Question about Intel Motherboard
Mother board problem.
Im using MSI k7n2v motherboard. My problem is with the USB ports of my motherboard. When I use Bluetooth it does not work properly. But when i use the same Blutooth in my friends system it works properly. But rest of the device work normally with the USB, only problem is with Bluetooth. Is there any driver updates for the motherboard? Please help. Rohit Balgalore.
    Scholar:
  • 125 Answers
I feel this may be a software problem. Which version of Operating System are you using?
Posted on Aug 01, 2007
SOURCE:
Problem with mother board ms-7030 usb ports and ps/2 not working at all
The USB and PS/2 ports are ,as far as I can tell, controlled by the same chip on the motherboard. If this has failed you will have to replace the motherboard. Your board and processor are very old so the chances of thermal failure are very likely. Sorry, a new mobo and cpu bundle will make a vast difference to your experience and can be found fairly cheaply.
Apr 07, 2012 | MSI Computers & Internet
USB port problems
You need the motherboard specs, which you can look up on the internet, based on the maker.
With the USB ports, the front ones often don't include power.
So plug a powered 4 port hub into the front port, and then the hub will supply the power after that.
Jun 26, 2009 | MSI K7N2 Delta-ILSR (MS-6570-030)...
My usb ports dont want to work
did u install driver of the motherboard properly, if not download the driver of ur motherboard if stil not working my only advice is u buy a pci or agp usb card its look like a video card something like that then try input the new hardware or connect to the mother board what if ur card asign.
Jun 15, 2009 | MSI 845GVM-V (MS-7057-010) Motherboard
Usb
please click follow:
http://www.pctechguide.com/tutorials/MBoard_USB.htm
acording the table and picture you can make easy to correct your USB connection.
hope help you fix it, any question send any time please!
please take a rating let me know how much helped you, thanks!
May 17, 2009 | MSI 865PE Neo2-PFS Motherboard
Asus 845 chipset pb4 mother board not starting
it may be the circuit problem,inside the mother board.send it to service center
Jan 16, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Usb Port is not working
Mercury Chipset Mother Board Number : pig31Z
Problem is USB Port is not working... so send me the driver detils throw out my mail....thank you
[email protected]
May 16, 2008 | ASUS P5GD1-VM Motherboard
No sound from front headphones
check your speaker is good and it i inerted in the correct slot and it raise the error of POST so the mother board power had some problem cheak wether the led in the mother board glows properly once it correct check with your board input power +-5,using your multimeter.or else there is a problem in your smps
Mar 25, 2008 | MSI P6NGM-FD Core 2 Quad Socket 775...
Usb2
the thing is u have to update ur bios by downlaoding update file frm msi.com . plug a flash drive unto ur usb . if a message showing this device can peform faster . then ur usb is 1.1 . if noting shows then ur port is usb 2.0
Jan 25, 2008 | Intel Motherboard
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
