Question about Whirlpool Washing Machines
Whirlpool WF 665/1 Doesn't proceed to next cycle
Just keeps filling up and will not spin or start wash cycle even when manually moved to the next notch. No problem emptying.
  • 343 Answers
SOURCE: LG WF T6517TC Washing Machine does not fill water
make sure the drain hose is above the working water level or the water will merely flow through the machine
Posted on Apr 24, 2010
  • 64 Answers
SOURCE: Indesit Washing Machine not proceedding with the cycle programme after filling with water.
Cant understand how the machine will revolve on the 'spin cycle' & yet you can hear the motor on the 'wash cycle' but yet it doesnt revolve!!
Nomally if the water fills, & the tub revolves without the programmer advancing, its because the heater is not working. ie faulty thermostat, heat element, or maybe a wire burned off in the 'heater circuit'. Check if you have 240 volts at both ends of the heat element, with a meter or 240 volt bulb
                         !! BE CAREFUL OF 240VOLTS!!
Posted on Oct 31, 2007
  • 109 Answers
SOURCE: Washing machine fills, but won't agitate
sound like the lid switch is open, if that doesn;t fix it try the water level switch
Posted on Mar 30, 2008
  • 19396 Answers
SOURCE: Washing machine fills in the water but does not start the wash cycle
The fact that it does not fill completely can be related to a problem with the water-level switch, that regulates the water level.
See from Repairclinic:
"This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch."
However, when it is only the switch the mashine usually completes the cycle, but with less water than normal.
A possibilty is that either the timer is faulty or there is a problem with the water supply.
Check that water is coming from water supply with regular pressure, and that hoses back there are not obstructed.
More likely you will have to replace the timer.
See again from Repairclinic:
"When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water."
  • You can find parts at the following websites, you need to input your model number. If the part is not listed contact them.
    Don't forget to rate the solution.
    Many thanks.
    Posted on Sep 01, 2008
    SOURCE: Roper washer wont empty
    the pump is not working
    Posted on Oct 28, 2008
    Fills with water correctly, will not go to next cycle
    Hi ,, ok lets try some fault finding,,, try putting the washing machine on a no or low temp programme like wool,, or even the fill empty spin , see if it moves then,, if the programmer moves through then spins, i would assume the thermostat is broken,, if it moves through but does not spin , it may be the heating element,, if it does not move at all in any programme i would assume the programmer has a problem
    Nov 14, 2013 | Whirlpool Washing Machines
    Whirlpool washer model lsr8233eqo
    So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
    Feb 03, 2013 | Whirlpool Washing Machines
    My idesit IWB5113 just keeps filling after starting the wash cycle, normal it inject some water then starts washing, my machine just keeps filling and doesn't seem to start the wash cycle, please help
    It is possible that the water level sensor has failed and so does not detect to stop the inlet valve from filling.You can remove and check this level sensor normally it can be a damaged diaphragm and replace the same so that the program proceeds to the next stage to start the machinetips to see working of the machine;
    Mar 14, 2012 | Washing Machines
    Washer fills but won t advance to the next setting for all cycle
    Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
    Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
    New Whirlpool washer model WTW5700SW rinse cycle doesn't worker properly. The water never fills the tub & continues to drain. You have to manually move the dial to the end of the rinse cycle to have...
    Sounds like what you are describing is the timer on the dial is not activating the next cycle. Timers are usually the problem when the cycles do not complete there cycle
    Dec 03, 2017 | Whirlpool Washing Machines
    Mar 27, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Whirlpool filling and washing, not draining, rinsing or spinning
    Check out your outlet filter, probable it is clogged. Clean this out and refit. Most cases when the drain or spin does not work, it is the filter. This is a suggestion.
    Apr 01, 2007 | Frigidaire FWS833A Top Load Washer
    Washing Machines Logo
    210 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
