Question about Panasonic DMR-ES35VS
Stuck on self check failed
Keeps shutting off clicking okay after self check failure notice. notice wont go away. says to refer to product service but doesnt say anything about the self check failure
  • redrocket768 Feb 23, 2009
    First it asked for a different Blank DVD Disc that I was going to copy, and it would do a self test. Right after placing in a different disc, it went right to Self Check Failed. Then it says to" press Enter, then the unit will open the tray and power off automatically. If this message appears frequently, please refer to the Product Service section in the operating Instructions".
    The other problem, is that I don't have an Owner's Manual.
    You may contact me through E-Mail: k.l.curtis@hotmail.com
I tried changing drives and then i put in a different dvd.
that worked.
Posted on Feb 12, 2009
PSC 1315 All-In-One InkJet Printer: The orange light keeps flashing. This has been hap...
Please perform the steps given below and check.
1. Press the Power button to turn off the product.
2. Wait 15 seconds.
3. Press the Power button to turn the product on again.
NOTE: The product might go through a warm-up period of up to two minutes. The product lights might flash and the carriage might move. Wait until the warm-up period is complete before proceeding.
4. Try to print a self-test report. Refer to the steps on how to print a self-test report at the top of this document.
If the issue still persists perform the steps from the HP Web link and check.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01578337&cc=us&lc=en&dlc=en&product=374568
May 18, 2010 | HP PSC 1315 All-In-One InkJet Printer
The carriage jam message wont go away on my HP4385 and I have tried all solutions on the HP site. Help!
is it connected through LAN or USB,
if it is installed on LAN oen its web page
go to system option and service. click on service it will take few minutes,
Sep 07, 2009 | Office Equipment & Supplies
2000 jeep cherokee interior lights wont turn off
I would check the door adjar switches. IF all the door adjar switches check okay, then check the head light switch .
Assuming the head light switch and door adjar switches are okay , Then there is a wiring problem. This is the worst case scenario .
Mar 15, 2009 | 2000 Jeep Cherokee
The ventilation fan of my power inverter wont shut off
This is hard without knowing the specifics, but these fans can be wired to be on all the time, or controlled by the thermo-switch, or even electrically controlled by a logic board. You may have a stuck Thermo-switch or a bad logic board, since to fail shorted is the standard failure mode (for a Triac).
Nov 16, 2008 | Electronics - Others
I took Paper from the front now the it keeps saying carrage jam(hp Photosmart C7180 all in one)
Step one: Print a self-test report Follow the steps below:
  1. Press the Power button to turn on the product.
  2. Press Setup on the product control panel.
  3. Press the right arrow button until Print Report displays on the control panel display, and then press OK . The self-test report prints.
  4. Analyze the results:
    • If the product prints a self-test report, there is no need to follow the remaining steps, because the error message might be false. Try to print something from the computer.
    • If the product does not print a self-test report, proceed to the next step.
Step two: Clear the paper path Follow the steps below to clear the product of any jammed paper.
  1. Make sure the product is on, and then disconnect the power cord and the USB or Ethernet cable from the back of the product. Do not reconnect them until instructed to later. NOTE: Make sure the product is on before disconnecting the power cord. Failure to disconnect the power cord from the product can cause damage when removing jammed paper.
  2. Open the top access door by lifting from the front center of the product until the door locks into place. Figure 1: Opening the top access door c00786115.gif
  3. Note where the carriage is stuck and look for jammed paper. NOTE: The carriage is the device that contains the printhead and moves left to right during printing. A paper jam can cause the error message and the carriage stall. Paper might be jammed in different locations and might cause the carriage to be stuck in the middle of the product or on the right or left side.
  4. Remove any jammed paper. NOTE: Do not use any tools or other devices to remove jammed paper. Always use caution when removing jammed paper from inside the product. Follow these instructions if the carriage is stuck on the right side or the left side of the product:
    1. Check for and remove any paper or object that might be restricting the carriage.
    2. Manually move the carriage to the opposite side of the product.
    3. Check the paper path all the way to the side on which the carriage was initially stuck. Remove any paper along the path.
    Follow these instructions if the carriage is stuck in the middle of the product:
    2. Manually move the carriage all the way to the left side of the product.
    3. Check the paper path all the way to the right side and remove any paper along the path.
    4. Manually move the carriage all the way to the right side of the product.
    5. Check the paper path all the way to the left side and remove any paper along the path.
  5. Remove the rear access door or duplexer (if installed) from the back of the product. To remove, press in the tabs on the left and right side, and pull it away from the product.
  6. Check for and remove any paper still in the product.
  7. Replace the rear access door or duplexer, and then close the top access door.
  8. Reconnect only the power cord (do not connect the USB or Ethernet cables at this time). If the product does not automatically turn on, press the Power button. NOTE: The product might go through a warm-up period of up to two minutes. Lights might flash and the carriage might move. Wait until the warm-up period is complete before going to the next step.
  9. Check the power light.
    • If the power light is on, reconnect the USB or Ethernet cable to the product, and then print a self-test report as done in Step one.
    • If the power light is blinking or not on and the carriage is still stuck, reconnect the USB or Ethernet cable to the product, and then proceed to Step three.
Step three: Plug the All-in-One directly into a wall outlet Use these steps to make sure the product is properly connected to a suitable power source.
  1. Make sure the computer and the product have a three-prong power plug.
  2. Remove the product power cord from any power strips or surge suppressors, and then plug it directly into a grounded wall outlet.
  3. Try the print job again to see if this step resolved the issue. NOTE: If the product prints when plugged directly into a wall outlet while disconnected from any power strips or surge suppressors, the power strip or surge suppressor might not be allowing sufficient voltage to reach the product. If this did not resolve the issue, proceed to the next step.
Step four: Service the All-in-One If you have completed all the steps listed above and are still experiencing a problem, service the product.
Oct 24, 2008 | HP Office Equipment & Supplies
Scanner Failure
The only thing I can surgest is that you check installed programs I found that the 750 is very fussy about being the only kid on the block. Maybe worth trying a commercial program that says it will remove "junk" from your hard drive
Aug 24, 2008 | HP PSC 750 All-In-One InkJet Printer
Panasonic DMR-ES35VS Logo
307 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
