Question about Philips SINGLE HANDSET USB VOIP PHONE
My phone will not charge
When its in the charger it lights up but when you lift it out the phone goes off completely . put it back in the charger base it lights up again .please help with the problem thanks
  • babykj87 Feb 24, 2009
    i will sure try it and let you know thanks for takin the time to help me :) kris
    Novelist:
  • 180 Answers
It sounds like the battery is a goner but I wouldn't swear to it without having another to test it. Over the course of the last month or so, did you notice that the battery life was shorter and shorter? It will look like it is charging but holds no charge whatsoever upon removal from the charging base. The best way to test this, of course, is to install a new battery. Finally, is this an older phone or a new one? Rechargeable batteries are good for about 2 years, less if you don't let it fully discharge and recharge although in the newer types it's not as much of a problem. Let me know what you find out.
Posted on Feb 11, 2009
  • Victoria Anderson Sep 30, 2011
    Thanks. I will try a new battery. The phone is older than 2 years.
How to activate a vtech phone
Instructions
    • 1Remove the battery cover from the back of the phone. Most models have a door that slides downward to reveal the battery compartment.
    • 2 Install the battery by inserting the connector on the battery wires over the pins in the handset battery compartment. The connector will only go on one way.
    • 3 Insert the battery pack into the compartment and replace the battery cover.
    • 4 Charge the phone by sitting it in the charger for a minimum of 16 hours on the first charge.
    • 5 Place the fully-charged phone onto the cradle of the base unit and wait for the display to show "PRESS FIND HNDST 4 SEC ON BASE." If the message does not come up, lift the phone off the base and put it back in the cradle.
    • 6 Press and hold the "FIND HANDSET" button on the base unit for approximately four seconds. The display on the phone will change to "PLEASE WAIT," then "HANDSET X REGISTERED."
    • 7 Test the phone by making a call.
Jul 14, 2014 | Vtech Lands Phones
I am unable to set handset to work with the base. Its panasonic KX-TG5933Al
Registering a handset
Important:
If you accidentally assign another
handset's extension number to the base
unit, the originally assigned handset
stops functioning. Confirm the extension
number of the handset by placing it on
the base unit or charger. Lift the handset
from the charger before registering.
1 Handset:
{MENU} i {0}{0}
2 Base unit:
Press {SELECT} until the desired
extension number (H1, H2, H3, or
H4) is displayed on the base unit, then
press and hold {CALL} until the
CHARGE indicator flashes.
LH4 can be used if you have 4
handsets.
LAfter the CHARGE indicator starts
flashing, the rest of the procedure
must be completed within 1 minute.
3 Handset:
Press {OK}, then wait until the handset
beeps.
For futher information, see the phone manual at: http://dl.owneriq.net/3/3cd5d5a0-865d-4a28-8a1f-91f144108d9d.pdf
Mar 22, 2011 | Panasonic Computers & Internet
Hi, I have two GE 2.4 ghz cordless phones in my home. The base of the charger always has a blinking red light. That phone doesn't hold a charge very long. It it the battery or the charger? I emailed GE and...
batterys don't normally last long as constant charge with short breaks are bad for them. i'd bet the battery. does that happen with both phones?
\put a multimeter to the pins on the charger. my tongue tests 9 volt batterys
Jun 09, 2009 | Uniden Cordless Phone
PL-CS55 headset lifts receiver but only get buzzing sound in
Try a system reset:
1. Lift the headset off of the charging cradle (the base).  Make sure the headset is turned off.  The green light on the base won't be on if the headset is turned off. 2. Hold down the call answer button on the headset at the same time as mute button.  The mute button is found on the little black wheel on the top of the headset.  Use the tip of your finger to push it straight in. 3. Hold both buttons until you see a green light on the headset flash.  It will be right below your thumb.  Hold both buttons until the green light flashes for a series of 2 flashes.  Then let go of both buttons. 4. Put the headset back on the charging cradle and wait 30 seconds.  Lift it back off and try again. 5. If this doesn't work repeat the process once more or try a resubscription.
Resubscription procedure:
1. Put the headset back onto the charging cradle.  Make sure the red light on the base is on and the yellow light is flashing. 2. On the back of the base there are two buttons for the microphone adjustment that can be pressed down.  Press both of those down until the red light and yellow light on the front of the base start flashing. 3. While the headset is still on the charging cradle press and hold the mute button until the red light on the base goes solid, and the yellow light stays flashing. 4. Unplug the power to the base and then plug it back in. 5. Wait 20 seconds and try.
Apr 22, 2009 | Plantronics PL-CS55 Wireless Headset
Dewalt base charger unit
. The light on the charger will blink on and off during the charging process and will remain on when the charging process is completed.
Jul 21, 2008 | Dewalt 18 Volt Compact Drill Kit
My enV will not charge!
Hey i think i just figured out the problem to all the port charging issues for the envy and envy 2 phones with verizon. its not the phones, its the charger cord! the part that goes into the phone. it gets pulled out over time from pulling the cord out of the phone all the time. get a pair of pliers. grab the end and push the metal end of the cord against somthing hard, push it back in so it is at the appropriate depth. this should make it charge properly again!
Jul 17, 2008 | LG enV VX9900 Cellular Phone
Charger light
I had this same problem and all I did was to unplug the DC adapter at the phone and plug it back in after a few seconds. The solid charge light came on immediately, like usual. I let the battery charge for several hours before using the handset again.
Apr 06, 2008 | Uniden Cordless Phone
Main base not charging
no you need a new battery. Hope this helped you
Nov 18, 2007 | GE Thompson 25901EE1 Cordless Phone
Charging the Mx700 cordless optical mouse
I found the following:
Red light slow blinking: Battery Low, please put mouse in charger and charge;
When in Charger Red light Slow Blinking: No charging, please check and clean Gold Plated contacts in charger and Mouse;
When in Charger green light Blinking: Charging in progress
When in Charger green light Steady: Charging complete
When in Charger Red light Fast Blinking: Mouse detects overvoltage during charging! Please clean Battery contact inside Mouse, or replace rechargable batteries NiMh 1500-2100 mAh only
Oct 02, 2007 | Logitech MX700 CORDLESS OPTICAL MOUSE...
Phone charging indicator light
register phone instuction
May 22, 2007 | GE 25861GE3 Phone
Philips SINGLE HANDSET USB VOIP PHONE Logo
176 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
