Question about Lexmark X5470 All-In-One InkJet Printer
My lexmark is jammed
It says load paper but it has paper and it goes down to print and gets jammed jus almost were you cant see the paper anymore but it does not say paper jam
  • 46 Answers
Did you have any jams recently where the paper was badly damaged, and or came out in pieces? If so there may be a small amount of paper still jammed in the printer, out of sensor range. try looking deep into the bottom of the paper path and around the roller.
Posted on Feb 11, 2009
Getting message that I have a paper jam but there isn't on to be fpund
Try checking the printer for foreign objects that might be interfering with the paper path. Tilt the printer sideways and try shaking it a bit. After that, try printing. If the issue persists, clean the rollers of the printer.
Dec 13, 2012 | Lexmark X4850 WIRELESS All-In-One InkJet...
I have a 5650 lexmark printer and it keeps saying paper jams but there is not paper anywhere.. how can i find a solution... when you load paper it keepps getting stuck.. help
There could be something blocking the paper path. Try to shake the printer upside down. You'll be amazed of the things that falls off inside the printer. Also, make sure that there's no paper left inside the printer. Tiny pieces of paper will still lead to paper jams.
May 31, 2012 | Lexmark X5650 AllInOne InkJet Printer
When i try to print its pulling the paper in wrong, and then saying paper jam whats wrong?
Maybe the paper loading.Try this:-
  • Remove the previously stuck paper and turn the printer off and on.
  • Extend the paper guides by pressing down the paper adjustment lever.
  • Now load the paper making sure it goes into the center of the paper support and then adjust the paper guides by moving the lever up or down.
  • Make sure the paper guides rest against the edges of the paper.
Hope this helps.Thanks!
Please rate this answer.
Nov 04, 2011 | Lexmark X5650 All-in-One InkJet Printer
Paper keeps jamming. we get a partially printed page,then jams about 2/3 of the way and we have to pull it out.
You can avoid most paper jams by correctly loadingpaper and other media in the printer. Tips on how to help prevent paper jams · Do not loadwrinkled, creased, or damp paper. · Make sure thepaper is not buckled in the tray. · Never mixpaper/media types within a single tray. · Flex, fan, andstraighten paper before you load it. · Do not exceed themaximum stack height. · Push all papertrays firmly into the printer after loading them. · Make sure theguides in the trays are positioned snugly against the paper. · Do not remove anypaper trays while a job is printing. Wait for a Load Paper light sequencebefore you remove the tray. See the 'Load Media' section on page 61 of theUser's Guide for more information. · Use onlyrecommended paper. Consult the CardStock & Label Guide on the Lexmark web site for more information aboutwhich paper provides optimum results for your printing environment. For additional assistance, please contact LexmarkTechnical Support.
May 31, 2011 | Lexmark E232 Laser Printer
Printer has been working fine. all of a sudden the paper started to load crooked and jammed. now it continues to do this...why?
Usually it's because something has fallen down the back where the paper goes. One person on here turned her printer upside down and shook it and a Bic pen fell out. I got one last week with a wood screw inside. sometimes I find push pins, candy or jewelry. If nothing comes out try looking inside with a light and small mirror.
Jan 25, 2010 | Lexmark X4650 InkJet Printer
PAPER JAM
Rotate tires. Pull out paper tray. Pull down on red low paper indicator at left bottom. Two rollers come down on axel near center. I pulled off the rubber tire like roller, then twisted the roller inside out and reinstalled it with the fresh side out.
If tires dry out again will probably buy new ones from ebay.
Jun 26, 2008 | Lexmark E232 Laser Printer
Paper jamming
Look for some foreign object in the paper path. Easiest way is to turn the printer upside and shake it. (carefully :-)
Aug 31, 2007 | Lexmark X2470 All-In-One InkJet Printer
Lexmark 4300 not loading paper correctly
Look down the paper feed into the printer you will see one white plastic roller. Find a cotton bud and soak the end in methylated spirits and poke it down and wipe the roller. make sure you wipe the whole circumference of the roller. This removes any grease that has come off the paper onto the roller and allows the roller to grip the paper better. I have done this once and have not had a recurrence of the problem.
Aug 11, 2007 | Lexmark P4350 All-In-One InkJet Printer
Paper jam
Can you tell me if the paper goes through squint?. if you turn the printer upside down and give it a gentle shake and see if anything comes out, i have removed pens, toast, and loads of other things that sometimes gets stuck inside. also have a look and see if you can find any jammed paper even if its only a tiny bit, this fixes 80% of the printers that comes into us. hope it works John
Mar 01, 2007 | Lexmark X73 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
124 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
