Question about Gateway FPD2275W LCD Monitor
MENU NOT CHANGING LIKE IT SHOULD FROM DVI TO OTHERS LIKE COMPONENT,NOT EVEN COMING UP JUST PRODUCT TOUR
  • 558 Answers
Damaged mcu
Posted on Mar 25, 2009
How do i connect my dvi to vga to my misubishi ws-65313
you can't, DVI is a digital video source and VGA is an analog video source. however there is a VGA to component RGBHV cable that you can use. the Mitsubishi TV is very limited to the resolutions the VGA output can be. only 1080I, 480P or 480I. HD component video input in the menu you must change the source from Y /Pb/ Pr to RGB.
Jun 07, 2014 | Mitsubishi WS-65313 65" Rear Projection...
No DVI output detected on video screen
older PC desktpop (carbon dated 2010//?)
The Screen message only means the Has stopped sending
signals, to the screen,
that has many causes, all under the title of
Bad PC bad cable.
the Screen is not in DVI mode, most screens have a menu key
and OSD windows, see that, and check the port is set to DVI?
If you tested the screen and it works on another PC that leave
bad PC>
this PC was even made back in the days of VISTA OS
what is yours,? what OS?
this PC (2nd last degeration of many)
has an onboard video chip, (does not unplug)
if you added a up scale video card (we can seen inside to tell)
then it can run on that.
try both yet, the BIOS settings let you change from 1 top other.
try both if both are there,
the product page at hp tells me it has both VGA and DVI ports
try a VGa monitor yet, with VGA cables. (Female 15pin jack is VGA)
that be next and make sure you get GET BIOS to show up
Esc key pressed.
ask at real HP.com , why ask fixya and skip REAL,co.
https://h30434.www3.hp.com/
May 18, 2017 | HEWLETT-PACKARD Pavilion p6597c (WW591AA)...
Blackberry tour does not have any sound even after changing sound profile to several different settings.
Jun 21, 2010 | Cell Phones
Like many others, after three years one of my
It sounds like the monitor might have switched input modes for some reason. You can use the menu on the monitor to scroll through the DVI and VGA settings to make sure it is using the right method of connection.
Good Luck!
Jesse
Jan 04, 2010 | Samsung 906BW LCD Monitor
I have an r52wh74 tv. cant get it to display 720p
Hello Matiki64:
Yes this television does support 720p and 1080i. Hear is something that might solve your problem or at least get you going in the right direction.
Problems with DVI-HDTV Connection
• Make sure the DVI device is turned on and the cables are firmly connected. If problems still occur, turn off your device. Re-connect
your device. Reset the power by unplugging the power cord and plugging it back in.
• If you are tuned to the DVI-HDTV input and you’re receiving Unusable Signal message on-screen, contact the manufacturer of the
DVI device for further assistance.
• If you tune to the DVI-HDTV input and you see snow, the video goes in and out, or the video takes a long time to appear, your DVI
device is having trouble sending video information to the TV. Re-connect your device. Reset the power by unplugging the power
cord and plugging it back in. If problems persist, try connecting to the Y Pb Pr jacks instead if they are available or contact the
manufacturer of the DVI device for further assistance.
• If you have bars on each side of your picture, the device you connected might have a switch or a menu option allowing you to
change the picture format output that will fix this. Choose either 720p or 1080i.
Sep 22, 2009 | RCA Televison & Video
My menu says dtv Currently unavailable. How do I use the HD feature on my Olevia LT32HV
Do you have a High Definition cable/satellite reciever or a Blu-Ray player? Does your tv have a HDMI input or component or DVi or all of those? Most newer HD components use the HDMI connection. The HDMI connection is a single cable that has both video and digital audio together. The component connection is a connector with three rca jacks that are red, green, and blue. Audio is connected seperately with this connection via red and green rca audio jacks or a digital audio connector. The last is a DVi connector that is found on computers. Some older HD tvs and components use this connection. There are adapters available to turn a DVi connection into a HDMI connection. So if your TV does not have a HDMI connection but your HD reciever does you can use and adapter but you will not have any audio this way without using a seperate connector for the audio.
Sep 16, 2009 | Syntax Olevia LT32HV 32 in. HD-Ready LCD...
How do i connect my laptop to my lcd to watch films off the net
Depending on how old your laptop is, or what make it is, you may have few or several options. Some manufacturers have their own proprietary adapters/dongles for video out, but most at least give you VGA out, and others may have DVI, or the newest: an HDMI connector at the back.
If a proprietary dongle is provided, you're stuck with whatever it is they offer. It could be as poor as composite video (3 leads: yellow, white and red), S-Video (better), or best: component video for HD viewing. The first one offers you standard 640 x 480 definition, at 4:3 viewing ratio, while component offers you 1080i, using three leads to connect your
laptop to the LCD. Fortunately, most LCDs have component connectors. If the latter is available, this would be a great option, provided your LCD supports at least 720p, considered to be HD, though not the highest HD. The highest is 1080p.
Depending where you are in this wide scenario, the main thing is to get your LCD TV (I assume) hooked up the right way. The simplest way is to connect it using VGA, assuming your LCD has VGA as an input option. The next one would be to find an adapter to make the match. eg: DVI to HDMI, or vice versa; or VGA to DVI, etc. However the ideal one would be to have matching connectors at both the laptop and the LCD TV: HDMI to HDMI, or DVI to DVI, or component leads at both ends.
Aug 20, 2009 | Acer AOA150-1178 Notebook
How do i get my resolution up to 1080i?
Hi.
If your cable box is not HD you wont get resolution of 1080.
Mar 21, 2008 | Televison & Video
Gateway FPD2275W LCD Monitor Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
