Question about Epson Stylus C84 InkJet Printer
Printer problem I changed my ink in my printer. When i did i was suppose to charge my ink cartridges but i forgot to and turned my printer off now both my paper and ink light is flasing. What do I do?
  • 55 Answers
Flashing paper and ink light. check and remove if there are any obstructions inside the printer. turn off wait 3 minutes then turn it back on. if same lights persists i believe this is what they call printer error check on your manual. call the manufacturer
Posted on Feb 11, 2009
FORGOT HOW TO CHANGE INK CARTRIDGE
turn ON the machine and open the front cover(ink cartridge cover)and wait then move the cartridges in the change position and if blinking change the cartridge.
Feb 15, 2013 | Canon PIXMA MP240 All-In-One InkJet...
How do I change ink cartridges for Epson DX4450
1. Make sure the printer is on and open the printer cover
2. Make sure the printer is paused and the output tray at the front of the printer is lowered
3. Hold down the cleaning button for three seconds until the print head moves slightly to the cartridge replacement position, and the power light flashes when the print head is in position. Do not move the print head by hand, it will be damaged
4. Lift up the clamp that holds the cartridge you want to replace as far as it will go.
5. The cartridge will rise partly out of the cartridge holder. For black ink replacement, lift up only the smaller clamp on the left.
6. Lift the cartridge out of the printer and dispose of it properly.
7. Remove the cartridge from its protecting bag. Remove only the yellow tape seal from the cartridge. The yellow tape seal must be removed. Leaving the tape on when you install the cartridge will permanently damage it. Do not remove the tape seal from the bottom of the cartridge.Otherwise ink will leak.
8. Lower the ink cartridge into the cartridge holder with the label on the cartridge face up and the arrow on the cartridge pointing to the rear of the printer.
9. Press the ink cartridge clamp down until it locks in place. Do not press the cartridge itself.
10. Press the cleaning button. The printer moves the print head and begins charging the ink delivery system. This process may take a few minutes to complete. The power light continues to flash while the printer performs the ink charging operation.
11. Never turn off the printer while this light is flashing. Doing so can result in incomplete charging of ink. Even if you do not press the cleaning button, the printer moves the print head and begins the ink charging process about 60 seconds after you replace the ink cartridge.
12. When the ink charging procedure is finished, close the printer cover.
Jun 07, 2011 | Epson Stylus DX4450 All-In-One InkJet...
Forgot how to change ink
Turn the printer on.
Lift the lid that covers the print-mechanism.
In a few seconds, the cartridges will slide to a place where you can easily remove them, and insert a replacement cartridge.
Close the lid.
Jul 20, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Ink changing
When the printer is, powered, turned on, and you open the cover; the print head is supposed to automatically reset itself to a position where you can change the ink.
Nov 08, 2009 | Epson Stylus CX3200 All-In-One InkJet...
My epson stylus cx6000 printer keeps showing -(install the ink cartridges) and I have already put in new ones. The code is E-02.
f you have just installed a new cartridge and you still see an ink related error message, the cartridge may be incorrectly installed. Follow these steps to make sure the cartridges are correctly installed:
  1. Make sure the Stylus CX is turned on.
  2. Check the photo viewer screen to determine which cartridge is incorrectly installed. Then do one of the following:
    • If printer shows the ink cartridge is expended, press the cp_button_6.gif Start button.
    • If the printer shows the cartridge is low on ink, press the Setup/Utilities button. Press the cp_button_41_er.gif or cp_button_42_er.gif button to select Press Start to change cartridges. Then press the cp_button_6.gif Start button.
  3. Press the cp_button_6.gif Start button again.
  4. Lift up the scanner, then open the cartridge cover.
alert_caution.gif Caution:
Never attempt to open the cartridge cover when the print head is moving. Wait until the cartridges have moved to the replacement position.
  • Press down all the ink cartridges until they click into place to make sure they are properly seated.
  • alert_note.gif Note:
    If a cartridge is properly seated already, you may not hear a click.
  • Close the ink cartridge cover and press it until it clicks into place.
  • Close the scanner.
  • Press the cp_button_6.gif Start button. The Stylus CX charges ink for about one minute and displays Charging Ink on the photo viewer screen until charging is finished.
  • alert_caution.gif Caution:
    Never turn off the Stylus CX while the Charging Ink message is displayed or you'll waste ink.
  • Press the Setup/Utilities button to return to the previous mode, if necessary.
  • Aug 26, 2009 | Epson Stylus CX6000 All-In-One InkJet...
    Changing ink cartridge
    Turn on your printer and raise the lid or press the cartridge changing button. Wait for the cartridge carrier to slide out.
    Lift the cartridge holder lid, and the cartridge will pop up for removal.
    Carefully remove the tape from the ink opening on the bottom of new cartridge.
    Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been.
    Close the cartridge holder lid and press the cleaning button to charge the cartridge.
    Close printer cover.
    Mar 07, 2009 | Epson Stylus C86 InkJet Printer
    Epsom dx4450 how to change ink cartridge
    Replacing the cartridge:
    Sep 16, 2008 | Epson Aculaser C1100 Printer
    Ink in hp photosmart 3310
    the printer should have software installed enabling you to opt, for a printer-ink cartridge change.
    If the cartridge has a chip fitted, it may be discharged.
    The chip is supposed to be charged up, for the printer to recognise the newly installed cartridge.
    view your settings in control panel/printer/properties to see what options you have available.
    Mike @ Compurepair.
    Jul 23, 2008 | HP Photosmart 3310 Printer
    Dell 725 printer no manual need to change ink cartridge
    Here is the manual
    http://support.dell.com/support/edocs/systems/725/en/index.htm
    Replacing an Ink Cartridge
    1. Turn on your printer.
    2. Lift the front cover.
    The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
    1. Press down on the ink cartridge lever to raise the ink cartridge lid.
    1. Remove the old ink cartridge.
    1. Dispose of the old cartridge properly.
    2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
    1. Insert the new ink cartridge.
    1. Snap the lid closed.
    1. Close the front cover.
    Feb 09, 2008 | Dell 725 InkJet Printer
    Epson Stylus C84 InkJet Printer Logo
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
