Question about Acer Aspire 5520-5908 Notebook
Acer 5520 restore failed 0xa000000e
I'm triyng to restore my aspire 5520 but show a message- restore failed 0xa000000e click ok to restar the computer
  • 3 more comments
  • amarilys67 Feb 11, 2009
    restore from a disk
    reinstall everything.  I tried with a recovery disk or from a default system and send a same message restore failed
    The drive c is unread or corrupt
    how i formatting the hard drive?
  • John Cole
    John Cole May 11, 2010
    ok have you been able to boot up at all or are you trying to reinstall everything?
  • John Cole
    are you restoring from a restore point or a disk? If its a restore point try a different date to restore from.
  • 3 Answers
Interesting little bit of extra info about this Acer eRecovery Management error.I just got hit with it on an Aspire 4500 Notebook, which was being rebuilt for multiboot use. Seems the Acer eRecovery Management tool won't work if existing partition to restore onto is less than 20 GB in size.
Not all versions of the tool have any partition management functionality, the version I have here doesn't. the Alt-F10 thing just allowed editing boot parameters of the restore dvd.
Posted on Jun 28, 2010
  • 3 Answers
The partitions on the drive have to be deleted. If the alt-f10 doesn't work as ind icated, you can follow this process that I found for an Acer Aspire Restore Failed - reason a0x000000e.
Posted on Apr 03, 2009
    Problem Solver:
  • 10 Answers
I got it to work by deleting all the partitions on my drive (I first loaded xp, loaded system commander 9, and used that to delete all the partitions.)
Then while booting from the recovery cd, holding down alt-f10, the recovery dialog said it was partitioning the drive. (I didn't see this before, even if I partitioned the drive like it came from the factory.)
Then the rest of the recovery worked.
Posted on Feb 11, 2009
  • 3 Answers
If you have installed windows 7 put an xp disk in delete all partitions. Create a new partition format it. Quit the setup then go back to your restore cds for vista
Posted on Mar 25, 2010
    Sergeant:
    Champion:
  • 237 Answers
Ok it sounds like the hard drive either has some corrupt sectors or is damaged do you have a full install of your operating system if so try that. If that doesn't work and you get the same error try re formatting the hard drive. You will lose your data but it may be the only way
  • John Cole
    John Cole Feb 11, 2009
    you need the install disk and youll see an option for it
I cannot restore to the original setting error oxf0000005. I lost the cd
Try the Ultimate Boot CD (UBCD).
See a pretty nice description here:
http://www.barrywheeler.ca/acer-aspire-restore-failed-reason-0xa000000e/
Aug 09, 2011 | Acer Aspire 5102WLMi Notebook
I'm trying to wipe my hard drive with Fedora 12 and three partitions. I have 1 system disc and 3 recovery discs from Acer. After installing files from the system disc, I replaced it in the DVD drive with...
Jeff what you have to do is this dont disturb yourself just go straight off the system then later on it and press your key F11 down at a time simultaneously then it will bring the system recovering factory settings for you and follow the instructions then you are through is just that all you have on the system will be gone but you will have your system back alive the way it was manufacture to work BYE THANKS
Feb 20, 2010 | Acer Aspire 5520-5908 Notebook
My laptop to do inhales 5520 leaves a blue screen to me with a message stop 0x0000005x. Sometimes Windows raises but in the short while it goes out and when attempt to catch it returns to me again to leave...
the error code "HAL initialisation failed" shows that something is going really bad with your Windows installation.
Try starting the computer, while tapping the F8 button, once ever second, until you meet the windows startup menu. Select "Safe mode with networking" and see if it starts.
>two ways to go from there:
>Get a backup and reinstall Windows according to manufacturer's manual
>Try to use "System restore" and go back to a date before the occurence of the problem.
hope that helps.
Jul 12, 2009 | Apevia Keyboard for Acer Aspire 5520,...
Aspire 5520-5912 does not start ,shows only blue screen
Try to get into safe mode by pressing F8 when you first turn onto your computer. Choose safe mode. If you can get into safe mode. Try doing a system restore back to the last date the computer was last working properly.
If you can't get into safe mode then you'll need to wipe out your hard drive and get your system back to factory defaults. You probably have corrupt system files that are causing these problems.
Jun 20, 2009 | Acer Aspire 5520-5908 Notebook
I can't boot my computer
try safe mode tap F8 on start up and click ener by using the up and down arrows and click safe mode by hitting enter
Jun 02, 2009 | Acer Aspire 5100 Notebook
Restore failed - reason 0xa000000e
Did you install a new hard drive in the Acer? They have had problems when trying to restore windows onto a new drive or trying to use system restore on the existing drive. The same error message comes up.
It seems that when the pqservice partition is not on the drive, the recovery DVD won't work if the drive contains any partition (Restore Failed - reason 0xa000000e) is all you will see.
However, try deleting everything on the drive (leaving only unpartitioned space) before putting in the recovery DVD. The eRecovery tool first says that it is repartitioning the drive and then starts the install successfully.
I hope this helps.
Acer aspire 5520 won't load up upon reboot
when the computer first boots click alt f10 on your keyboard and it will take you to the acer restore program. you can then restore your computer to the default settings. you will be asked to hit enter before it will allow you into the screen
May 11, 2009 | Acer Aspire 5520-5908 Notebook
Acer Aspire 5520
only a couple of things in your computer that will click, that would be your hard drive or your cd-dvd rom.or if you have a disk in your 3.5 diskette drive.
Let me know how it goes.
Mar 09, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Restore
The recovery partition is corrupted. 1st option is, You can send your computer to acer repair center in germany. I believe acer have international warranty. 2nd option is to buy the recovery cd from acer, you can installed by yourself.
About downloadable OS, i don't think they have it online.
Feb 24, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5520-5908 Notebook Logo
6,527 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
