Question about Whirlpool RF364 Electric Kitchen Range
Error message EO F3 - Whirlpool RF364 Electric Kitchen Range
Check Thermocouple Oven sensor. ShouldRead 1080 Ohms at roomtemp. If that is working youneed a new control Board
Posted on Apr 21, 2009
WHEN MY WHIRLPOOL BUILT IN OVEN MODEL RBS305PRS00 IS BAKING IT SOMETIMES CUT OFF AND YOU HEAR A CLICKING NOISE AND IT WILL DISPLAY EO F3.I CAN TURN THE OVEN OFF AND IT WILL BEEP AND DISPLAY EO F3.AFTE
That's an oven sensor error. Replace the oven sensor. If you still have the error, check the wiring and/or replace the timer/clock board.
Nov 26, 2014 | Whirlpool Ovens
I have a kenmore gas range with a computer panel on it, error message is EO F3 and I cannot clear it or use top or oven.
Hello & Welcome to FixYa
F3 E0 error code indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 11, 2011 | Kenmore Kitchen Ranges
I dont know the exact model but its a kenmore gas range...it displays EO -F3- when i try yo preheat the oven...it is not getting hot at all
Hi
Thanks for using FixYa. Error E0-F3 means oven temperature sensor failure and to resolve this the oven temperature sensor should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 20, 2010 | Kenmore 46133 Stainless Steel Dual Fuel...
CONTINUE TO GET THIS ERROR MESSAGE EO-F2
you may have an oven temp sensor out of wack. may have carbon on it . wires going to it may have burned
Feb 03, 2010 | Kitchen Ranges
Whirlpool error message EO-F3 and E4-F3 sometimes while cooking, when trying to use the clean oven mode (which will not even function), and sometimes when the timer goes off (inevitably shutting the oven...
Bad EOC. Have to change the oven control. Sorry but this will be the only repair unless you know some one who can take it apart and repair some connections by using a soldering iron. Good luck.
Feb 02, 2010 | Whirlpool Accubake RF362LXTS Electric...
Electric kitchen aid double oven gives eo message
there should be more of a code like fo/eo or f2/eo or f3/eo or f5 /0o .. if you have # 1 = analog t digital l failure / replace control..= #2 shorted key pad / = replace control /? # 3 oven tempt sensor = repl oven sensor or fuse .// # 5 ck door /latch sw = replace component .. hope this helped . mm ( re/ck codes and see if one of thes matches your problem .. mm pls leave feed back ..
Dec 12, 2009 | Washing Machines
Getting error F3:EO
HI. This code is indicating that the Oven temperature sensor (RTD) is opened(stuck). If this is a double oven design, this will be the upper oven sensor. The solution will be to ,simply, replace the affected sensor. It is not repairable.
Dec 06, 2009 | KitchenAid Ovens
Kenmore Model 665 95781000 Stove Displays a EO-F3 code and the oven does not work WHat part work be defective to give me this fault code EO-F3?
F3 - E0 Oven temperature sensor (RTD) opened (upper oven, if double oven) Replace Oven temperature sensor (RTD)
Sep 25, 2009 | Ovens
WHIRLPOOL RF385PXG
If a new temp sensor doesn't fix an F3, you have a loose connection, or the electronic control is bad.
Feb 09, 2008 | Whirlpool RF380LXPS Electric Kitchen Range
F-3 Error message
this error refers to either a sensor problem, check it with an ohm meter. should be around 1100 ohms at room tmp. you can order the part through sears, just give them the model number and ask for an oven sensor, or thermistor. ALLWAYS UNPLUG THE UNIT WHEN TESTING OR REPAIRING
Sep 25, 2007 | Kenmore 95822 / 95824 / 95829 Electric...
Whirlpool RF364 Electric Kitchen Range Logo
240 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
