Question about Microsoft Office Professional 2007 Full Version for PC
Install error in office 2007
I tried all the fixes I could find. does anyone know how to fix the error when installing office that says "microsoft office enterprise 2007 encountered an error during install".
  • 32 Answers
Well, Microsoft finally posted a fix for this problem. If anyone else happens to run into this same problem, here's the link to the procedure.
http://support.microsoft.com/kb/928218
Posted on Feb 12, 2009
Error 25004.config.xml not specified; A valid config.xml file must be authored when deploying '(null)'. i am installing microsoft office enterprise 2007 and i enounter this problem..how will i
If the version of windows installed on your computer is not activated you would face issues to use any applications once the product is expired.
But if you have an issue with office programs with an error 25004 on an activated version of windows
Then the reason might be corrupted installation of office 2007 on the computer.
Uninstall office 2007 manually from the computer then
re-install it and check if it helps.
Apr 25, 2012 | Microsoft Office Professional 2007 Full...
Errors during microsoft office 2007 installation...how to fixed it....
Your installation file may be corrupted. Get a fresh copy of the same and try.
Feb 25, 2010 | Microsoft Office Professional 2007 Full...
I have loaded and activated Microsoft Office 2007 full version (Professional). Every time I go to start an Office application I get a configuration window. It's a bargraph showing Configuration Progress,...
Click Start- type msconfig- choose selective start up and uncheck Load Startup Items, then click on tab Services, cjoose check box "Hide all microsoft services" at the bottom left and click disable all.
Then clecik on apply and ok, restart the system and check
Feb 18, 2010 | Microsoft Office Professional 2007 Full...
I have windows installer keep popping up with homestuden is on a network unavailable and this always pops up when i log on to my computer and also i guess my microsoft.net framework 2.0 service needs...
Error message when you try to install a 2007 Office program: "Microsoft Office <Product_Name> 2007 encountered an error during setup. Error 1714"
To work around this issue, use the Add or Remove Programs feature in Control Panel to uninstall the earlier version of Office. To do this, follow these steps:
  1. Click Start, click Run, type appwiz.cpl, and then click OK.
  2. In the Currently installed programs list, click the Office program that you want to remove, and then click Remove.
  3. In the Add or Remove Programs dialog box, click Yes.
After the earlier version of the Office program is uninstalled, then install the 2007 Office program.
Jan 16, 2010 | Microsoft Office Home and Student 2007...
Error installing MS Office pro 2007 with BCM
Uninstall from control panel the following:
Microsoft SQL Server native client
Microsoft SQL Server Setup Support files
Microsoft SQL Server VSS writer
Move directory C:\Program Files\Microsoft SQL Server\MSSQL.1 to another location for possible use. Delete everything under Microsoft SQL Server in c:\Program Files
Reinstall
Jan 10, 2010 | Microsoft Office Professional 2007 Full...
Getting error code 1923
Error 1923: Service 'Office Source Engine' (ose) could not be installed. Verify that you have sufficient privileges to install system services.
Before you install the original release version of the 2007 Office programs, you must remove all prerelease versions of the 2007 Office programs. Additionally, we recommend that you restart the computer before you install the original release version of the 2007 Office programs.
Oct 12, 2009 | Microsoft Office SharePoint Designer 2007...
MS Office 2007 Professional won't install on my Laptop with XP
yor ms office 2007 cd or dump is corrupt pls try another one
Jun 24, 2009 | Microsoft Office Publisher 2007 for PC
My computer crashed and now microsoft office 07 wont work
I would probably run the following before doing anything else. It may take over an hour to run.
http://www.informit.com/articles/article.aspx?p=1718476&seqNum=5
https://support.microsoft.com/en-us/help/924611/how-to-install-the-individual-2007-office-features-or-to-repair-the-in
If the above does not work, try the below. It may be a bit difficult to determine which system restore might contain the working setting for the 2007 Office as you may have generated several restore points in attempting to reinstall it. If you go back too far, the program won't be available or recoverable. Avoid going back to a point prior to its installation but walk it back to a date where it was working. That is, choose such a system restore point. This may work around your problem with reinstallation.
I am not sure how you are reinstalling the 2007 Office. Did you uninstall it and then attempt to reinstall it or did you try to reinstall it over top of the existing corrupted version? And from what source? If you have an installation file and the software key, you might uninstall the program with something like Iobit Uninstaller or Revo Uninstaller, then try fixing disk errors with Glary Utilities (if you can find a version compatible with your OS). Afterwards, try installing the program from Safe Mode.
Regarding reinstallation attempts, surely it requested the "key" each time you attempted reinstallation. Before you try anything else, you might run Magic Jelly Bean and Belarc Advisor to see what the programs pull up in terms of the serial number (key). If you can't find it, you know why your 2007 Office didn't run.
Sep 12, 2017 | Microsoft Office Professional 2007 Full...
Problem installing office 2007.
go to website www.martau.com download uninstaller and completely remove previous version office. Using this application every entry related to previous version will be removed
Dec 18, 2007 | Microsoft Office Professional 2007 Full...
Microsoft Office Professional 2007 Full Version for PC Logo
164 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
