Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Burners not lighting
If you turn the stove top knobs the igniter for the right front clicks. And only the right front burner fires up. Gas is still flowing out of each burner as you turn it corrisponding knob . It seem as if the igniter module is confused. Is this the case and should I replace that part.
I know nothing about gas but I am an Electrician.
  • GE Master
  • 3,361 Answers
You have one or more spark switches defective or a loose wire to the switches.
They are located on each gas valve stem.
Yes they should be replaced for safety.
In the interim you can match light the surface burners.
Posted on Feb 21, 2009
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
www.youtube.com/watch?v=U0VcfMJPaiY
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ...
www.shopyourway.com > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
I have a kenmore stove model number 790,72403012 and 3 of the 4 burners are working. They all are getting a spark, but the front left won't fire up.
First, try to light the burner in question with a match. Just hold a match to the burner, then turn the gas on to low. If the burner doesn`t light, the problem is the gas supply to the burner. Next, lift the top cover and put the prop rod in the hole in the cover to support it. Hold a match to the left-front burner. Now, turn the control knob to "light". You should see the igniter spark and hear a snap. If this doesn`t happen, repeat this step with the left rear burner. If you hear the spark and snap.
If the igniter doesn`t work on the front left burner, but does on the rear left burner, the igniter does work. The problem is likely the control knob for the left front burner. The. Control knob includes the electrical switch the activates the igniter when you turn on that burner.
Jan 26, 2015 | Kenmore Kitchen Ranges
Front right burner will not ignite
I'd get a briquette lighter down in there when you turn it on and try to light it manually. If it does not light, it is a gas supply problem (bad valve or control), and time to call appliance guy. If it does light, the spark path over to the burner may just be plugged with something. If you have gas + spark, but no fire, it almost has to be that the spark can't reach the gas for some reason. That usually comes from something being plugged up.
Nov 27, 2013 | Electrolux EW30DS65GS Dual Fuel (Electric...
Miele KM 3474 stove top lights but turns off after 30 seconds
Does the burner attempt to re-ignite after it goes out? If so, it's probably the therocouple. If not, it could be the burner valve. Be sure the caps and rings are correctly seated on the burners and be sure to firmly press the burner knob down to start the flame.
Feb 04, 2010 | Miele 36 in. KM3474 Gas Cooktop
For the GE XL44 model, where would i find the pilot light? the stove is not working
There is not pilot light on the stove top since the burner is activated by a spark generate by high voltage to a small ceramic disk with a wire protruding from it by the burner.
You have the have AC Power to the stove and you should hear a clicking when you slightly turn on the burner. Once the burner is on fire then turn the burner control to the desired temperature. If the burner will not light after 4 seconds of clicking sounds turn the burner control off and make sure the round gas diffuser on top of the burner is correctly seated on the burner. It should lock in place and is removable for daily cleaning of the stove. Now try the burner control again in the light position for no more than four seconds to see if it lights.
Do you smell gas? Do you hear clicking when slightly turning the burner knob? If yes to both the stove is working and the top of the burner is not seated correctly. If no on either or both you may have a stove, electrical or gas problem.
Jul 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Burner won't light
hi gud day,i think the sensor is we have problem is hard to repair in ur own,try to call the person have expireince for repair that unit, or ur igniter ligther have damage like small broken if u hear have click is ok but much better to check the igniter coz the broken igniter is not directly spark in the burner that why is not light.to check if remove the burner base cover then see if the igniter like a small niddle color white,turn the knob to click the igniter then see it wer the spark directly if u not see it means have a broken igniter.
tns gerbee
May 26, 2009 | Amana AKS3040 Gas Cooktop
Igniter of back burner dies not click or light
I had the same issue with washing the top with water and cleaning solution. I had arching, eventually one burner failed to ignite. I tried the above solution and it did not work. Remove the ceramic top on the burner that will not ignite. Turn on another working element. Do you see the igniter working?
If so slowly turn on the gas on the failed burner and it will ignite. I'm looking into what component automatically controls the igniting and gas release when the knob is turned on.
Dec 22, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove top pilot light
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
Jan 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
197 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
