Question about Acer Aspire 5100 Notebook
Acer 5515 ran out of power now plugged in has grey screen?
When trying to load a cd for wireless router laptop ran out of power when plugged back in it has only grey screen and pointer i tried on off powering up all the way reinstalling cd
  • 596 Answers
If you are able to get to the BIOS settings, try resetting everything to defualt settings. This should correct your problem. Good luck.
Posted on Feb 11, 2009
I have an acer aspire 5515 and it says wireless networkadapter not installed and confurgerd
you need to download and install the driver for your acer aspire 5515
Sep 23, 2011 | Computers & Internet
I have an Acer Aspire 5515 laptop. My computer will turn on but it shows a black screen. I've tried turning it off and back on again. Removing the battery but it hasn't helped. Any suggestions??
Wow this is tuff,
Setting from keyboard, possibly.
Software, not likely.
Video Card, possibly.
LCD Screen, very likey.
But with no screen you options at home are limited.
There is a setting on laptops that allow you to send the video output to an overhead projector and cuts the laptop screen off. However, when you re-boot it usually defaults to the screen.
I betting on a screen failure. You may want to take it to a PC Repair shop. Or, buy one here,
Good Luck
Aug 12, 2011 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5515 notebook I had the noebook on bed and it kept on shutting down then the last time i pressed power button and fan and cd rom will start for a few seconds and the two lkights in fron of...
Sorry to read about your problem, I hope this helps you out.
let it sit for a hour..dont put on the bed, they will get to hot....
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Acer Aspire 5515-5187 Notebook
I have an acer aspire 5515. After downloading a
you have problem with you OS just reinstall OS it will solve the problem
Jun 04, 2010 | Acer Computers & Internet
Me laptop does not connect to router when wireless but will conect when plug in by cable
make sure you down loaded the router into your computer right cause i had the same problem, i had to plug in my router to the motem then pull the power plug out of my motem for 10 sec plug it back in and the motem will talk to the router then install your software again this should work
Oct 31, 2009 | Acer eMachines 520-2890 Notebook
Acer Aspire 5515 stopped responding and will only boot as far as the Microsoft loading screen
Try tapping the "f8"key when booting - it should allow you to choose "safe mode".
If it starts up - scan the PC for errors (including bad sectors on HDD)
If it still does not boot - I'd try booting from the windows install disc and use the installers repair console.
If that wouldn't help - I'd get a bootable CD of Ubuntu or some other OS and try and repair the windows installation from there.
Oct 23, 2009 | HP Compaq Presario R4000 Notebook
Acer Aspire Computer
Hi there.
This method will hard reset the wireless drivers back to default settings, but before you perform this remove power from the modem and router for 2 minutes reconnect power and wait another 2 minutes for them to settle down.
What i want you to do is right click "computer" select "manage" and then "device manager", a list will populate, then click on the + sign next to "network adapters" and right click on the wireless adapter and "uninstall" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again.
Good luck
Jun 30, 2009 | Acer TravelMate 661LCi Notebook
Wireless problems
You'll need to go to control panel/network and sharing/setup a new wireless router or access point. Then follow the instructions in the setup wizard.
Mar 01, 2009 | HP Pavilion dv6000z Notebook
Cd won't load on computer
You may configure your router without using the cd.
Using an ethernet cable, connect the router and the laptop so that you can configure it for internet connection.
1. check physical connection. modem to internet port of router. laptop to numbered port of the router.
2. check lights.
3. on your laptop go to the command prompt. (type cmd on the run window)
4. type ipconfig/all on the black screen
5. look for ip address. IP address should be in this range 192.168.0.*
6. open your internet explorer browser then type
7. type admin on the username then password or 1234 on the password box.
8. configure the router for dsl or cable connection. don't forget to save
9. check if you have internet connection. if not, power cycle the modem and router.
10. once you're online, go to wireless tab. set your ssid (any name you want). set your encryption (either wep or wpa) don't forget to save
11. unplug the ethernet cable from the laptop and the router.
12. if the wireless card of the laptop is configured, you may click the wireless connection icon at the system tray (near the clock). enter your ssid and encryption.
13. you should have internet connection.
Nov 02, 2008 | NetGear WGR614 Wireless Router
Monitor on Acer staying gray
have you tried to the "function+8" (or the number to transfer the signal to a monitor) when you are on the laptop with grey screen?
Did you said that grey, means that there is light on the laptop, but no colors, or that tha screen is not turned on?
Jan 09, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 5100 Notebook Logo
88 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
