Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Parts diagram where can i get a parts diagram with a break down of the vacuum, for a dyson dc07 we need to do some work on ours
    President:
  • 1,214 Answers
You can find the exploded views and replacement parts at www.searspartsdirect.com.
Go to the link and enter DC07 in the field for Model number.
Posted on Feb 11, 2009
Just started use my dyson dc07 it is new but is very noisy after my dc04 broke down.
Your dc04 breaking down is unlikely to be causing the excessive noise of your new dc07 unless you've trying to vacuum up the dc04 with the dc07??
It may be that the operating noise of a dc04 is lower that that of a dc07 however if the noise is excessive then you should get it replaced by the vendor.
Nov 12, 2016 | Dyson DC07 Bagless Upright Cyclonic Vacuum
No sucking when the handle is down
Hi Steven, it's Jack at Dyson.
If your machine isn't picking up from the cleaner head, this may be due to a blockage. The filter may also need a wash. To check for any obstructions, please follow the steps shown in our online Support guide: http://www.dyson.co.uk/support/dc07/dc07-animal/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/wand-suction
In normal use, DC07's filter needs to be washed at least once every 3-6 months, as shown in the video attached. Use cold water without detergent, and allow at least 12 hours for the filter to dry completely before replacing it.
If you do need any further advice after you've given this a try, please get in touch with us directly. You can reach our experts by calling 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Aug 12, 2013 | Dyson DC07 Animal Bagless Upright Cyclonic...
How do you change the belt
If your DC07 is a model equipped with the brush control feature, the belt should not need replacing. If it doesn't seem to be working correctly, it's probably best if you get in touch with us directly using the details provided below, so we can help you resolve the issue as quickly as possible.
If your DC07 is a model without the brush control feature, you can find out how to replace the belt here:
http://www.dyson.co.uk/support/help.asp?article=18&product=DC07-ORIGIN
You can purchase replacement belts from our online store:
http://www.dyson.co.uk/store/partsDetails.asp?part=ACC-DC0104BELTS&product=DC07-ORIGIN
If you have any further questions, or if you'd like to order the belts via our Helpline, please call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Sep 16, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Our upright Dyson has just stopped working. No
There are four possibilities:
1) If in a country that has a fused plug, the fuse in the plug (unlikely). 2) The switch (unlikely). 3) A break inside the cable that you cannot see (quite likely). 3) The motor is shot and needs replacing (very likely).
Jan 10, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Power Button won't stay down/on.
Hi There,
Most likely your switch has gone bad, and you'll need to replace the on/off switch on your Dyson DC07. If you have to hold down the switch in order to keep the vacuum on, this is indicative of needing a new switch. Unfortunately this is very common problem on the Dyson vacuums2_bing.gif . The switch that Dyson uses for their vacuums is one of the cheapest switches on any vacuum on the market today. The good news though is that this is not a extremely difficult repair to fix.
I took pictures of replacing the switch assembly on one of our customers repairs they brought in. It was having the same exact problem that yours is, it just wouldn't stay on. Here's how you can fix the switch on your Dyson:
- T15 Torx Bit Screw Driver
- Genuine Dyson DC07 & DC14 Replacement On/Off Switch Part 901181
- Needle Nose Pliers
- Patience (haha)
The switch above is actually a link back to our site if you have yet to purchase the switch yet. We carry most every Dyson part.
IMPORTANT: MAKE SURE YOUR VACUUM IS UNPLUGGED BEFORE DOING ANYTHING ELSE!
Step 1. First thing you'll want to do is to unwrap the cord from the machine, and remove the handle from the upright part, then slide the hose all the way down the wand, and remove the hose from the handle assembly completely and set it aside. Also remove the dust bin assembly completely from the machine as well.
Step 2. Once you've remove the handle from the machine I find it easier to work on if you lay the vacuum on it's back, with the switch button facing upwards. Now remove the T15 Torx bit screw that is directly below the switch actuator. I have circled the location of this screw in the picture below:
Step 3: After you have taken off the screw, you're doing to need to remove the switch box housing from the vacuum that the screw was securing. Simply use your flat head screw driver, and pry the two small arms upwards. Be careful when prying, the plastic components on Dyson Vacuums are really cheap quality plastic, and I can't tell you how many times I have seen these plastic parts break when customers bring in repairs to us here at govacuum headquarters. Here's a picture of the location of where you should pry the switching off:
Here's what the vacuum should look like after the switch housing has been removed:
Step 4. Use your needle nose pliers to remove the terminals from both of the switch poles.
Step 5. Take out the new switch assembly. I find it the easiest to use my needle nose pliers to reattach the wires to the new switch, but it also can be done with just your hands. Both both wires to your switch. If the cords have come loose while you have been working on the vacuum, you'll need to put the wires back into their proper places as well. This is how the switch and the wires should look like when you're done:
Step 6. Once the switch and cords are back to their normal places, simply put the switch housing cover back on, and screw in the one screw.
