Question about Acer X191WSD Monitor
P191W Screen brightness, how do I reset Factory Settings
After playing Call Of Duty One and Call of Duty 2: UO, the monitor did not reset to the default factory settings. Now, it is really difficult to see the screen, ie; print, web, etc. Tried using the menu mode to reset factory settings but it didn't work. tried Contrast/Brightness adjustments and they didn't have any significant impact. anybody got the secret out there to reset this bad bear?
4 Suggested Answers
  • 1003 Answers
SOURCE: Adjusting Brightness on Acer 17 inch monitor
you change the settings manually using the up and down arrow buttons or plus or minus buttons mounted on the front of your monitor you dont need to use mouse.
Posted on Jan 16, 2008
SOURCE: Acer AL1715 - insufficient brightness
No there isn't any. there is probably a part that is damaged due to the surge u should get a new one or send it back to the company
Posted on Feb 02, 2008
budmrtn
  • 11361 Answers
SOURCE: monitor looks floresent
If you want to DIY repair, please see my pictures here so you will know what bad caps look like, that will be the first thing to look for inside.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
http://s807.photobucket.com/albums/yy352/budm/Acer%20AL1916W/
http://s807.photobucket.com/albums/yy352/budm/ACER%20AL1916W%20Abd/
Posted on Apr 22, 2010
Brightness set to all the down
There should be a menu button on the monitor. Press this button, it has it's own brightness settings. Press the "factory settings" button; monitor should return to normal brightness.
Sep 19, 2013 | Dell Dimension™ B110 PC Desktop
My dell monitor is too dark
There is a small light behind TFT screen which must have gone bad
Feb 15, 2013 | Dell S2209W Monitor
The colors on my monitor are faded!!!! i got a compaq q2009
Check the backlight settings on the monitor, Sometimes they are set too low and it looks like the color is faded. In the monitor settings (on the monitor Itself) play with the color and brightness until you find a setting you like. If you need reset the monitor to factory.
Jun 17, 2011 | Compaq Q2009 Monitor
My monitor is brighter on the lower left side than on the rest of the display?
NOTE : steps below are only for a Dell monitor
There could be two reasons for the same,
1. The monitor settings are bad or
2. The monitor has gone bad.
Request you to disconnect the monitor signal cable from the back of the computer (cable with the blue jack)
A self test feature check would run on the screen. If the screen is bright in the feature check . The monitor has gone bad and needs a replacement.
If the screen appears ok in the self test . Press the menu button on the monitor and select factory reset.
Thanks
Proton
Feb 06, 2010 | Dell E173FP 17" LCD Monitor
Screen Too Bright
Do a factory reset on All Settings:
http://support.dell.com/support/edocs/monitors/se197FP/EN/ug/setup.htm#Using_the_OSD
Dec 06, 2009 | Dell SE197FP 19 inch LCD Monitor
My 19" Princeton flat panel monitor is "washed-out" looking. It is very light, I can hardly see the characters, letters, etc. on the screen. I don't know how to adjust this as there are two buttons on...
reset the brightness and contrast if something has causedmthem ti go uo. somewhere around 50-70% seems right, but set on a screen you know what should look like
Jun 08, 2009 | Princeton Digital LCD1510 15" Flat Panel...
Acer P191W monitor does not fill up the screen
Try pressing the "Auto" button located by the power button. If that doesn't work, I have a few questions for you.
Apr 30, 2009 | Acer P191WBD LCD Monitor
Colors have gone wrong
There could be 3 reasons for this...
1. If color settings are changed from the computer...
try to reset to defaults
2. if colors are changed from monitor..
try to reset to factory defaults
3. If the Monitor cable is loose..
try differnt monitor if available with the same cable which is used to connect monitor and computer, or try using different cable on same monitor and computer.....
Nov 02, 2008 | Dell E176FP 17" LCD Monitor
Kogi L9ch 19 in flat monitor
(I posted the latest post.) Change the resolution. (Mine was 1024 by 768, so I changed it first to 800 by 600 and then back to 1024 by 768, and it's back to normal!)
Hope that helps.
Feb 13, 2007 | Kogi L9CH 19" Flat Panel LCD Monitor
Acer X191WSD Monitor Logo
160 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
