Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Scanning to PC
I press Scan button, then I select document, Scan to file, then I hit OK. I can not scan a document to my PC. It tells me scanning, and then goes to start window.
    Sergeant:
  • Kodak Expert
  • 285 Answers
try using the kodak aio home center
it is much easier and gives you more conrtol, including editing
dont scan directly from the scanner
Posted on Feb 11, 2009
  • Andrew Perrong Feb 11, 2009
    then you'l need to reinstall the software
I need to scan documents in jpg format. I notice there is an option to choose tif/jpg but I don't seem to be able to choose the jpg option it just keeps choosing tif. How can I scan in...
Everyone above has cut and pasted from the Ricoh manual, which as any tech will tell you is worthless. There is some other setting that must be set to force the "TIFF/JPG" to toggle - hence why no one has figured it out.
Jun 17, 2011 | Ricoh Office Equipment & Supplies
How do I set my canon mx 870 to scan
Hi.
This the user manual scanning using canon mx870.
just follow this step by step.
Select the scan operation.
(1) Make sure that the power is turned on.
(2) Press the SCAN button.
If you specified the same computer to save scanned data last time, go to (5).
(3) Use the l_mark.jpg or r_mark.jpg button (Scroll Wheel) to select PC i_pcscan6.jpg, and press the OK button.
The computer selection screen will appear.
Besides saving scanned data on the computer, you can save them on a memory card or USB flash drive, or attach them to E-mail on the computer.
(4) Select the computer to save or forward scanned data, and press the OK button.
(5) Select the document type, and press the OK button.
Hope can help you.regards
Jun 14, 2011 | Office Equipment & Supplies
How do I scan more than one page at a time so I have a complete document of 6 pages instead of having 6 different document
you either select add a page, or use the document feeder. The document feeder will try to scan all pages into one file.
Mar 02, 2011 | Brother MFC 420CN All-In-One InkJet...
Simply how to use the scanner which does not come with instructions. Many t hanks for your assistance
  • Click Settings > Scan Settings > Button Settings at the bottom of the left pane.
  • Click the Scan Picture Button tab. Under "Scan to" select the program you would like to edit the image with after the scan is finished.
  • Repeat step 2 for the Scan Button, the Scan Document Button and Scan Film Button. Select the program you would like to use to open each type of scan, or select "Save to File" and the desired file type. Select your preferences under the Document or Picture menus based on the type of image or document you will scan most often using this button. Ensure that the "Show Preview" check box is checked for each button type. Click "OK."
  • Place your document or picture on the glass. If scanning film, place the 35 mm negative or slide in the special adapter provided by HP. Select the Scan Picture, Document or Film button depending on what you are scanning. Select the Make Copies button to copy the document or picture directly. Click "Scan" and then "OK" to see the scan preview.
  • Crop your image by clicking the small black boxes at the edges of the selection area. Drag your mouse until the portion of the image you wish to scan is selected. Select the image correction settings in the menu on the right to fix any problems with the picture or document. You may also change the image resolution and resize the image in these menus. When you're finished, click the "Accept" button. If you'd like to scan another image, select "Yes" in the next dialogue box. If not, select "No."
  • Feb 21, 2011 | Office Equipment & Supplies
    How do I set up my scanner to scan multiple pages at once, without having to keep hitting the scan button. ( fi-6140 )
    Hi, are you using Scannedallpro software? If so, press the batch scan setting button (2nd right after the white drop down menu). This will give you access to your settings. Select add, name your new profile appropriately, then select SCAN, Click SHOW CONFIRMATION WHEN NO PAPER IN ADF, then click on Detail Scanner Settings. This will take you to your options screen. Select either Duplex, for double sided or ADF Front side for single sided. You can choose to drop out blanks by clicking on the OPTION button at the bottoms of the screen, then JOB/CACHE, click the selection button for Blank Page Skip and choose the sensitivity. (I usually use a low setting). Click OK.
    when happy with your settings click OK again, then apply.
    Use your new profile to batch scan. The system will scan until the hopper is empty and should ask if you want to continue with the same batch scan, allowing you to add paper until the job is complete.
    NB Always ensure you have selected Multi Page Tagged Image File Format as the system will not save your scan as one document without it.
    Hope this helps!
    Nov 10, 2010 | Fujitsu fi-5120C
    I am trying to figure out how to use my Brother MFC-8440 scanner. I would like to use it to scan documents to email out. When I go to Brother.com and look at the direction book, it doesn't have directions...
    It is part of the Network User's Guide (section 10) and the Software User's Guide (section 3 for a PC using Windows, Section 8 for network scanning), not the User's Guide. The directions below are for XP and Win2K primarily. Slight changes may exist with other OS versions. (Full software is not available for Win7 so the buttons on the unit will not work. You will need to launch scans from the computer only. You can use Windows Paint or Fax and Scan without needing third party software. Then attach the file to an email either in the email software or by right clicking on the file and choosing Send to Mail Recipient.)
    For either use, put the document face down on the glass or face up in the ADF.
    If you use a directly connected computer, you need to set the destination for the Scan to E-mail in the Control Center (section 4-4 in the Software User's Guide). Open this program and make sure the correct machine is in the drop-down menu. This program needs to be running to hear the buttons being pressed. Click on E-mail to set which program will get the scanned document as an attachment for your e-mail. You can also set the resolution and type of attachment. If you do not want to use available file formats, you will need to scan in PaperPort (or other software) and then use that to attach the file to the e-mail. Then click Scan to launch the scan from the unit. Hit Set when ready to send.