I hope that this repair was helpful to you, if you have any questions or have any problems, please feel free to use the clarification request form here on Fixya.
If you ever need any for your Dyson, we do carry most parts and accessories on our site under our Dyson Parts Section .
If this was helpful, please be so kind and leave feedback for the repair. This is really, really appreciated and is the reason repair professionals like myself continue to post free repair help on Fixya rather then just answering the paid questions.
Thanks again,
Chris J.
GoVacuum
Apr 17, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Pipe valve on dc07 same as one on dc 17
Hi there, the parts are not interchangeable, but you can purchase a replacement valve pipe for your machine via our website at www.dyson.com.
Kind regards
Darran
Dyson Customer Service
Apr 11, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Will not stay on.
Hi There,
Most likely your switch has gone bad, and you'll need to replace the on/off switch on your Dyson DC07. If you have to hold down the switch in order to keep the vacuum on, this is indicative of needing a new switch. Unfortunately this is very common problem on the Dyson vacuums . The switch that Dyson uses for their vacuums is one of the cheapest switches on any vacuum on the market today. The good news though is that this is not a extremely difficult repair to fix.
I took oictures of replacing the switch assembly on one of our customers repairs they brought in. It was having the same exact problem that yours is, it just wouldn't stay on. Here's how you can fix the switch on your Dyson:
- Needle Nose Plyers
- Patience (haha)
IMPORTANT: MAKE SURE YOUR VACUUM CLEANER IS UNPLUGGED BEFORE DOING ANYTHING ELSE!
Step 2. Once you've remove the handle from the machine I find it easier to work on if you lay vacuum2_bing.gif on it's back, with the switch button facing upwards. Now remove the T15 Torx bit screw that is directly below the switch actuator. I have circled the location of this screw in the picture below:
Step 3: After you have taken off the screw, you're doing to need to remove the switch box housing from the vacuum that the screw was securing. Simply use your flat head screw driver, and pry the two small arms upwards. Be careful when prying, the plastic components on Dyson vacuums2_bing.gif are really cheap quality plastic, and I can't tell you how many times I have seen these plastic parts break when customers bring in repairs to us here at govacuum headquarters. Here's a picture of the location of where you should pry the switching off:
Step 4. Use your needle nose plyers to remove the terminals from both of the switch poles.
Step 5. Take out the new switch assembly. I find it the easiest to use my needle nose plyers to reattach the wires to the new switch, but it also can be done with just your hands. Connect both wires to your switch. If the cords have come loose while you have been working on the vacuum, you'll need to put the wires back into their proper places as well. This is how the switch and the wires should look like when you're done:
If you ever need any supplies for your Dyson, we do carry most parts and accessories on our site under our Dyson Parts Section .
Thanks again,
Chris J.
GoVacuum
Apr 08, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Power switch does not work. Vacuum only runs while holding down the power button.
Greetings,
Most likely your switch has gone bad, and you'll need to replace the on/off switch on your Dyson DC07. If you have to hold down the switch in order to keep the vacuum on, this is indicative of needing a new switch. Unfortunately this is very common problem on the Dyson vacuums. The switch that Dyson uses for their vacuums is one of the cheapest quality switches on any vacuum on the market today. The good news though is that this is not a extremely difficult repair to fix.
- Patience (haha)
Step 2. Once you've remove the handle from the machine I find it easier to work on if you lay vacuum on it's back, with the switch button facing upwards. Now remove the T15 Torx bit screw that is directly below the switch actuator. I have circled the location of this screw in the picture below:
Step 3: After you have taken off the screw, you're doing to need to remove the switch box housing from the vacuum that the screw was securing. Simply use your flat head screw driver, and pry the two small arms upwards. Be careful when prying, the plastic components on Dyson vacuums are really cheap quality plastic, and I can't tell you how many times I have seen these plastic parts break when customers bring in repairs to us here at govacuum headquarters. Here's a picture of the location of where you should pry the switching off:
I hope that this repair was helpful to you, if you have any questions or have any problems, please feel free to use the clarification request form here on Fixya. If this repair was helpful to you, please be sure to rate the repair helpful by clicking the thumbs up icon in the top right hand coner. This is a nice gesture that will ensure that professionals will continue to post free repair solutions here on Fixya.
Thanks again,
Chris J.
GoVacuum
Mar 28, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Sparking motor on Dyson assume motor brushes at fault?
A replacement motor can be purchased direct from Dyson via our Helpline on 0800 298 0298 at a cost of £36.31.
Alternatively we can arrange a service for £69 which includes parts, labour and VAT. This can also be arranged via our Helpline.
Kind regards
Darran
Mar 02, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
7,531 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
