When the temp is above 70 degrees outside my truck shows to over heat but when I check it does not show to be low on water.
Your truck does not have to be low on water to be running hot...you need to verify the tempature of the cooling system, and the head temp...then you will be albe to tell if it is actually overheating , or just an indication problem. Be very careful as hot engine coolant can scald you badly (know from experience)
