Question about Baby Lock Esante
Palette Creative embroidery Software
My husbands late wife had an embroidery machine. We have found the Palette software, upgrade for versions 1-4 to version 6.0. The computer will not let me download the upgrade because I don't have the original .
where can I get the 1-4 version?
  • Patti Sep 06, 2013
    I have versions 1-3 and possibly 4. in which state are you located.
I was wondering if you would like to sell your upgrade - I have version 1
Posted on May 06, 2009
There is a complete version 4 up for auction on ebay, last time I looked high bid was $200
Posted on Feb 22, 2009
I have Babylock Palette 5.0 and I want to install on windows 7/32/64bit I do not know which install upgrade to use. I have installed the orginal disk and it does not work properly. Please advise.
Ester,
You will need to upgrade to Palette 8,0 or NeXT versions that are compatible with Windows 7. I'm not sure if Palette 7 upgrade will work either. Other option, may be to get old computer with Windows XP and the right Parallel printer port with the card reader security device for Palette software to work.
Cheers,
Kelly
San Diego, CA
EmbroideryServices
May 26, 2014 | Baby Lock Esante
How do you upgrade the Bernina Artista motherboard from version 0.3 to version 0.4? I have a machine that tells me that the embroidery unit is not compatible with the machine
You do not need to changes any board. The machine carries software and so does the embroidery unit, in order for the to read each other the s.machine and e.unit must have same software. Just take you machine and embroidery unit into your local bernina dealer and have you dealer download version 4.01 to you machine and e unit. then all will work just find. usually the dealer will do the download for free!!!!!!!!!!
Apr 04, 2010 | Bernina Artista 180
Baby Lock Embroidery Sewing Machine "ELLURE" Model ESL- Problem: Defective Embroidery Memory Card (part#35205-4) used with the "PTS BOX" and the Palette Ver 1.0 Software Program to transfer embroidery...
I had the same problem and after buying a new card, found out that you get that message if the pattern you are trying to transfer is too big. reduce the size of the pattern and see if that works
Jul 11, 2009 | Baby Lock Ellure
When I try to open design enhancer I get an error
This error can appear when you attempt to start 4D software. This will happen if you have installed any version 8.0 4D software, and the 4D Embroidery System software that is already installed has a later version than your 4D software.
If you have a CD (or DVD) containing 4D Embroidery System Software for version 8.1 or later, install the update for the 4D Embroidery System found in the Patch folder on the CD (or DVD).
If you have updated your 4D Embroidery System to version 8.1 or later using an update obtained with Smart Update, find the update you have already downloaded and run it again.
If you are unable to find the update, or you are not sure if you have the latest update, use Smart Update to obtain the latest update, as described in CC007.
When you run the update, you may be asked to choose between Modify, Repair and Remove. This selection appears because you have updated on a previous occasion. Choose the Repair option, and this will ensure all your 4D Embroidery System software is updated.
Mar 14, 2009 | Husqvarna Viking 1
Husqvarna 1 Embroidery software
Use program compatibility wizard and you'll be able to use the same program in Windows XP also.
  • To start the Program Compatibility Wizard, click Start, click Help and Support, click Find compatible hardware and software for Windows XP, and then, under See Also in the navigation pane, click Program Compatibility Wizard.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Dec 20, 2008 | Husqvarna Viking 1
Sftware
Hi, Unfortunately any of Bernina's software that is older than Version 5 , will not work with Vista. There are some software patches available on the berninausa.com web site, but there is nothing out there that will help you if you have any Version 4 software or older. Microsoft really through out a curve ball to everyone with VISTA as there is a lot of software out there that will not work in that operating system.
Actually the lowest cost solution would be to get a nice used computer that runs Windows XP. You do not need a super fast, state of the art computer to run embroidery programs.
I bought a nice used computer at a yard sale for $10.00 and it even came with the XP install disk. I replaced the hard drive just because they do wear out after a few years, installed XP in it and that computer is now in my wife's sewing room and it is only used for her embroidery work.
You might have a computer repair shop in your area where you can buy an older XP computer that has been reconditioned. The few dollars you would spend to get an older computer would cost you far less than buying new Bernina Version 5 software. It is EXPENSIVE! Good luck...bushvideo
Sep 11, 2008 | Bernina Artista 180
Start up..Babylock BMP6
Not if you just want to get the patterns off the internet, etc., you cannot, or at least with my older version, make your own designs. You need to download the program to your computer. Its pretty simple if you get on the internet and download the designs put your palette on your computer, go to the designs, with a blank card, and load the patterns. Hope this makes sense.
Apr 14, 2008 | Baby Lock Ellure
Sewing Machines Logo
710 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
