Question about Dell PowerEdge 1800 Server
Concise Question, Poweredge 1800 powerup failure
Hi: I asked earlier, but my info was not well thought out. I thought best to try again.
1)On occasion when I power on, the case fan turns on, and a yellow wire output line from power shows 12V for maybe 5 seconds or less. Then the voltage drops to nearly nothing, and the orange light starts to blinks on the server. It never shows anything on the video screen.
2) If I try it again soon after, while the case fan never turns on, the voltage shows nearly nothing. The power supply fan does run though.
3) However If I wait awhile to try it again (maybe an hour) it will again do what it did in (1) above.
I did try running it, disconnecting all drives and the fans one by one. This did not help (I was looking for a short).
To me, this smells of a bad power supply. But expensive to guess. Any feelings on this? Thanks. Sorry for bad question before, I was not being clear.
  • 1 more comment
  • fkalich Feb 11, 2009
    Correction: (2) should read
    2) If I try it again soon after the power supply fan does not turn on and the
    I worded it sloppily, and thought it might confuse. It has been curious to me that power supply does run its own fan fine. But I guess a defective power supply might still be able to do that.
    Disregard the correction comment, screw up again. I mean to say
    2) If I turn it off, and try to power up again right after that, the case fan does not turn on at all, and the
    voltage shows nearly nothing from the beginning. The power supply fan does run though.
  • fkalich Feb 13, 2009
    Thanks Aenim4. I did try the PS from an old dell 1600 and nothing happened at all. But that server is set up differently. When you plug the 1600 in, there is no activity, not until you push the start button. There is a line from the PS to the front, I expect to the start up switch. On my 1800 there is no such line, the PS fans turns on and the case fans for a few seconds when you plug it in. I even was able to keep that long line hooked into the 1600, and pushing the start there, but that did not help. But I will try a different PS when I can, or some other way as you suggest. I will give you the appropriate 'helpful' or 'FixYa' rating after I found out if this indeed was the deal (as I expect it will be). Again, thanks for your help.
    Scholar:
  • 53 Answers
It is definitely the PSU that's not working properly,because defective motherboard should still receive the 12V. you can use a desktop standard power supply to check if the server runs fine, even a cheap one is ok for a test run. they sell also cheap (about 15-20$) PSU tester, definitely worth when working with servers and WS.
the Power supply fan might have a dedicated rail coming from the thermal sensor(thermistor.)this is why it can run even with bad 12V rail.
Posted on Feb 13, 2009
I am having a problem with my dell poweredge 1800, it beeping continuous
Assuming this is still an issue...old as it is...
You need to boot the server and press the correct prompt to enter the BIOS of your PERC RAID controller. There you need to manage your physical/logical volumes.
Chances are that either you had a drive failure or the metadata on your RAID volume (JBOD?) was corrupted. This is a common issue with these LSI-based PERC[5-6]i RAID controllers that Dell utilized.
Jan 18, 2014 | Dell PowerEdge 1800 Server
My server poweredge 1800 failed how can i remove data? and the server was configured raid 5
The obvious is to repair it, but if you have another identical server you can place drives and access data. The replacement should boot as failed server. Make sure to track drives and slot location. Shuffling may cause major failure. It may want to stripe itself again and cause data loss and defeating the purpose.
Aug 31, 2012 | Dell PowerEdge 1800 Server
All lights flashing rapidly
Indicators, Codes, and Messages
Dell PowerEdge 1800 Systems Installation and Troubleshooting Guide
http://support.dell.com/support/edocs/systems/pe1800/en/it/r2053c20.htm
Aug 06, 2012 | Dell PowerEdge 1800 Server
Poweredge 1800 shuts itself down several times a day.
Hi
A server shuts itself
1 if some hardware problem is there. so check any yellow/organge colour led is glowing in the server which indicates hardware failure.if it under AMC then get it checked with vendor.
2 when there is some problem with the OS.
2 when the surrounding temp of the server is very high.
Jan 25, 2011 | Dell PowerEdge 1800 Server
Video card that supports Dell PowerEdge 1800
It says it has an embedded 7000m chip, there is no mention of a graphics slot for a discrete add in card.
Some info here http://en.community.dell.com/support-forums/servers/f/956/t/19274842.aspx
Sep 30, 2010 | Dell PowerEdge 1800 Server
I am trying to install esx 3.5 from a usb on a poweredge 2650 and have not been succesful. any thought?
Hi Dell poweredge 2650 dosent support usb boot
try using a CD or DVD or floppy if you can get 1 big enuf
Sep 30, 2010 | Dell PowerEdge 2650 Server
Valid operating systems fro Power Edge 1800
During the Windows XP setup you will need to provide the RAID driver using a pre-formated floppy disk.
Windows will ask you if you want to provide additional drivers and give you the key combination to use to do that.
Jan 21, 2009 | Dell PowerEdge 1800 Server
Dell PowerEdge 1800
Hi satti73,
I need you to explain your problem a little more clearly.
I think you are saying that when you press the ON/OFF you get a display? What is the display that you get? How old is this machine? What other events have taken place leading up to this problem. Do you get and error messages on the monitor? DO you get any sort of sound emitting from the server when you press the ON/OFF butoon?
Nov 09, 2007 | Dell PowerEdge 1600SC Server
Dell PowerEdge 1800 Server Logo
1,095 people viewed this question
joecoolvette
joecoolvette
Brian Sullivan
Brian Sullivan