    If you have the unit set up on the network, then you can enter the LAN setup in the Front Panel (or a browser). Hit Menu 6 (and then the appropriate number for the next feature), such as TCP/IP, DHCP or Static IP (these are under 1), SMTP, POP3, Mail Address (Menu 6 2). Setup the Scan to email with Menu 6 7 1 for color and Menu 6 7 2 for black and white.
    This automatically sends the item to the email server or PDF as either a PDF or JPEG. Then you need register the PC that will get the file to the unit, if you use scan to email (PC). (Your version of Windows will matter for exactly where the information is: Control Panel > Scanners and Cameras or Control Panel > Printers and Other Hardware > Scanners and Cameras.) Right click on the icon for the unit and select Properties to see the Network Properties box. Go through all of this set up including the Scan To Button. Then the Control Center will launch the e-mail program when it "hears" you press Scan, select Scan to Email, press Set, then choose PC and press Set again. (or select the destination PC which has e-mail access and press Set again). Scanning will start.
    If you have set the POP3 and SMTP servers and the unit can directly access them, then you can scan to e-mail and enter the recipient address. Press Scan, select Scan to Email, press Set, choose Email Server and Press Set again. Adjust the scan quality as desired pressing Set at each step. Once you go through all of the layers, the LCD screen will prompt you for the recipient's email address. Then press Start.
    I hope this helps.
    Jul 20, 2010 | Brother MFC-8440 All-In-One Laser Printer
    Canon mp630 scanner
    You can save the scanned data on a USB memory or a memory card by using the control panel.
    IMPORTANT
    - You can not use USB memory card and memory card simultaneously.
    1 .Select Scan (Scan) on page HOME (HOME) and then press the OK button.
    The screen where you select where the data should be saved is displayed.
    2 .Turn the USB memory card direct print port or memory card into the slot.
    3 .Select USB flash drive (USB flash drive) or memory card (Memory card) and then press the OK button.
    4 .Select Save on USB disk (Save to USB flash). The screenshot Scan documents (Scan document) is displayed.
    5. State the necessary settings and then press the OK button.
    6. Place the original on the glass plate as shown on the LCD screen.
    7. Press the [color] (Color) for scanning in color, or button [Black] (Black) for scanning in black and white.
    When the preview is enabled, press the OK button after viewing the preview pane on the LCD screen.
    The machine starts scanning and the scanned data is stored either on the USB memory card. Remove the original from the glass plate, the scan is complete.
    REFERENCE
    - You can only scan images continuously when you select PDF. Continue to scan the confirmation screen. You can save up to 100 pages of images in a PDF file.
    - If the USB memory card or memory card becomes full while images are scanned, saved only images that are already scanned.
    - You can save up to 2000 files of scanned data in both JPEG and PDF formats.
    - Folder and filename of the scanned data stored on USB memory or memory card is as follows:
    • Folder Name: (extensions: PDF): CANON_SC \ DOCUMENT \ 0001
    • Folder Name: (File Extension: JPG): CANON_SC \ IMAGE \ 0001
    • Filename: Serial number, starting from "SCN_0001"
    • File dates: 01/01/2008
    Mar 28, 2009 | Canon Office Equipment & Supplies
    Bizhub C250 How to set scan to multi page TIFF for everyone. How to scan front and back of documents Thanks
    To set scan default:
    Select Scan Mode
    Press Scan Settings
    Press File Type
    Press TIFF
    Press Multipage
    Press Ok
    Press Utility/Counter
    Press User Setting
    Press Initial Setting
    Press Current Setting
    Press Ok
    Press Reset
    This will only affect address book destinations. Program destinations specify within their settings the file type.
    To scan front and back:
    Select Scan Mode
    Select Destination (must be done 1st!)
    Press Scan Settings
    Press Simplex Duplex
    Press 2 Sided
    Press Ok
    Mar 27, 2009 | Konica Minolta bizhub C250 All-In-One...
    Scanner
    to be able to scan to pc you have to have the scan file utility set up on the pc
    the scan file utility is on the CD that came with the copier.
    you can Google the file if need be
    when you have loaded the file you will need to go to
    start, all programs,kyocera (scanner file utility and open it
    once in configuration you will need to do the following
    select setup
    on the top you will see a box, type in 001
    file destination, you should hit the box next to this and select kyocera/scan file
    press ok and you are done
    Next
    get the ip address of the scanner, you will find this in scanner default when you have pressed thecounter/system menu button
    get back into normal copy mode
    on your web browser type the scanner ip into the address bar and you will get into the scanner command center
    press the start icon bottom left of your desktop, go to run and type in cmd
    once in dos mode type in ipconfig, this will give tou the destination address for your scans
    now back to the command center, select sender info (left side menu) and type in kyocera after selecting 001 (blue numbers) and submit
    then go to destination setup (scan to pc) and under 001 (blue) enter the relavent info, the address will be your pc's ip address.
    say no to all password requests
    and submit
    very important now is to close the browser as you cannot scan when the command center is open
    please take the time to rate this fix
    Mar 27, 2009 | Kyocera Office Equipment & Supplies
    Won't scan legal documents properly
    Make sure that you set the paper size in the setup menu for legal - 8.5 x 14 for the manual paper feed.
    Jul 01, 2008 | Samsung CLX 3160fn All-In-One Printer
    Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
    90 people viewed this question
    Top Kodak Office Equipment & Supplies Experts
    Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
