Question about Kenmore Refrigerators
Older glenco fridge
Fridge isn't cooling i have dusted condenser and took ice off a coil on the inside of fridge and still not cooling
  • 27 more comments
  • tonemfone Feb 11, 2009
    it was not frost. it was hard ice about the size of a baseball. it was on the coil that came from the 1-7 cooling setting knob if that makes sense the coil was not connected to anything
    it was ice and it was on a wire maybe not a coil i am not hip with the proper lingo of fridge parts and there was ice on a 3/8 tube and all those are connected
    it is a two door frigerator its a glenco
    the condenser on the bottom of the unit is cold to the touch does that help any
    there is no frost any where in or on the fridge and the wire is not connected to anything just comes from the cool setting
    where is the evaperater is that the thing behind the fan that blows on the condenser under the fridge and if so that is hot
    could it be the thermostat
    i think so keep going
    i have a fridge no freezer in between the two sides is a fan and a radiator looking deal and under there is a condenser, a fan, and a bowling ball looking thing
    and both fan are running yet the fridge is not cooling i took off all ice and dusted the condenser under the fridge and still no cooling
    no meats just beer
    someone told me it may need freon but can it be the thermostat that is failing
    side by side
    yes i am here and yes the fan can be heard
    there is no frost
    thanks for the help i will keep that in mind
  • robert samples May 11, 2010
    thats what we are trying to find out did you open the left door look for frost on the back wall and see if frost is there and if you hear a fan running
    you still there
    ok the door on the left hand side should be the freezer side open it look at the bottom and see if you see frost now there is a difference between a freezer and a deep freeze all side by sides have a fridige side and a freezer side ok when you open the left side door do you see frost and do you hear a fan running the freezer side does all the colling for the whole unit roger that
    lol roger that tell me about the two doors is one on top one on bottom or are they next to each other side by side
    where do you keep your frozen meats
    if you got two doors one is the freezer and one is the fridigare the bowling ball is the compressor are the two doors on top of each other or side by side each other
    ok now is your freezer on top or to the side of the fridge and when you open freezer door do you hear a fan sorry about all theese questions but you got to be my eyes
    evap inside freezer behind a panel
    lets do fridges 101 the freezer does all the cooling for the whole unit the coils in the freezer are called the evaporator the coils on the outside are the condenser now freon absorbs heat in the freezer and carries the heat to the condenser coils and lets it go to the kitchen etc have you looked at the evaporator coils inside the freezer the prob your describing sounds like a leak in the system or a restriction in whats called capillary tube which is a tiny tube going into a 3/8 tube at the evaporator coil with me so far
    do you know where the evaparater is the condenser should be under the fridge and should be hot
    ok did this wire connect to a siliver hony comb looking part and look at the bottom of the freezer side and see if its covered in frost
    first off how old is this unit yes it makes sence thats the thermostat now is this a top freezer or a sxs
    describe the ice on inside coil tell me if its ice or heavy frost and location on the coil
    President:
  • 1,314 Answers
If the fan is running in there and there is no frost then sounds like a leak and id reccomend replacing if its as old as you say it is if the bowling ball is running then the thermostat is good
Posted on Feb 11, 2009
I have kelvinator fridge it doesn't cool in both compartment we replaced the compressor il coold down for only 3dayes then returned back to hot state
is the condenser fan running back there?also did you clean out the condenser coil?usually when the middle strip gets hot the coil is filled with dust or the fan where the compressor is isn't running.the condenser fan keeps the compressor cool and all the heat from the machine escapes out through the condenser coil.check this,also the start device could be bad on the compressor,send model number next time you write so whoever helps you can look up your machine.hope this info helps you out.
Sep 15, 2012 | Kelvinator Refrigerators
Display problem and not cold
sounds like your internal control board took an early retirement. You up to doing this yourself, or do you want to search the repair listings for someone nearby?
May 25, 2008 | GE Profile PFS22 33" Artica French Door...
