure since I'm just using the TV intermittantly, I'm fine. The picture looks great!
    I've attached a small schematic showing the pin lay-out of the back of the TV (my TV) for the DVI plug... You'll notice the configuration of all the pins..
    ..I know that post was quite old, but I hope this helps anybody else trying to hook up their Sony TV's via the DVI HDTV plug. Seems to work great thus far!
    http://upload.wikimedia.org/wikipedia/co...
    Just attached this link to show you the different types of DVI connectors. The Sony TV I use uses the 4th connector down (in the link) the "DVI-D (dual link)" this is the configuration of pins that you want to buy for the DVI - HDTV connector in the back of your TV. (at least on my Sony KV32HS510)
I tried the recommended cable to the TV, but I cannot get a picture. I have a Sony HSKV32HS500. I attached a VGA cable from the PC to the HDMI adapter I bought for the TV. I fired up the PC and went thru all the various options from the remote trying to find the right mode on the TV. Nothing worked! It does not display anything from the PC. What option did you find that worked?
Posted on Mar 06, 2010
I recently bough a used 40in sony trinitron xbr. i have the DVI to HDMI cable but wether its my laptop or xbox the sound wont come through the tv at all. any suggestions?
Check the audio cable it might not been connected securely.
Could also be missing.
Even with the HDMI you may still needs it ( DVI is for video only).
DVI means Digital Video Interface.
Sep 26, 2012 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Prende dos dias y dos dias no prende asta que se enfria ojala y me pueda ayudar la tv es una sony trinitron de 32 pulgadas mod kv-32hs500
trata de resoldarle todas las resistencias y piezas que veas con soldadura fria.si hay piezas con soldadura fria ellas se mueven y no hacen contacto, los sony's padecen mucho de eso.espero esto te ayude.
Apr 23, 2010 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony trinitron KV-32HS500 won't turn on, stand by lights flash 7 times. If we leave it off for a day or 2 then it will start again. What is wrong and how do I fix it?
I have this Sony KV-32HS500 DA-4 chassis complete service manual,i can email you the power supply circuit or any other parts you may need.Its about 18 megs in size.
Sep 06, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony FD Trinitron WEGA KV-32HS500 32" just stays on standby & blinks 7 times give no indication there were any probems.- wont turn on when you push the power button it acts like it is going to come on...
we have the same porblem. We just unplug ours and wait a couple of weeks while watching another tv plug and un plug it will eventually come on then we dont turn it off again it only goes off if the power goes off.
Jun 07, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony tv will not turn on
the power supply is a switched mode. you need to take your tv to a w/shop, and let them check the following.
powersupply rectifier diodes, power trasistor lekage,
diodes, zener diodes,
if a 90-110 volts to the line trasistor,
a line transistor be checked.
the tv simple problem
Mar 29, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony trinitron KV-30HS420 HDMI
Yes. As long as your PC has an HDMI port as well (or at least a DVI port and a DVI-to-HMDI converter dongle).
Jul 10, 2008 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony KV 32HS500
what is the blinking pattern? blink pause blink
Jan 14, 2008 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony Trinitron kv-32hs500
plug out the tv and let it stand for about 2hrs so that it can reset itself if that does not work take the set to a tech for repairs the problem is in the power supply and related circuits good luck.
Apr 02, 2007 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony FD Trinitron WEGA KV-32HS500 32" TV Logo
4,474 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