My fridge gets really hot on top and between the fridge and freezer where the door meets
next time send the model number and brand name.usually when this happens is the condenser fan motor isn't working.pull the fridge out,remove the bottom back panel and check the fan to see if it's working,if it is check the condenser coil to see if it's filled with lint and dust,it could just need to be cleaned out but if it's that hot most likely the fan isn't running,if you get this tonight check it now,if the fan isn't running you could blow the compressor,the condenser fan blows and keeps the compressor cool enough so it doesn't overheat by moving the hot air and the heat also esscapes through the condenser coil so if that's clogged with dust the machine will run hotter than normal,if the fan isn't running you can stick any window fan back there and blow it onto the compressor to keep it cool until you fix the condenser fan motor,this way you won't loose any food and if the compressor goes it's new fridge time,to much to repair.hope this helps and good luck with your machine.one more thing,i've found the fans not running and by pushing the blade it runs again,if this happens the fan could run and never have a problem or it could stop an hour later but i would change it out no matter what.if it's a G.E. fridge and the motor isn't running,most likely it will be the computer board,i've found 10 machines doing this and the temp. settings turning on and off or the evap fan motor in the freezer runs slow and then fast and the condenser fan isn't running or running slowly,this is why you have to send the brand name and model number.
Oct 28, 2011 | Refrigerators
It seems the fan goes on more than it should. How often should it go on?
Both fans should run when the compressor is running. Dust on the condenser coil under the fridge can cause it to cool less efficient. Ice build up on the evaporator coil inside the freezer behind the rear cover will cause it to be less efficient. Heavy ice on the coil is caused by auto defrost failure.
Jan 18, 2010 | Kenmore 50522 / 50524 Side by Side...
Fan not working right very noisey fridge runs all time back of fridge gets hot
replace the fan and it will also cool down the back. the back shoudl be hot somewaht as that is how it cools the inside. its called a heat exchanger. takes the heat from int he fridge to the outside and then the fan cools the coils on the back or underneath the fridge. if the fan is noicy then maybe needs to be cleaned. I foudn that many have dust buildup and that makes it wobble and not cool. Best to repalce the fan 9cheapo to do) and see if that works. Also make sure you vacume the coils in the back of the fridge . They need to have free flowing air to work properly.
Dec 04, 2009 | Televison & Video
My fridge has ice build-up in the freezer behind the inside wall. this ice is on the freezer elements, because of the buildup, the fridge is not cooling.
This sounds like a problem with the defrost circuit. It is likely that the evaporator coil is clogged with ice due to the defrost heater / circuitry not functioning. This can be caused by a failure of any one or more of the following components:
1) Defrost timer. Defrost timer may be "stuck" - failing to advance from a cooling cycle to a defrost cycle. May be found in the toe space of many fridges, but not all.
2) Defrost terminator. This is a thermal sensor that is secured (usually with a clip) to the refrigerant line close to the evaporator coil in / behind the freezer compartment. If this component fails to detect a rising temperature, it never allows the fridge to return to the cooling mode again.
3) Defroster Heating coil. This is a simple, relatively low wattage heater secured to or near the evaporator coil. It is powered through the defrost timer and shut off by the defrost terminator. If the coil is burned out or otherwise "open", it will not heat to melt ice buildup on the evaporator coil.
4) Fan. The fan is located near the evaporator coil. If the fan is unable move air from the freezer to the fridge, the compressor runs endlessly because cold air is not directed into the fridge compartment - where the thermostat is located.
5) Condenser coil. If the condenser has a "furry jacket" it's long overdue for a cleaning. Gently vacuum lint / dust / dirt collected on the coil to increase efficiency. This is probably not the problem - but it probably needs to be done anyway.
Most of these steps will require hand tools, schematics (specific to your model), electrical test equipment, etc. Be careful to not use sharp instruments that may puncture refrigerant lines or electrical insulation. Allow the ice to defrost with the fridge powered off with the freezer door opened, or place a pot of hot water inside, hair dryer directed at the coil, etc. Access to the evaporator coil is usually from the freezer compartment (back wall) and will require removal of any ice maker installed.
I hope this helps!
Oct 26, 2009 | GE Refrigerators
Kenmore refrigerator will not cool. Freezer works
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 27, 2009 | Kenmore Refrigerators
Lights on Freezer and Fridge not working
Aug 21, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Kenmore Elite 596755 - Freezer warm, Ice Melted, then...
did you move it or tip it on its side when these devices are moved sometimes it will create anair pocket in the cooling system after moveing let stand for a few hours before plugging back in.
Jan 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
146 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
